urian
Hello!, Sorry for my english if you do not understand something.
I have a problem witch a cdrom autoexecutable, the cdrom must register a dll before run the application. I create a batch file.On windows vista it's not possible. When I call regsrvr32 from cd appear acces denied, I believe that is appear of Acces User Control.
I trying create msi to register the library but i need register from cd.
Can you help me please!
Thanks in advance.
My mail is [email protected] if you need.
Greetings
Hi and welcome to the forums,
There is no way to elevate an application from the command-line in Windows Vista out of the box. You may want to check out this, however, as it may be useful. I am not sure if you could include it on your CD-ROM to make this work. It may be better to create an installer using InstallShield or Windows Installer where you can properly control the elevation.
Utility Spotlight: Script Elevation PowerToys for Windows Vista
Please let me know if this helps you.
Mike
Windows Forum Admin
