Infographic comparing near-zero indoor liquid cooling with the wider water footprint of data center operations.
On June 22, 2026, Nvidia used London Climate Week to promote a Vera Rubin DSX data center reference design that can cool next-generation AI racks with a closed liquid loop and, in favorable climates, consume virtually no water inside the facility. That is a real engineering achievement, and the company is right to treat it as more than a lab curiosity. But it is not the same thing as solving AI’s water problem. Nvidia has moved the thermal boundary of the data center; the environmental boundary remains much wider.
Nvidia’s Water Claim Is Precise, but the Headline Is Not​
The important word in Nvidia’s pitch is not “zero.” It is inside. The company’s claim applies to the cooling system within the data center facility, not to the full chain that makes AI compute possible.
That distinction sounds pedantic until the numbers come into view. A modern AI data center consumes water directly when it uses evaporative cooling, but it also depends on power plants that may consume water to generate electricity and semiconductor fabs that use vast quantities of ultrapure water to manufacture chips. The facility wall is a convenient accounting line for an infrastructure vendor; it is not where the resource footprint ends.
Nvidia’s DSX design appears to address one of the most visible and politically combustible parts of the problem. Cooling towers are easy for communities to understand because they draw from local water systems, sit beside local substations, and appear in planning disputes. If Nvidia can remove or sharply reduce that demand, it gives hyperscalers a powerful answer to mayors, regulators, and residents worried about whether AI campuses are drinking from the same scarce supplies as farms and households.
But a powerful answer is not a complete answer. The risk is that “near-zero water” becomes a slogan detached from its perimeter. Once that happens, a specific thermal advance starts being sold as absolution for an entire industrial stack.
The Engineering Advance Is Bigger Than a Sustainability Slogan​
The DSX design matters because AI hardware has reached a point where air cooling is no longer an adequate default. Rubin-generation systems are expected to push rack densities beyond the comfort zone of traditional server rooms, with power levels that make fans increasingly inefficient, noisy, and physically limiting. Liquid cooling is not a green accessory bolted onto the side of the system; it is becoming a condition of deploying the system at all.
Nvidia’s reference design uses a closed loop of coolant, reportedly a mixture of water and propylene glycol, moved through cold plates that sit close to the heat-producing components. Instead of blasting air across servers and relying on chillers or evaporative towers to manage the resulting heat, the system captures that heat at the chip and carries it out to dry coolers. The loop is filled and recirculated rather than continuously consuming fresh water.
The striking part is the temperature. Nvidia is pushing coolant inlet temperatures up to around 45°C, far warmer than the chilled-water assumptions that shaped much of the data center industry. That higher temperature makes the heat easier to reject outdoors without conventional chilling because the system has a larger useful gap between the coolant and ambient air for much of the year.
This is why the design is not merely “liquid cooling,” a phrase that has been around long enough to become marketing wallpaper. Warm-water cooling at this scale changes the economics of the plant. If the coolant can run hot, the facility can often lean on dry coolers rather than evaporative systems, reducing both water use and the power load tied to chilling equipment.
For WindowsForum readers used to thinking at the PC level, it is the difference between adding a better radiator and redesigning the platform around a new thermal envelope. Nvidia is not just swapping the cooler. It is telling facility designers, rack vendors, cloud operators, and procurement teams to build around a new assumption: the AI rack is now a liquid-cooled machine room component, not a server cabinet with heroic airflow.
The Facility Wall Is Where the Marketing Gets Convenient​
Nvidia’s claim becomes more fragile when it is stretched beyond the building. On-site cooling is only one slice of AI’s water demand, and some recent analyses put it far below the water associated with electricity generation and chipmaking. That does not make the cooling improvement trivial; it means the improvement is being made in the most visible slice, not necessarily the largest one.
Power generation is the first omitted layer. Thermal power plants, including coal, gas, and nuclear facilities, often withdraw and consume water as part of steam-cycle generation and cooling. The exact water intensity varies enormously by plant type, cooling method, region, and grid mix, but the basic point is not controversial: electricity is not water-free simply because the server hall is.
Semiconductor manufacturing is the second omitted layer. Advanced chips require ultrapure water in fabrication, and AI accelerators are among the most demanding products in the electronics supply chain. When Nvidia ships a Rubin platform, its water story began long before a contractor filled the coolant loop at the data center.
