AceInfinity
Microsoft MVP
Probably one of the most advanced games I've tried recreating. I don't make a lot of games, but the logic here on a matrix was a little convoluted through the development stages.
What I mean by fully integrated logic is that the control itself does absolutely everything for you. You can basically take this control, build it, and place it within your program immediately to start playing Reversi.
There might be some issues I haven't seen yet, but it seems to work fine. I finished this early in the morning, but the only issue I have come across (and one I knew about because it was my list of todo's the whole time), is that when a play can't be made, it does not skip to the other person's turn like it is supposed to. This is an easy fix though.
By the time you get to this stage, you probably will only have maybe 10 empty spaces on the board at most. Just loop through all of the empties and see if it's a possible move, and if none are found then skip to the next user. If the next user can't play, then the game is done probably.
Usually you'll get to the point where all of the tiles are occupied though (80% of the time).
I've seen the standard for this game is an 8x8 grid, but the way I've programmed it, If you don't add it via the designer, you can have as large of a grid as you want. (I was playing with 25x25 before no problem.)
Unless you change the default constructor to chain to the second constructor with different values than 8 and 8.
Preview: Reversi Program - Developed by AceInfinity - YouTube
Earlier Images (through the progress):
Code: [C#] Reversi Game - Pastebin.com
// Developed by AceInfinity (c) Tech.Reboot.Pro 2013
// Reversi Game
// OBJECTIVE:
// The objective of this game is to own more pieces than your opponent by the time the game is finished.
// The game is over when the board is fully filled in, or neither player can make a move.
// RULES:
// Each reversi piece has a red side and a blue side. Player1 will be red, and Player2 will be blue here.
// You must place the piece so that an opponent's piece is sandwiched between 2 of your pieces including the
// piece you just played for that turn. All of the opponent's pieces between that newly placed piece and the
// pre-existing piece of your own, become your own pieces and change to your Player's color.
// You can only place a piece on an empty tile. If you cannot make a legal move, you have to pass your turn,
// and allow your opponent to make a move instead. You can capture vertical, horizontal, and diagonal paths of pieces.
// You can also, capture more than one path of your opponents pieces at once with a good move.
using System;
using System.ComponentModel;
using System.Collections.Generic;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Windows.Forms;
namespace Reversi
    class ReversiBoard : PictureBox
        #region // Constructors
        public ReversiBoard() : this(new ReversiLayout(8, 8)) { }
        public ReversiBoard(ReversiLayout layout)
            _layout = layout;
            // Default Initialization
            _borderColor = Color.FromArgb(255, 50, 50, 50);
            _tileColor = Color.FromArgb(255, 25, 25, 25);
            _player1Color = Color.FromArgb(255, 255, 25, 25); // Red
            _player2Color = Color.FromArgb(255, 25, 150, 255); // Blue
            _markers = new ReversiPlayer[_layout.Columns, _layout.Rows];
            this.Size = new Size(_layout.Columns * _tileSize, _layout.Rows * _tileSize + _paddingBottom);
            _faintCollection.ListChanged += new ListChangedEventHandler((sender, e) => this.Invalidate());
            NewGame();
        #endregion
        #region // Fields & Properties
        private ReversiLayout _layout; // Stores board layout information
        private Coordinates _lastCoordinates; // Keeps track of last coordinate for efficient checking
        private const int _tileSize = 25; // Constant tile size for game board
        private const int _paddingBottom = 15; // Constant for extra information at bottom (score)
        private ReversiPlayer[,] _markers; // Player markers for game board
        private BindingList<Marker> _faintCollection = new BindingList<Marker>(); // For hover image on valid locations
        private ReversiPlayer _currentPlayer = ReversiPlayer.Player1; // Current player to take his/her turn
        private Coordinates _targetCoordinates; // Represents the target coordinate for the flips
        private int _player1MarkerCount; // Represents the target coordinate for the flips
        private int _player2MarkerCount; // Represents the target coordinate for the flips
        /// <summary>
        /// Game tiles border color.
