Windows desktop settings and registry editor showing a warning about changing the Desktop folder location.
If Windows system folders suddenly appear on the desktop, the key distinction is this: did Explorer merely start showing hidden items, or is Windows treating the wrong folder as your Desktop? In the WindowsForum case, the answer was the second one. The confirmed fix was to recreate the missing Desktop shell-folder registry entries so the Desktop pointed back to the user profile, not to remove the folders from the desktop.
That distinction matters because the danger is conditional. A folder named Windows, Program Files, Users, ProgramData, Recovery, PerfLogs, or similar is not dangerous because it is visible. It is dangerous to delete if it is visible because the Desktop location points to C:\ or another system-level location. In that situation, the “desktop icons” may be real system folders being shown through the wrong Desktop path.
What the WindowsForum thread actually showed​
The WindowsForum thread was titled “System files in File Explorer showing up on desktop.” Member davercrb2 opened with a specific report, not a vague complaint about desktop clutter: Windows system files were appearing on the desktop; File Explorer showed “three folders with backslashes” that looked like the culprit; attempts to remove them had failed; turning hidden folders back off hid only some items; and the user had deliberately avoided physically deleting them because they did not look like normal aliases or shortcuts.
That last detail was the right instinct. The helper’s first read of the screenshot was that the Desktop location appeared to have been redirected to the root of C:\. If that was true, Explorer was not inventing icons. It was showing real folders from the root of the system drive, including folders such as Windows, Program Files, Users, ProgramData, and Recovery. The helper therefore warned the user not to delete them and directed the diagnosis toward the Desktop location.
The first repair attempt followed the normal graphical path: open File Explorer, right-click Desktop, choose Properties, open the Location tab, and check whether the location was something like C:\ instead of the user’s Desktop folder. The helper also gave the important restoration warning: if Windows asks whether to move files from the old location to the new location, choose No when the “old location” is a system root. Moving C:\Windows or C:\Program Files into a Desktop folder would not be a cleanup step.
After those steps, davercrb2 reported that “those three folders are still there.” That moved the case from a simple Location-tab reset to a registry/path check. The helper then asked whether the remaining folders came from the current user’s Desktop, the Public Desktop, or a still-misdirected Desktop known-folder path. When PowerShell would not open, the helper switched to Command Prompt. When the user ran the registry query, the error was direct: “The system was unable to find the specified registry key or value.” The helper interpreted that as a missing Desktop registry value and gave commands to recreate it.
The final Desktop fix was the command-line recreation of the Desktop entries under the current user’s Explorer shell-folder keys. After that step, davercrb2 replied: “Looks like that last one did it. The folders are gone.” A later follow-up reported that the desktop looked OK, and after the thread continued into a related PowerShell startup issue, the user ultimately confirmed everything was stable.
The observed facts are therefore separate from the interpretation:
  • Observed by the user: System-looking folders appeared on the desktop; three path-like folders remained; hiding hidden folders helped only partly; deletion/removal attempts failed; the user did not delete the objects.
  • Inferred by the helper: The Desktop location was probably wrong, possibly pointed at C:\, and later the missing registry value suggested corrupted or missing user shell-folder entries.
  • Confirmed by the outcome: Recreating the Desktop shell-folder registry entries made the folders disappear from the desktop.
Why the hidden-files toggle was not enough​
The hidden-items setting was still a valid first check. Microsoft’s File Explorer guidance describes hidden files as a normal view option: in Windows 11, View > Show > Hidden items controls whether hidden files and folders are shown; Windows 10 exposes the comparable setting through File Explorer options. That explains why some hidden metadata or normally hidden folders may appear after a view setting changes.
But in this WindowsForum case, that setting was only a partial explanation. Davercrb2 reported that hiding hidden folders removed some items but not all. That was the diagnostic break.