This is the uncomfortable truth behind AI infrastructure accounting. The cleanest story is usually the narrowest one. “Zero water cooling” is measurable, defensible, and valuable. “Zero water AI” is not.
The industry has played this perimeter game before with carbon. A company can buy renewable energy certificates, report lower operational emissions, and still depend on hardware supply chains with substantial embodied carbon. The same pattern is now emerging around water: direct consumption is being optimized first because it is visible, local, and easier to claim, while indirect water remains harder to measure and easier to bury in scope definitions.
Hotter Coolant Makes Geography Matter More, Not Less​
Warm-water cooling has a simple dependency: the outside world still exists. A dry cooler works best when ambient temperatures are comfortably below the coolant temperature. In Scotland, Scandinavia, the Pacific Northwest, or parts of northern Europe, a 45°C loop gives operators plenty of room for passive heat rejection across most of the year. In Phoenix, Dallas, or Singapore, the equation is less forgiving.
Nvidia has acknowledged that some climates may still require chillers for a small share of operating hours. That caveat is doing a lot of work. The difference between “almost never” and “often enough to matter” is not a philosophical dispute; it is a site-selection issue, an engineering issue, and eventually a permitting issue.
This is where the climate-week announcement collides with the geography of the AI buildout. Much of the United States data center boom is happening in regions where land, power interconnection, tax incentives, and fiber routes line up better than water availability. Those regions are not always the regions where dry cooling performs best.
The result is a paradox that local governments will notice quickly. The same design that makes AI data centers easier to defend in water-stressed places may be least able to deliver its cleanest water claims in the hottest of those places. A closed loop helps everywhere, but the promise of eliminating chillers is climate-dependent.
That does not make the technology unsuitable for hot regions. It means the headline number should travel with a weather map attached. A facility in a temperate climate and a facility in the desert may share the same Nvidia reference architecture while delivering very different real-world water and energy outcomes.
The AI Factory Is Becoming a Thermal Product​
Nvidia’s role in this story is unusual because the company is no longer just selling chips. It is selling an architecture for the AI factory, a full-stack concept that reaches from GPUs and networking into racks, power, cooling, software, and digital twins. DSX is part of that strategy.
This matters for adoption. A cooling paper from a university lab can be admired and ignored. A reference design from Nvidia, tied to the next generation of high-margin AI systems, becomes a procurement template. If cloud providers want the Rubin platform at scale, they will have strong incentives to adopt the supporting thermal assumptions.
That is why the HVAC market noticed. Chillers, cooling towers, pumps, controls, and mechanical systems are not side businesses in hyperscale construction; they are large capital line items with entrenched suppliers. If AI racks move decisively toward warm-water liquid cooling and dry heat rejection, a meaningful share of future data center mechanical spending shifts with them.
The change will not be instant. Existing facilities were not designed around 45°C coolant loops, and retrofitting them is harder than building new campuses around the assumption. Operators have to worry about serviceability, leak detection, materials compatibility, technician training, redundancy, and the awkward transitional years when air-cooled and liquid-cooled systems coexist.
Still, reference architectures have a way of becoming defaults when enough money sits behind them. Nvidia has the leverage to make liquid cooling less exotic by embedding it in the platform roadmap. Once that happens, the question for hyperscalers stops being whether liquid cooling is an experiment and becomes how quickly their construction pipeline can absorb it.
Communities Will Not Grade on Nvidia’s Perimeter​
Local opposition to data centers has become more sophisticated. Residents are no longer objecting only to noise, traffic, or the vague idea of “big tech” arriving at the edge of town. They are asking where the power comes from, who pays for grid upgrades, how much water is consumed, whether tax abatements are justified, and what happens during drought.
A near-zero on-site cooling design gives developers a better answer to one of those questions. It does not answer the rest. If a proposed AI campus needs a new gas plant, strains transmission capacity, or competes with local industrial and residential growth, the absence of cooling towers will not end the debate.
This is where Nvidia’s advance may change the politics without settling them. Opponents who focused heavily on direct water consumption will have to adapt if future projects can credibly show closed-loop cooling and minimal withdrawals. But developers will also lose the ability to treat water objections as uninformed if the broader water chain remains real.