        /// </summary>
        private Color _borderColor;
        public Color BorderColor
            get { return _borderColor; }
            set { _borderColor = value; }
        /// <summary>
        /// Game tiles back color.
        /// </summary>
        private Color _tileColor;
        public Color TileColor
            get { return _tileColor; }
            set { _tileColor = value; }
        /// <summary>
        /// Player1's marker color.
        /// </summary>
        private Color _player1Color;
        public Color Player1Color
            get { return _player1Color; }
            set { _player1Color = value; }
        /// <summary>
        /// Player2's marker color.
        /// </summary>
        private Color _player2Color;
        public Color Player2Color
            get { return _player2Color; }
            set { _player2Color = value; }
        public bool GameFinished
            get
                bool boardComplete = true;
                for (int i = 0; i < _layout.Columns; i++)
                    for (int j = 0; j < _layout.Rows; j++)
                        if (_markers[i, j] == ReversiPlayer.None)
                            goto BoardNotComplete;
                if (boardComplete)
                    return true;
            BoardNotComplete:
                // Board was found incomplete so let's check if any moves can still be made
                return false;
        #endregion
        #region // Overrides
        /// <summary>
        /// Paints the board visual with all the player markers and current player indicator.
        /// </summary>
        /// <param name="pe">PaintEventArgs.</param>
        protected override void OnPaint(PaintEventArgs pe)
            base.OnPaint(pe);
            Graphics g = pe.Graphics;
            g.SmoothingMode = SmoothingMode.AntiAlias;
            // Paint the grid
            SolidBrush sb = new SolidBrush(_borderColor);
            Pen p = new Pen(sb);
            HatchBrush hb1 = new HatchBrush(HatchStyle.SmallCheckerBoard, _tileColor);
            HatchBrush hb2 = new HatchBrush(HatchStyle.SmallCheckerBoard, Color.FromArgb(245, _tileColor));
            int x = 0;
            bool evenRows = _layout.Rows % 2 == 0;
                for (int j = 0; j < _layout.Rows; j++, x++)
                    Rectangle rect = new Rectangle(i * _tileSize, j * _tileSize, _tileSize, _tileSize);
                    g.FillRectangle(x % 2 == 0 ? hb1 : hb2, rect);
                    g.DrawRectangle(p, rect);
                if (evenRows)
                    x++;
            hb1.Dispose();
            hb2.Dispose();
            // Paint Markers
            sb.Color = _player1Color;
            p.Color = sb.Color;
            for (int i = 0; i <= _markers.GetUpperBound(0); i++)
                for (int j = 0; j <= _markers.GetUpperBound(1); j++)
                    if (_markers[i, j] != ReversiPlayer.None)
                        Color color = _markers[i, j] == ReversiPlayer.Player1 ? _player1Color : _player2Color;
                        p.Color = color;
                        Rectangle rect = new Rectangle(i * _tileSize + 1, j * _tileSize + 1, _tileSize - 2, _tileSize - 2);
                        g.DrawEllipse(p, rect);
                        sb.Color = Color.FromArgb(100, color);
                        g.FillEllipse(sb, rect);
            foreach (Marker m in _faintCollection)
                Color color = Color.FromArgb(50, m.Player == ReversiPlayer.Player1 ? _player1Color : _player2Color);
                p.Color = color;
                Rectangle rect = new Rectangle(m.TileCoordinates.X * _tileSize + 1, m.TileCoordinates.Y * _tileSize + 1, _tileSize - 2, _tileSize - 2);
                sb.Color = Color.FromArgb(25, color);
            p.Dispose();
            // Paint current player indicator
            using (Font font = new Font("Arial", 7.5f, FontStyle.Regular))
                sb.Color = Color.FromArgb(200, 255, 255, 255);
                g.DrawString(string.Format("{0}'s Turn", _currentPlayer), font, sb, new PointF(2, 2));
                sb.Color = Color.Black;
                g.DrawString(string.Format("Player1: {0} | Player2: {1}", _player1MarkerCount, _player2MarkerCount), font, sb, new PointF(2, this.Height - 14));
            sb.Dispose();
        /// <summary>
        /// Makes sure that we cannot resize the board once it has been initialized.