If a visibility setting is the whole problem, turning the setting off should remove the unexpected objects from view. If system-looking folders remain, especially when they resist removal and look like mirrored folders rather than shortcuts, stop treating the case as a display preference. At that point, the question becomes: which folder is the Desktop actually showing?
That is why the thread did not end with “turn off hidden items.” The helper moved from appearance to origin.
The expected Desktop locations​
Microsoft’s KnownFolderID documentation gives the baseline expectation: the per-user Desktop known folder, FOLDERID_Desktop, has the default path %USERPROFILE%\Desktop. The Public Desktop known folder, FOLDERID_PublicDesktop, is separate and has the default path %PUBLIC%\Desktop.
Those defaults do not prove what happened on a specific PC. They simply define what “normal” looks like. The WindowsForum evidence came from the thread itself: the helper suspected the Desktop was pointed at the wrong place, the registry query reported a missing value, and recreating the Desktop entries resolved the visible folders.
For practical troubleshooting, that means you do not need to begin with GUIDs. You need to answer three plain questions:
  1. Is the current user Desktop really %USERPROFILE%\Desktop?
  2. Is anything unexpected coming from the Public Desktop?
  3. Do the current user registry entries for Desktop exist and point where they should?
The decision path​
Use this order. Stop when the evidence explains the symptom.
Decision pointWhat it meansNext step
Hidden items are enabled and all unexpected items disappear when disabledThe issue was probably cosmetic visibilityLeave hidden items off unless you need them
Hidden items are disabled but system-looking folders remainVisibility was not the whole issueInspect the Desktop source path
The visible folders include names like Windows, Program Files, Users, or ProgramDataThe Desktop may be showing a system-level locationDo not delete; check the Desktop location
Desktop Properties shows C:\ or another unexpected locationThe Desktop path is wrongRestore the default location, but do not move system-root contents
The Desktop registry value is missing or points wrongWindows may not know the correct Desktop pathRecreate the Desktop shell-folder entries
Items are not in the user Desktop but are in the Public DesktopThey are shared desktop itemsTreat them as all-user items, not single-user clutter
The path points into OneDrive, a redirected folder, or a managed profileSync or policy may be involvedInvestigate that layer after confirming the path
This is the compact version of the WindowsForum helper’s logic. The thread did not say “never delete system folders” as a generic slogan. It said not to delete them while the Desktop may be pointed at C:\ or another wrong location, because then the visible entries are likely real system folders.
Step 1: Normalize visibility, then stop toggling​
First, put File Explorer back into a normal view state.
In Windows 11:
  1. Open File Explorer.
  2. Select View.
  3. Select Show.
  4. Make sure Hidden items is off unless you intentionally need it.
In Windows 10:
  2. Open Options or Change folder and search options.
  3. Use the View tab to control hidden files and folders.
Now reassess.
If everything unexpected disappears, the issue was probably a visibility setting. If only some items disappear, follow the WindowsForum path: stop changing view options and inspect the Desktop location.
Step 2: Check whether Desktop points somewhere abnormal​
The first helper response in the WindowsForum thread focused on the Desktop Location tab because it is the safest non-registry check.
Open File Explorer and inspect the Desktop folder:
  2. In the left pane, right-click Desktop.
  3. Choose Properties.
  4. Open the Location tab if it is present.
  5. Check the path.
The expected ordinary user location is a Desktop folder inside the user profile, such as:
C:\Users\<your-user-name>\Desktop
or, in environment-variable form:
If the Location tab shows:
C:\
or another broad system location such as:
C:\Users
C:\Windows
C:\Program Files
then that is the main finding. Explorer may be showing you the contents of that folder as the desktop.
If you use Restore Default, be careful with the move prompt. In the WindowsForum thread, the helper specifically warned not to move the old location’s contents if the old location was C:\. In that scenario, choose No if Windows asks whether to move files from the old location to the new one. You want to restore the Desktop pointer, not relocate the system drive into the Desktop folder.
