The latest ICS advisory from CISA has unveiled severe vulnerabilities in the Outback Power Mojave Inverter—a key component of residential grid-connected battery backup systems. Although primarily an industrial control system (ICS) device, the ramifications of these vulnerabilities stretch far, potentially affecting home networks where power management and surveillance overlap with Windows-based control systems.
A black OutBack power rotary inverter sits on a table in a dimly lit urban night setting.
What’s Happening?​
CISA’s alert details three main vulnerabilities with CVE identifiers CVE-2025-26473, CVE-2025-25281, and CVE-2025-24861. Each vulnerability carries a CVSS v4 base score of 8.7—enough to set alarm bells ringing within cybersecurity circles. Here’s the lowdown:
  • Use of GET Request Method with Sensitive Query Strings (CWE-598): The Mojave Inverter improperly employs the GET method, sending sensitive queries within URL strings. In modern web security, GET requests expose data that should remain private—especially dangerous if intercepted over unencrypted networks.
  • Exposure of Sensitive Information (CWE-200): Attackers can tweak the URL to retrieve confidential network data. This type of vulnerability can expose the underlying architecture and operational details, making subsequent attacks easier to craft.
  • Command Injection (CWE-77): Perhaps most dangerous, this flaw enables an attacker to craft malicious posts that can inject and execute commands on the device. Such exploits could allow attackers to manipulate the device’s operation or even pivot deeper into a network.
The Technical Breakdown​
How Do These Vulnerabilities Work?​
  • Sensitive Data via GET Requests:
    In this configuration, the inverter sends critical data in the URL parameters. Unlike POST requests, GET requests are stored in browser histories, logs, and are often visible in network traffic. Any Windows-based or network monitoring tool could inadvertently capture and expose this data. The use of GET in this sensitive context violates basic best practices in secure communications.
  • Unauthorized Information Disclosure:
    The flaw regarding the exposure of sensitive information means that modifying query parameters can allow cyber intruders to glean internal system data. This is somewhat akin to leaving the back door of your house unlocked, where sniffers can easily wander in and survey vulnerable entry points.
  • Command Injection Risk:
    An attacker can craft a specially-designed post request that injects commands into the system. Imagine an unintended open gateway, not only exposing secrets but permitting remote execution of commands. This flaw could allow hackers to alter system settings or even shut down the device entirely, impacting your home’s backup power management.
Broader Implications for IT and Windows Systems​
For Windows users—and IT professionals—the intersection between consumer-grade Windows systems and industrial control systems is growing. With Industry 4.0 trends and the increasing convergence of operational technology (OT) and information technology (IT), vulnerabilities in critical components like inverters can act as gateways into wider networks. If your home or corporate setup utilizes any sort of remote management interface for these inverters, the risk escalates dramatically.
Moreover, these flaws highlight broader concerns in cybersecurity where legacy products and cascading vendor transitions (Outback Power inheriting products from Enersys) create patch management nightmares. The lack of timely updates may affect not only industrial environments but also any integrated setups where Windows-based network management tools are in place.
Mitigation Steps: What Can You Do?​
While Outback Power has yet to address these vulnerabilities, CISA has recommended several measures to mitigate the risk. For Windows users managing network endpoints or systems integrated with such devices, consider the following:
  • Disable Unused Functions: If the networking features of the inverter aren’t essential, consider disabling them to reduce exposure.
  • Restrict Network Access: Ensure that these devices are not exposed directly to the Internet. Place them behind firewalls and use network segmentation to protect business or home networks.
  • Use Secure Remote Access: When remote management is necessary, opt for secure VPNs. Ensure that VPN clients on Windows are always updated, as vulnerabilities in VPN software can be an entry point for attackers.
  • Regular Impact Analysis: Continuously monitor your network for unexpected behavior. Utilize endpoint security tools that integrate with Windows to detect anomalies early.
  • Educate Users: As always, be cautious with unsolicited emails and unexpected links—social engineering can be the easiest method for attackers to gain a foothold.
Final Thoughts​
This discovery underscores a clear warning: when integrating specialized hardware like the Mojave Inverter into your network, ensure that all connected devices—including your Windows systems—are thoroughly secured. As organizations grapple with legacy systems and resource constraints, vigilance is key. The intersection of ICS and IT is a growing frontier where vulnerabilities in one can lead to significant ramifications in the other.
While these vulnerabilities may be technical in nature, their potential impact on power management and network security is a serious concern that calls for swift and proactive defense measures. Stay tuned to WindowsForum.com for further expert insights on securing your network against such ICS challenges and enhancing your overall cybersecurity posture.
Feel free to share your thoughts or additional mitigation tips in the comments section below. Let's work together to keep our networks safe and secure!