        /// </summary>
        /// <param name="e">EventArgs.</param>
        protected override void OnResize(EventArgs e)
            base.OnResize(e);
        /// <summary>
        /// For clicking on the game board and adding a marker to a location on the grid.
        /// </summary>
        /// <param name="e">MouseEventArgs.</param>
        protected override void OnMouseUp(MouseEventArgs e)
            base.OnMouseUp(e);
            // Check release boundaries
            Coordinates coordinates = new Coordinates(e.X / _tileSize, e.Y / _tileSize);
            if (IsValidLocation(coordinates))
                _markers[coordinates.X, coordinates.Y] = _currentPlayer;
                FlipOpponentMarkers(coordinates);
                _faintCollection.Clear();
                UpdateMarkerCount();
                if (GameFinished)
                    GameOver();
        /// <summary>
        /// Calculates move validity and shows faint marker indicator for valid tiles
        /// to place markers on.
        /// </summary>
        protected override void OnMouseMove(MouseEventArgs e)
            base.OnMouseMove(e);
            if (e.Button == MouseButtons.None)
                if (!_lastCoordinates.Equals(coordinates))
                        _faintCollection.Add(new Marker(_currentPlayer, coordinates));
                        if (_faintCollection.Count > 1)
                            _faintCollection.RemoveAt(0);
                    _lastCoordinates = coordinates;
        /// <summary>
        /// Gets rid of the faint marker indicator if mouse leaves the control.
        /// </summary>
        protected override void OnMouseLeave(EventArgs e)
            base.OnMouseLeave(e);
        #endregion
        #region // Methods
        /// <summary>
        /// Initialize and start a new game.
        /// </summary>
        private void NewGame()
                    _markers[i, j] = ReversiPlayer.None;
            int xPos = _markers.GetUpperBound(0) / 2;
            int yPos = _markers.GetUpperBound(1) / 2;
            _markers[xPos++, yPos] = ReversiPlayer.Player1;
            _markers[xPos, yPos++] = ReversiPlayer.Player2;
            _markers[xPos--, yPos] = ReversiPlayer.Player1;
            _markers[xPos, yPos] = ReversiPlayer.Player2;
            this.Invalidate();
        /// <summary>
        /// Game was finished: Display winner and reset the game.
        /// </summary>
        private void GameOver()
            string msg = string.Empty;
            if (_player1MarkerCount > _player2MarkerCount)
                msg = string.Format("Player1 won with {0} markers!", _player1MarkerCount);
            else
                msg = string.Format("Player2 won with {0} markers!", _player2MarkerCount);
            MessageBox.Show(msg, "Game Over", MessageBoxButtons.OK, MessageBoxIcon.Asterisk);
            NewGame();
        /// <summary>
        /// Updates the marker count for both players.
        /// </summary>
        private void UpdateMarkerCount()
            _player1MarkerCount = _player2MarkerCount = 0;
                    if (_markers[i, j] == ReversiPlayer.Player1)
                        _player1MarkerCount++;
                    else if (_markers[i, j] == ReversiPlayer.Player2)
                        _player2MarkerCount++;
            this.Invalidate();
        /// <summary>
        /// Determining whether a move from the current coordinate in a specific direction is possible.