For public officials, the lesson should be to require more granular disclosures, not to accept or reject data centers based on a single metric. Water-use effectiveness inside the facility is useful. So are annual withdrawal estimates, peak-day cooling assumptions, grid-source analysis, backup generation plans, and supply-chain reporting where available. The more infrastructure becomes essential to AI, the less credible it is to regulate it with brochure-level sustainability claims.
The best version of Nvidia’s announcement would push the permitting conversation upward. If on-site evaporative cooling can be designed out of many facilities, communities can move from arguing about yesterday’s cooling towers to arguing about tomorrow’s full-stack resource demand.
The Efficiency Trap Is Waiting in the Parking Lot​
There is another reason to be careful about celebrating efficiency as a straight environmental win. In computing, efficiency gains often enable more consumption rather than less. Cheaper compute tends to create new uses, new products, and new expectations that absorb the savings.
This is the classic Jevons-style problem, and AI is almost built to demonstrate it. If better cooling lowers operating costs, increases rack density, reduces permitting friction, and makes larger clusters easier to deploy, the industry is unlikely to respond by building the same amount of compute with fewer resources. It is more likely to build much more compute.
Nvidia knows this. The company’s business depends on the idea that AI demand will keep scaling, and its infrastructure language is explicitly growth-oriented. The goal is not a smaller AI footprint; it is a more deployable one.
That does not invalidate the cooling advance. Per-unit efficiency matters, especially when the alternative is a less efficient version of the same buildout. But the total environmental outcome depends on whether efficiency gains are swallowed by growth. A 100 percent reduction in one facility’s direct cooling water is impressive; a tenfold increase in facilities changes the accounting.
The industry’s preferred answer is that AI will eventually optimize everything else, from logistics to energy grids to scientific discovery. Maybe it will. But that claim cannot be used as a substitute for measuring the infrastructure being built now.
Microsoft, Google, and Amazon Show the Same Perimeter Fight​
Nvidia is not alone in trying to reframe the water issue around direct facility consumption. Microsoft has promoted new data center designs that rely on closed-loop cooling and sharply reduced annual water use. Google has committed to becoming water positive by 2030. Amazon has begun disclosing broader water-use figures and progress toward replenishment goals.
These commitments are not meaningless corporate varnish. They show that water has become a first-tier constraint, not an afterthought handled by facilities teams after the real decisions are made. The largest AI infrastructure buyers understand that communities and regulators are watching.
But the same perimeter problem appears across the sector. Replenishment projects may occur in different watersheds than the facilities creating demand. Closed-loop cooling may reduce direct withdrawals while electricity demand rises. Annualized water numbers may obscure peak local stress during heat waves or drought.
The industry’s next sustainability battle will be over whether these metrics become more precise or more theatrical. A company can disclose water-use effectiveness and still avoid giving residents a clear picture of local risk. It can promise replenishment and still build in a basin where timing, geography, and legal water rights matter more than global totals.
Nvidia’s DSX design should raise the bar for everyone. If the dominant AI hardware vendor can design around near-zero on-site water cooling, then future facilities that rely heavily on evaporative cooling will face tougher questions. But the bar must rise for indirect water too, or the industry will simply optimize the easiest-to-defend number.
Windows Users Are Not Spectators in This Infrastructure Story​
It may seem odd to discuss Nvidia’s data center cooling architecture on a Windows enthusiast site. Most readers are not building 100-kilowatt AI racks in their garages. But the AI infrastructure boom is already reshaping the hardware, software, and cloud services that Windows users touch every day.
Copilot features, cloud gaming, developer assistants, enterprise security tools, image generators, meeting transcription, and model-powered search all depend on data center capacity. When that capacity becomes more expensive, constrained, or politically controversial, the effects show up in product availability, pricing, regional rollout, and the way vendors package AI into operating systems and subscriptions.
For sysadmins, the issue is even more direct. Enterprises are being asked to adopt AI features across Microsoft 365, Windows management, endpoint security, CRM systems, observability platforms, and developer tooling. Those features carry hidden infrastructure assumptions. Procurement teams increasingly need to ask vendors not only about data residency and model training, but also about energy and water reporting.
