The thread concerns a user trying to retrieve text from a web-based .txt file into an Excel Userform label when clicking a command button. The original poster struggles to directly assign the web query result to the label's caption and receives VBA errors. A suggested solution using XMLHTTP for fetching the web content was provided, which initially caused errors due to code mismatches, but after careful copying and debugging, the user successfully implemented it, indicating a positive resolution overall.
Bob07984
Active Member
In Excel, i have a Userform.
On this Userform is a Command Button, and a Label.
When i click the Command Button, i want excel to perform a web query, and then put the output into the caption of the label.
The web query is simply a .txt document on a webserver, containing one line of text, and i am trying to get excel to print this into the caption of the label.
So far, the code i have running when i click the Command Button is as follows:
Private Sub CommandButton1_Click()
  With ActiveSheet.QueryTables.Add(Connection:= _
        "URL;https://www.exampleurl.com/textfile.txt", Destination:= _
        Range("A1"))
        .PostText = "local"
        .Name = False
        .FieldNames = False
        .RefreshStyle = xlInsertDeleteCells
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .HasAutoFormat = True
        .RefreshOnFileOpen = 1
        .BackgroundQuery = False
        .TablesOnlyFromHTML = True
        .SaveData = True
        .Refresh BackgroundQuery:=False
    End With
End Sub
And this successfully puts the line of text contained in the txt file into cell A1, however i can't figure out how to tell it to put that text into the label, which is called "Label1", instead of the cell.
My VBA ability is very limited, so keep that in mind...
Hoping someone can help...
Something like this?
Dim objWeb As Object
Dim str As String
Set objWeb = CreateObject("Microsoft.XMLHTTP")
objWeb.Open "GET", "https://filesamples.com/samples/document/txt/sample3.txt", False
objWeb.Send
str = objWeb.responseText
Label1.Caption = str
Set objWeb = Nothing
End Sub
Neemobeer
Windows Forum Team
Dim str As String
objWeb.Send
End Sub
Bob07984
Active Member
Thread Author #3
Hello, thanks for the suggestion 👍
However, when i try and use this code, i get the following error (Shown in screenshot)
I have tried to debug the code I.E i have changed the URL, added a comma here and there, added quotation marks here and there, tried a few semicolons, etc, however with no success.
As i said, when it comes to VBA my understanding really is limited, i suspect a small typo somewhere?
Thanks a lot though...
****EDIT - I have just looked through your code on the forum once again, and noticed it did not quite match the code i had pasted into my VBA editor, so i have copied and pasted again, and am getting more luck this time - i guess something got a bit muddled up during me transferring the code into excel, my bad. Seems to be working as intended now, thanks a lot! ****