Step 3: Check the registry entries the thread used​
When the Location-tab approach did not clear the last three folders, the thread moved to the registry values used by Explorer for the current user’s shell folders.
The two keys checked in the WindowsForum thread were:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
and:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
The value being checked was named:
Desktop
The helper expected the User Shell Folders value to point to:
and the Shell Folders value to point to the actual expanded Desktop path for that user.
If you are comfortable using Command Prompt, the thread’s diagnostic query was:
reg query "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders" /v Desktop
reg query "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders" /v Desktop
In davercrb2’s case, the important result was not a wrong path but an error stating that Windows could not find the specified registry key or value. The helper treated that as a missing Desktop registry value and recreated it.
Step 4: Recreate the Desktop entries if they are missing or wrong​
This is the step that fixed the visible desktop problem in the WindowsForum thread.
From Command Prompt, the helper first ensured the Desktop folder existed:
mkdir "%USERPROFILE%\Desktop"
Then the helper recreated the per-user Desktop value under User Shell Folders:
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders" /v Desktop /t REG_EXPAND_SZ /d "%USERPROFILE%\Desktop" /f
Then the helper recreated the Desktop value under Shell Folders:
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders" /v Desktop /t REG_SZ /d "%USERPROFILE%\Desktop" /f
Because that command is run from Command Prompt, %USERPROFILE% is expanded before the REG_SZ value is written. The practical result is that the value points to the user’s actual Desktop path.
Then restart Explorer:
taskkill /f /im explorer.exe
start explorer.exe
If Explorer restarts but the desktop still looks wrong, restart Windows.
In the thread, this was the decisive Desktop repair. After this “last one,” davercrb2 reported that the folders were gone.
Step 5: Check the Public Desktop only if the user Desktop does not explain it​
The helper’s follow-up did not jump randomly to every possible Explorer feature. It asked whether the remaining objects were coming from the user Desktop, the Public Desktop, or a still-wrong known-folder path.
That Public Desktop branch is legitimate because Windows can show items from the shared desktop location to users. Microsoft’s KnownFolderID table documents the Public Desktop as a separate common folder with the default path:
%PUBLIC%\Desktop
A typical expanded path is:
C:\Users\Public\Desktop
Check it only after the user Desktop path does not explain the remaining items:
  1. Press Win + R.
  2. Enter:
  1. Look for the same folders or shortcuts there.
If the items are in the Public Desktop, they may affect all users on the PC. Do not treat them as ordinary personal desktop clutter. If they are system-folder names, keep the same rule: do not delete until you know whether they are real folders, shortcuts, junctions, or artifacts of a wrong location.
Why “folders with backslashes” mattered​
Davercrb2’s phrase “three folders with backslashes” was an important clue. Backslashes are path separators in Windows. A normal folder name on the desktop usually is not described that way by a user unless the item looks path-like, is displaying a target, or is being surfaced through an unusual namespace or location problem.
The safe response is not “delete the three folders.” The safe response is:
  1. Open the item’s Properties.
  2. Look for Location, Target, or path fields.
  3. Compare them with the expected user Desktop path.
  4. Check the Public Desktop if the user Desktop does not contain the item.
  5. Repair the Desktop path before removing anything.
In the WindowsForum case, the strongest evidence was not the word “backslashes” alone. It was the combination: path-like items, failed removal attempts, partial hidden-items improvement, suspected Desktop redirection, missing Desktop registry value, and successful repair after recreating the Desktop entries.
Where OneDrive and folder redirection fit​
OneDrive, folder backup, enterprise redirection, and managed profiles can all affect where Desktop content lives. But they should not be inserted into this case unless the path evidence points there.
Use them as follow-up branches:
  • If the Desktop path is under OneDrive, check OneDrive backup and sync behavior.
  • If the Desktop path is a network or managed location, check policy or profile redirection.
  • If deleted items return after sync, check the sync provider.
