The thread discusses an idea to enable toggling selected text between uppercase and lowercase using the Caps Lock key, prompting user interest but clarifying it's a feature request for Microsoft rather than a built-in OS function. Contributors suggest submitting feedback to Microsoft through their forums and support channels, and some mention that similar text case toggling features exist in applications like Microsoft Word. Overall, the discussion is a mix of idea sharing, technical insights, and guidance on how to propose such features to Microsoft.
JulianCh420
Got no idea if this is right thread, but i got this idea.
when u mark texts, you can just press caps lock to make everything in caps, and ofc toggle so hitting caps lock again will make the text small again
Someone make this happen, because its not a stupid idea.
BIGBEARJEDI
Hi and welcome to the forum :up:
Not sure I'm understanding you. Are you sharing a "tip" with all of us forum users, or are you suggesting that someone like Microsoft fix this and it's a problem?
Cheers!
<<<BIGBEARJEDI>>>
Neemobeer
Windows Forum Team
This sounds like an enhancement request to Microsoft. If that is the case you should probably tell Microsoft. This site is not owned, operated or monitored (probably) by Microsoft.
JulianCh420
Thread Author #4
It was just to get the idea out there, see what people think about it, idk where to contact microsoft for that, there was a link on theyre page but it didnt exist
BIGBEARJEDI
zirkoni
I think this is more of an application specific feature than an OS feature.
In MS Word you can change the case of selected text with Shift+F3 (lower case -> 1st letter upper case -> upper case).
Neemobeer
Windows Forum Team
This would be certainly doable, from c++ or C# you could do the following.
  • Implement a program with a keyboard hook to capture your key combo you want to use to make text all upper or all lower
  • Call GetForegroundWindow windows API to get the handle to the current window with focus
  • Call the Windows API GetFocus to get the handle to the focused control
  • Call SendMessageW API with EM_GETSEL to get the selected text
  • Would need to keep track of what state you are transitioning to for each known process and then convert the text accordingly
  • Send the converted text back to the control (not quite sure how to do this, but I'm sure there is a API call you can use in user32.dll
