The thread discusses a SQL Server database that entered Suspect Mode, making it difficult to repair or access. The original poster seeks advice on resolving this issue, and a responder suggests using emergency mode and running certain commands, but with caution. Later, another contributor questions whether DBCC checkdb truly refuses to run in this state, highlighting some uncertainty about the problem's specifics.
alainmarion85
In the work I came up against a situation when the working database at the end of day went to the Suspect Mode. And the archive was in many hours before. To transfer it in normal mode, until isn't made repaired base it was impossible. DBCC checkdb also refused to run because the database is in this mode. What to do in this case?
What version of MS SQL are you using?
Backup the database if at all possible before trying any of this, I'm not responsible if you nuke your data!
You need to login to the database as the sa user and perform some maintenance.
EXEC sp_resetstatus 'database_name';
ALTER DATABASE database_name SET EMERGENCY;
DBCC checkdb('database_name');
Josephur
Windows Forum Admin