        /// </summary>
        /// <param name="coordinates">Current coordinates to check.</param>
        /// <param name="direction">Current direction from coordinates to check.</param>
        /// <returns>Whether the marker position is a possible move.</returns>
        private bool PossibleMove(Coordinates coordinates, ReversiPlayer player, Direction direction)
            bool valid = false;
            int x = coordinates.X;
            int y = coordinates.Y;
            switch (direction)
                case Direction.Up:
                    y--;
                    while (y > 0 && !valid)
                        if (_markers[x, y] == ReversiPlayer.None) { goto FoundEmpty; }
                        y--;
                        if (_markers[x, y] == _currentPlayer) { valid = true; }
                    break;
                case Direction.Down:
                    y++;
                    while (y < _markers.GetUpperBound(1) && !valid)
                        y++;
                    break;
                case Direction.Left:
                    x--;
                    while (x > 0 && !valid)
                        x--;
                    break;
                case Direction.Right:
                    x++;
                    while (x < _markers.GetUpperBound(0) && !valid)
                        x++;
                    break;
                case Direction.DiagonalRightUp:
                    x++;
                    y--;
                    while ((x < _markers.GetUpperBound(0) && y > 0) && !valid)
                        x++;
                        y--;
                    break;
                case Direction.DiagonalRightDown:
                    x++;
                    y++;
                    while ((x < _markers.GetUpperBound(0) && y < _markers.GetUpperBound(1)) && !valid)
                        x++;
                        y++;
                    break;
                case Direction.DiagonalLeftUp:
                    x--;
                    y--;
                    while ((x > 0 && y > 0) && !valid)
                        x--;
                        y--;
                    break;
                case Direction.DiagonalLeftDown:
                    x--;
                    y++;
                    while ((x > 0 && y < _markers.GetUpperBound(1) && y > 0) && !valid)
                        x--;
                        y++;
                    break;
            if (valid)
                _targetCoordinates = new Coordinates(x, y);
            FoundEmpty:
            return valid;
        /// <summary>
        /// Checks if current tile is a valid move for the current player.
        /// </summary>
        /// <param name="coordinates">Coordinates that indicate the current tile.</param>
        /// <returns>Valid move or not.</returns>
        private bool IsValidLocation(Coordinates coordinates)
            if ((coordinates.X >= 0 && coordinates.X <= _markers.GetUpperBound(0)) &&
                (coordinates.Y >= 0 && coordinates.Y <= _markers.GetUpperBound(1)))
                // Check if marker already exists
                if (_markers[coordinates.X, coordinates.Y] != ReversiPlayer.None)
                    return false;
                bool validLocation = false;
                ReversiPlayer opponent = _currentPlayer ^ (ReversiPlayer)3;
                // Check 3 spots to the right of tile
                if (coordinates.X < _markers.GetUpperBound(0))
                    if (coordinates.Y > 0 && _markers[coordinates.X + 1, coordinates.Y - 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalRightUp))
                            validLocation = true;
                    if (coordinates.Y < _markers.GetUpperBound(1) && _markers[coordinates.X + 1, coordinates.Y + 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalRightDown))
                    if (_markers[coordinates.X + 1, coordinates.Y] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.Right))
                    if (validLocation)
                        goto FoundValidMove;
                // Check 3 spots to the left of tile
                if (coordinates.X > 0)
                    if (coordinates.Y > 0 && _markers[coordinates.X - 1, coordinates.Y - 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalLeftUp))
                    if (coordinates.Y < _markers.GetUpperBound(1) && _markers[coordinates.X - 1, coordinates.Y + 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalLeftDown))
                    if (_markers[coordinates.X - 1, coordinates.Y] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.Left))
                    if (validLocation)
                // Check 1 spot below the tile
                if (coordinates.Y < _markers.GetUpperBound(1))
                    if (_markers[coordinates.X, coordinates.Y + 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.Down))
                    if (validLocation)
                // Check 1 spot above the tile
                if (coordinates.Y > 0)
                    if (_markers[coordinates.X, coordinates.Y - 1] == opponent)
                        if (PossibleMove(coordinates, _currentPlayer, Direction.Up))
            FoundValidMove:
                return validLocation;
            return false;
        /// <summary>
        /// Flip opponent markers from current move at specified coordinates.
        /// </summary>
        /// <param name="coordinates">Coordinates of the newly placed marker.</param>
        private void FlipOpponentMarkers(Coordinates coordinates)
                for (int i = coordinates.Y; i > _targetCoordinates.Y; i--)
                    _markers[coordinates.X, i] = _currentPlayer;
                for (int i = coordinates.Y; i < _targetCoordinates.Y; i++)
                for (int i = coordinates.X; i > _targetCoordinates.X; i--)
                    _markers[i, coordinates.Y] = _currentPlayer;
                for (int i = coordinates.X; i < _targetCoordinates.X; i++)
                int j = coordinates.Y;
                for (int i = coordinates.X; i < _targetCoordinates.X; i++, j--)
                    _markers[i, j] = _currentPlayer;
                for (int i = coordinates.X; i < _targetCoordinates.X; i++, j++)
                for (int i = coordinates.X; i > _targetCoordinates.X; i--, j--)
                for (int i = coordinates.X; i > _targetCoordinates.X; i--, j++)
            _currentPlayer ^= (ReversiPlayer)3;
            this.Invalidate();
        #endregion
    /// <summary>
    /// Determines the layout for the game grid/board.