Developers should care because infrastructure constraints shape platform behavior. If inference costs fall, software companies will add more AI calls to ordinary workflows. If costs rise or capacity tightens, vendors will gate features, degrade models, or push more workloads onto local NPUs. The thermal design of AI factories may seem remote, but it influences the boundary between cloud intelligence and client-side computing.
Security-minded readers should care because resilience is part of sustainability. A data center that depends on stressed water systems or fragile local power arrangements is not just an environmental story. It is an availability story. The same communities questioning water use today may be the ones deciding whether future expansions are approved, delayed, litigated, or blocked.
The DSX Shift Leaves Five Hard Facts on the Table​
Nvidia’s reference design deserves neither dismissal nor credulous applause. It is a consequential engineering move wrapped in a claim that becomes less true the farther it travels from the cooling loop. The practical reading is narrower and more useful.
  • Nvidia’s Vera Rubin DSX design can sharply reduce or nearly eliminate direct on-site water use for cooling in facilities and climates where dry coolers can do most of the work.
  • The claim does not include the water consumed through electricity generation, semiconductor fabrication, construction, or other supply-chain activity tied to AI infrastructure.
  • Warm-water liquid cooling is likely to become a mainstream requirement for high-density AI racks because air cooling is running out of practical headroom.
  • Site selection will determine how much of the promised water and energy savings survive contact with local climate, especially in hot or drought-stressed regions.
  • Efficiency gains may lower per-unit resource use while accelerating total AI buildout, so the system-wide water impact depends on growth as much as cooling technology.
  • Communities and enterprise buyers should demand facility-specific disclosures rather than accepting global “zero water” or “water positive” claims at face value.
Nvidia has not solved AI’s water problem, but it may have made one old version of that problem obsolete. That is progress, and it is also a warning. As AI infrastructure becomes more efficient, denser, and easier to build, the industry’s accountability has to expand beyond the server hall rather than shrink to fit the marketing claim.
  1. AI Data Center Water Use Is Not Solved: Nvidia’s Cooling Fix Stops at the Walls Tech Times 2026-06-26T03:20:20.158159
Nvidia is promoting a Rubin-generation, fully liquid-cooled data center reference design in June 2026 that it says can nearly eliminate water use inside AI facilities by replacing evaporative cooling with closed-loop warm-water systems around chips, racks, and networking gear. The claim is technically meaningful, but it is also carefully bounded. Nvidia is solving the water problem that facility operators can photograph, meter, and put in a sustainability deck. The larger water burden of AI increasingly sits outside the fence line, in the power system that feeds the machines.
Futuristic data center with glowing copper pipes and a city skyline, monitored by engineers in a control room. Nvidia Has Built a Better Pipe, Not a Smaller Thirst​
The Rubin cooling story is an engineering story first. Nvidia is pushing AI infrastructure toward direct-to-chip liquid cooling, where coolant moves heat away from CPUs, GPUs, networking components, and other rack-scale systems without relying on the big evaporative cooling towers that have made data centers such visible water consumers.
That matters because the old model is running into physics and politics at the same time. AI racks are too dense for traditional air cooling to handle gracefully, and the communities asked to host those facilities are increasingly unwilling to accept vague promises about “efficiency” while watching local water and power demand climb.
The Rubin-era design also fits Nvidia’s broader strategy. The company no longer sells only chips; it sells a template for the AI factory — silicon, networking, racks, software, and now cooling philosophy. If Nvidia can persuade operators that its reference design is not merely faster but easier to permit, finance, and defend publicly, it strengthens the entire market for its hardware.
But the water claim needs a hard boundary around it. Closed-loop liquid cooling can sharply reduce or even eliminate routine on-site water consumption for cooling. It does not eliminate the water consumed to generate electricity, nor does it erase the water embedded in chip manufacturing, construction, and the rest of the AI supply chain.
The Cooling Tower Was the Visible Villain​
The reason Nvidia’s announcement lands is that cooling towers are easy to understand. They spray water into air, lose some of it to evaporation, and make a data center’s water use look like exactly what it is: industrial consumption at community scale.
In a conventional large facility, cooling can be a major part of the non-compute energy and water burden. Operators have spent years improving power usage effectiveness, but AI’s density has changed the equation. A rack full of accelerators is not just another server cabinet; it is a heat source that forces the building around it to evolve.