  • If the same desktop contents appear on multiple signed-in PCs, check cloud or profile synchronization.
In the WindowsForum thread, the confirmed Desktop fix was local shell-folder repair. The article should not turn that into a general OneDrive warning without evidence.
What the later PowerShell symptom adds​
After the desktop folders disappeared, davercrb2 raised a second issue: PowerShell opened and immediately closed. That was not the original desktop symptom, but the later thread history is useful because it supported the helper’s broader suspicion that user shell-folder values were damaged or missing.
The helper first checked whether PowerShell failed because of a profile script, module path, or environment problem. Eventually the diagnosis returned to user shell-folder paths such as Documents, AppData, and Local AppData. After those related shell-folder paths were recreated, the user reported that PowerShell stayed open. Later, davercrb2 said everything looked stable after the repairs and a restart.
That does not mean every desktop-folder case is a PowerShell case. It means this particular thread ended with a coherent explanation: more than one user shell-folder setting appeared damaged, and restoring those paths stabilized both the Desktop behavior and the later PowerShell startup issue.
For the desktop article, the takeaway is narrower: the visible system folders were not fixed by deleting folders or toggling view settings. They were fixed by restoring the Desktop shell-folder path.
The exact troubleshooting sequence to extract​
Here is the concise workflow, stripped to the decision points used in the thread.
1. Hide hidden items and reassess​
If the unexpected items vanish, stop. It was likely a visibility setting.
If only some vanish, continue.
2. Confirm whether the Desktop points to the user profile​
Expected:
Suspicious:
C:\
C:\Users
C:\Windows
C:\Program Files
If the Desktop points at a suspicious location, restore the default Desktop location. If prompted to move files from a system root, choose No.
3. Query the Desktop registry values​
Use:
If either value is missing or points somewhere abnormal, that is no longer a cosmetic Explorer problem.
4. Recreate the missing Desktop value​
Use Command Prompt:
start explorer.exe
Restart Windows if needed.
5. Check the Public Desktop only if needed​
Open:
If the same objects are there, they may be shared desktop items.
6. Only then remove anything​
Remove only items you have confirmed are ordinary files or shortcuts in the correct Desktop location. Do not delete system-named folders if the Desktop path is still wrong or unresolved.
What not to do​
Do not keep toggling Explorer settings after hidden items are already off and the folders remain. That was the point where the WindowsForum case moved away from view settings.
Do not assume the desktop surface tells you the object’s real origin. Desktop content can come from the current user Desktop, the Public Desktop, or a redirected/misconfigured known-folder path.
Do not delete folders named like Windows system folders while the Desktop might be pointed at C:\. If the Desktop path is wrong, deletion is not acting on “desktop clutter”; it may be acting on the system drive.
Do not blame an Explorer update or a general explorer.exe reliability issue unless the symptom is actually Explorer freezing, crashing, failing to draw the taskbar, or showing other shell reliability failures. This case was about content origin, not Explorer responsiveness.
The clean conclusion​
The WindowsForum thread resolved because the helper followed the evidence in order. Hidden-items settings explained only part of what davercrb2 saw. The remaining folders, especially the three path-like folders that resisted removal, pointed to a Desktop source-path problem. The registry query then exposed the concrete failure: the Desktop value was missing or not available where expected. Recreating the current user’s Desktop entries under User Shell Folders and Shell Folders, ensuring %USERPROFILE%\Desktop existed, and restarting Explorer made the folders disappear.
That is why the earlier visibility tweak was insufficient. It could hide files that were merely being displayed because of a view setting. It could not repair a missing or corrupted Desktop shell-folder value. The confirmed fix was not cosmetic; it restored where Windows looked for the user’s Desktop.
  1. Windows System Folders Showing on Your Desktop: Hidden Files vs. a Broken Desktop Shell-Folder Path learn.microsoft.com
  2. support.microsoft.com support.microsoft.com