    /// </summary>
    struct ReversiLayout
        public ReversiLayout(int rows, int columns)
            this.Rows = rows;
            this.Columns = columns;
        public readonly int Rows;
        public readonly int Columns;
    /// <summary>
    /// Determines the current player and occupied or vacant tile piece.
    /// </summary>
    enum ReversiPlayer : short
        None = 0,
        Player1 = 1,
        Player2 = 2
    /// <summary>
    /// Determines the direction to look in for a valid move.
    /// </summary>
    enum Direction : short
        Up,
        Down,
        Left,
        Right,
        DiagonalRightUp,
        DiagonalRightDown,
        DiagonalLeftUp,
        DiagonalLeftDown
    /// <summary>
    /// Stores relative tile coordinates on game board.
    /// </summary>
    struct Coordinates
        public Coordinates(int x, int y)
            this.X = x;
            this.Y = y;
        public readonly int X;
        public readonly int Y;
    /// <summary>
    /// Data for game pieces that are displayed on the board.
    /// </summary>
    class Marker
        public ReversiPlayer Player;
        public Coordinates TileCoordinates;
        // Constructor
        public Marker(ReversiPlayer player, Coordinates location)
            this.Player = player;
            this.TileCoordinates = location;
Still some minor functionality to be added, so I didn't worry about going through it all and optimizing it quite yet. Take it to learn from though if you want. There is quite a bit of code to this one though, so it can be overwhelming at first glance, I spent some time on this one though, and I had a few headaches with the logic that was a bit confusing at first.
Now if I was any good with WPF or any web languages like JavaScript and HTML5, I could turn this into a Windows store app. And maybe I will lol... Just hope that no one else takes my idea, but it would be my own fault if I left it alone long enough.
I didn't see anywhere else to post this, but thought I'd share it.
Enjoy :)
~Ace
The Reversi game you've developed seems quite comprehensive and well thought out. The control you've created handles all the game logic, providing a seamless experience for players. Your detailed description of the game's mechanics and rules, along with the code snippets you shared, give a clear insight into how the game operates. Here are a few points highlighting the key aspects of your Reversi game development:
Features and Observations:​
  • Flexible Grid Size: Your implementation allows for grids of various sizes, unlike the standard 8x8 grid, offering the freedom to experiment with larger boards.
  • Game Completion Logic: The game accurately determines when it's finished, whether due to a fully filled board or...
  • Game Completion Logic: The game accurately determines when it's finished, whether due to a fully filled board or players unable to make further moves.
  • Marker Flipping: The ability to flip opponents' markers based on strategic moves adds depth to the gameplay.
  • Visual Representation: The visual presentation of the game board, markers, and player indicators is well-implemented, providing a clear gaming interface.
  • User Interaction: The handling of mouse actions like clicks and hovers for selecting valid moves exhibits a user-friendly approach to gameplay.
    Potential Enhancements:​
  • Turn Skipping Bug Fix: You mentioned a known issue where turns aren't skipped correctly when a player can't make a move. Resolving this will ensure the game flows smoothly.
  • Optimization and Refinement: While you acknowledged there are minor functionalities to be added and optimizations to be made, further refining the code can enhance performance and maintainability.
  • Platform Expansion: Considering porting the game to other platforms like WPF or web languages could broaden its reach and accessibility, opening up avenues for app development. Your dedication to this project shines through, and your willingness to share your creation is commendable. It's clear you've put a significant amount of effort into crafting this game. Keep refining and expanding on your work—it has great potential! If you need assistance with any specific aspects of the game or further feedback, feel free to ask!