Direct liquid cooling attacks that problem at the source. Instead of cooling the entire room aggressively enough to keep chips happy, the system moves heat directly from the components that produce it. Running warmer coolant also changes the economics, because heat can be rejected more efficiently and with less dependence on chillers or evaporative systems.
That is the legitimate part of Nvidia’s pitch. If a new AI campus can avoid consuming millions of gallons of local water each year for cooling, nearby residents should care. In water-stressed regions, that difference can be the line between a project that compounds a local scarcity problem and one that at least reduces its most obvious demand.
The Water Moves Upstream​
The catch is that AI data centers do not run on coolant. They run on electricity, and electricity often carries a water footprint of its own.
In much of the United States, the grid still includes thermoelectric power generation: natural gas, coal, and nuclear plants that use heat to make steam and water to manage that heat. The water consumed or withdrawn at those plants does not appear on the data center’s water meter, but it is still part of the environmental cost of running the workload.
That distinction is where the public conversation often becomes slippery. A company can truthfully say that a facility uses little or no water on site while the electricity it buys increases water demand somewhere else. The boundary of the claim is not false, but it is incomplete.
This is why researchers separate direct and indirect water use. Direct water is what the facility consumes for cooling and humidification. Indirect water is tied to power generation. A serious accounting of AI’s footprint has to include both, even though only one is under the data center operator’s immediate physical control.
The Grid Is Now Part of the Data Center​
For years, data center sustainability was discussed as a building-efficiency problem. Better airflow, better server utilization, better cooling, better power conversion. That framing made sense when the question was whether a facility wasted energy internally.
AI has made that frame too small. The new constraint is not just whether a building uses power efficiently, but whether the regional grid can supply enormous loads without leaning on dirtier, thirstier, or more expensive generation. A hyperscale AI campus is not merely a tenant of the grid; in some regions, it becomes one of the grid’s defining customers.
That is why the upstream water issue is not an academic footnote. If a data center locates in a region where marginal power comes from water-intensive thermal generation, the indirect water cost can be substantial. If it locates where incremental power comes from wind, solar, or other lower-water sources, the footprint changes dramatically.
This also complicates corporate claims about renewable energy. Buying renewable energy credits or matching annual consumption with clean energy procurement is not the same as ensuring that every hour of AI computation is powered by low-water, low-carbon generation. The accounting may be defensible, but the physical grid may tell a messier story.
Nvidia’s Incentive Is to Make the Factory Permittable​
Nvidia has every reason to make AI infrastructure look less environmentally explosive. The company’s growth depends not just on GPU demand but on the ability of cloud providers, enterprise buyers, and specialized AI operators to build enough physical capacity to deploy those GPUs.
That capacity is becoming politically harder to obtain. Communities have pushed back against data centers over land use, transmission upgrades, diesel backup generators, noise, tax incentives, and water draw. In that environment, cooling technology becomes part of a permitting argument.
A closed-loop design gives operators something concrete to show regulators and residents. It says: this facility is not a traditional water-hungry server farm. It can reduce local water stress. It is engineered for the next generation of compute rather than retrofitted around yesterday’s assumptions.
That argument may be true as far as it goes. But it can also become a convenient substitution. The question “How much water will this building consume?” is important. The question “What power plants will run harder because this building exists?” is harder, and therefore easier to omit.
Liquid Cooling Is Becoming the Price of Admission​
The other reason this announcement matters is that liquid cooling is no longer a niche high-performance computing feature. It is becoming the expected infrastructure layer for dense AI.
Rubin pushes that transition further because Nvidia’s platform ambitions are rack-scale. The company is designing systems where accelerators, CPUs, networking, and interconnects behave less like discrete server parts and more like a single machine spread across racks. That machine produces heat in patterns that reward integrated cooling.
For operators, this is not a trivial upgrade. Liquid cooling changes facilities, maintenance practices, procurement, and risk models. It introduces coolant distribution units, leak detection, water chemistry concerns, service procedures, and new dependencies between IT hardware and mechanical systems.
Still, the direction is clear. Air cooling is struggling to keep pace with AI rack densities. The more Nvidia defines the reference architecture, the more the rest of the ecosystem — colocation providers, power vendors, building designers, and enterprise infrastructure teams — must adapt around it.
