The Surface Laptop Ultra reviews are landing, and the broad verdict is one Microsoft has to be happy with. Gizmodo calls it Microsoft's best laptop yet. Wired says it is probably the best laptop you can buy that isn't a MacBook Pro. Windows Central puts it among the most capable Windows laptops it has ever tested. The RTX Spark platform is real, the mini-LED display is genuinely bright, and the local AI story checks out.
But early hardware always has a shakedown period, and one review catalogued the quirks in unusual detail. The Verge's Tom Warren published "Surface Laptop Ultra review: a different kind of MacBook Pro" this week, and alongside a positive overall verdict it lists three early-adopter quirks: loud pops from the speakers, display lag and ghosting, and a battery meter that drops the moment you unplug. I want to walk through all three, because two of them have workarounds and the third turns out not to be a bug at all.
First, the framing matters. This is one reviewer's experience on one unit, not a confirmed defect wave. The speaker pops in particular have not been reported on other review units so far. The review itself is positive overall. Read this as a field report from the first week of a brand new platform, not as a reason to cancel an order.
Quirk one is the strangest. The reviewer reports loud pops and bangs from the built-in speakers, loud enough to sound like firecrackers. The first time it happened, the honest assumption was that the battery was failing. It turned out to be speaker interference. Rebooting the laptop fixed it, but it has recurred a couple of times since.
That is worth paying attention to for two reasons. The first is that nobody else has reported this exact symptom yet, which keeps it in "watch this space" territory rather than "known issue" territory. The second is that Gizmodo's Raymond Wong independently noticed something adjacent in his review week: a distracting scratching sound from the speakers when loading games or trying to listen to a Microsoft Teams call. A scratch is not a firecracker bang, and I am not going to claim they are the same fault. But two reviewers hearing odd things from the speakers of a first-generation machine is a pattern worth naming. The side vents on this laptop double as speaker openings and exhaust outlets, which is clever thermal design, and also means the audio path shares real estate with moving air and hot components. Whether that has anything to do with the interference is speculation. What is concrete is the workaround: a reboot cleared it on the affected unit.
If you get a unit and hear it, reboot first and note whether it comes back. If it recurs, that is worth reporting to Microsoft through the Feedback Hub with the exact circumstances, because intermittent speaker interference on a $2,599-plus machine is the kind of thing that gets fixed in firmware if the reports are specific enough.
Quirk two is the display. The reviewer ran into moments where the screen felt slightly laggy or showed noticeable ghosting, with a visible trail left behind when moving a window around rapidly. Two things helped. Switching the power settings from the default "best power efficiency" mode to "best performance" fixed most of the laggy feeling. And the backlight ghosting grew less noticeable the longer the laptop ran.
There is useful context here from a second independent review. Digitalcitizen.life's review of the same machine notes that the 15-inch mini-LED panel, with its 1,344 local dimming zones and 2,000-nit peak HDR brightness, can show a subtle ghosting effect of its own: the backlight can take a fraction of a second to adjust when bright windows move across dark areas. That is a known characteristic of local-dimming backlights with a limited zone count, not a defect, and it is a different mechanism from the lag the first reviewer saw in power-efficiency mode.
So there are really two display behaviors bundled into one quirk report. The lag is a power-mode behavior, and the fix is one settings change. The ghosting is partly the panel's local-dimming response, which is physics, and partly something that faded with use on the review unit. Neither sounds like a reason to avoid the machine, but both are worth knowing before you judge the display in a store demo running the default efficiency profile. Flip it to best performance before you form an opinion.
Quirk three is my favorite, because it is not a quirk at all. The reviewer unplugged the charger at a reported 100 percent, and Windows immediately showed 97 percent. Plug it back in, back to 100, unplug again, straight back to 97. Naturally this looked like a faulty battery gauge, so the reviewer asked Microsoft. Microsoft spokesperson Moses Nsereko confirmed on the record that the behavior is by design: "the device pauses charging rather than constantly topping off, and resumes only once the level drops to 95 percent." The reasoning is battery longevity, since holding a lithium cell at a constant 100 percent with a trickle charge accelerates wear. While plugged in, the indicator shows 100 percent to signal a full charge; the moment you unplug, it shows the battery's exact level, which may sit a few percent lower.
This is the industry converging on the same answer. Phone makers have shipped adaptive charging for years, and Apple has its optimized charge limit. Microsoft just implemented it with unusual transparency about the gap between the plugged-in indicator and the real level. If your unit does the 100-to-97 dance, your battery is fine. It is doing exactly what it was told to do.
Stepping back, what does this add up to? A first-generation platform with first-generation quirks, all of them manageable. It helps to remember how much is new at once here. The RTX Spark N1X is a brand new chip collaboration between NVIDIA and MediaTek. The mini-LED panel is Microsoft's first in a Surface device. The magnetic USB-C charging is a new connector design. When a laptop debuts a new processor platform, a new display technology, and a new charging system simultaneously, a short list of behavioral quirks in week one is the normal price of being early, not a sign of a troubled product. The mature move is exactly what happened here: document them, find the workarounds, and watch whether they persist.
The battery behavior is intentional and documented. The display lag has a one-click workaround in the power settings, and the ghosting is partly inherent to the mini-LED backlight design. The speaker pops are the only one I would actually watch, because they are the only one without a second data point or a satisfying explanation, and intermittent audio faults are exactly the kind of thing that either gets fixed in a firmware update or turns out to be a bad unit.
None of this changes the shape of the reviews. The consistent take across the press is that this is a serious machine with real tradeoffs: a high price, an ARM platform that still leans on emulation for some software, and a display that is very bright without being best in class. The quirks sit underneath that verdict, not on top of it. I would still call this a positive launch week for the platform.
For prospective buyers, the practical version is short. If the display feels laggy out of the box, check the power mode before you judge it. If the speakers pop, reboot, and if it keeps happening, file detailed feedback so Microsoft can trace it. And if the battery reads 97 percent the second you unplug at "full," relax. That one is a feature.
I will keep an eye on whether the speaker issue shows up on other units. If it does, that becomes a different story. For now, file it under early-adopter trivia, and enjoy the machine.
Correction (October 17, 2026): This article originally attributed the quoted Surface Laptop Ultra review to Techiemag.co.uk; it was actually published by The Verge, written by Tom Warren.