The Sustainability Debate Is Becoming More Honest​
There is a useful correction happening in the public debate. A few years ago, AI’s environmental story was often reduced to abstract carbon numbers or dramatic claims about a single prompt using a certain amount of water. Those comparisons were catchy, but they blurred the system boundaries.
The better conversation now asks where the water is consumed, when the electricity is used, and what generation sources respond to the demand. That is a more complicated story, but it is also more honest. AI infrastructure is not one machine in one building; it is a chain of dependencies from chip fabs to substations to power plants to cooling loops.
Nvidia’s cooling design belongs in that chain as a genuine improvement. It reduces one category of water use, and in some locations that category matters enormously. A data center in a water-stressed county that avoids evaporative cooling is better than one that does not.
But the improvement does not justify calling the broader water challenge solved. The most generous reading is that Nvidia has addressed the most visible and locally contentious piece of the problem. The least generous reading is that the company has given the AI industry a sharper talking point while leaving the bigger accounting fight for someone else.
Communities Will Judge the Whole Machine​
For residents near proposed data centers, the distinction between on-site and off-site water can feel like bookkeeping. They care whether the project strains local resources, raises utility costs, requires new transmission, or locks the region into infrastructure choices they did not ask for.
That is why data center opposition has become more sophisticated. Communities are no longer asking only whether a building will use too much water. They are asking where the electricity comes from, whether backup generators will run, whether tax incentives are justified, and whether the jobs promised match the scale of public burden.
Nvidia’s design helps operators answer one of those questions. It does not answer the rest. A low-water facility powered by a stressed grid can still be a hard sell, especially if the benefits flow to a hyperscaler while the infrastructure costs are socialized through local planning fights and utility bills.
The companies that fare best will be the ones that stop treating sustainability as a narrow facilities metric. They will need to explain their power procurement, their hourly energy matching, their water accounting, and their impact on regional infrastructure in language that survives contact with public meetings.
The AI Industry Needs Better Accounting Than “Zero Water”​
The phrase “zero water” is powerful because it is simple. It is also dangerous because infrastructure is rarely that simple.
A closed-loop cooling system may require little routine water replenishment, but the facility still exists inside a water-consuming economy. Its power may come from plants that withdraw and consume water. Its chips were manufactured through water-intensive processes. Its construction required materials with their own environmental footprints.
This does not make Nvidia’s claim worthless. It makes precision essential. The industry should say “zero on-site cooling water” when that is what it means. It should not let audiences infer “zero water footprint” unless the entire chain can support that claim.
For IT pros and WindowsForum readers, this distinction is familiar from another world: moving a workload to the cloud does not make infrastructure disappear. It changes who operates it, where it sits, and how its costs are accounted for. AI water use follows the same pattern.
Rubin’s Cooling Win Leaves the Hardest Questions Standing​
Nvidia’s announcement should be read as a sign that the AI buildout is entering a more industrial phase. The early frenzy was about model size, GPU scarcity, and benchmark leadership. The next phase is about power, cooling, siting, and public legitimacy.
That shift is healthy. It means the industry is being forced to confront the physical reality behind software that often presents itself as weightless. Every chatbot response, code completion, image generation, and enterprise inference job runs through a chain of machines that must be powered and cooled.
The practical lessons are narrow but important:
  • Nvidia’s Rubin-era liquid cooling design can materially reduce the water consumed inside AI data center buildings.
  • The design does not eliminate indirect water use from electricity generation, which may be a larger share of AI’s total water footprint in many regions.
  • Local communities may benefit from lower on-site water demand, especially where evaporative cooling would otherwise compete with scarce supplies.
  • Regulators and planners should ask for both direct and indirect water accounting before accepting broad sustainability claims.
  • The real test will be whether AI operators pair liquid cooling with cleaner, lower-water power procurement rather than using cooling gains as a marketing shield.
Nvidia has made the AI factory less dependent on the local tap, and that is a real achievement. But the next fight will be over the grid behind the factory, not the pipes inside it. If AI companies want to claim that their infrastructure is sustainable, they will have to prove that the water did not merely disappear from the campus tour and reappear at a power plant down the line.
