The thread begins with a brief, informal post from whoosh, and is followed by a detailed summary from ChatGPT of a YouTube video showcasing the construction of an AMD-based custom water-cooled gaming PC, highlighting challenges such as RGB troubleshooting and assembly hurdles. The creator humorously documents their experience, emphasizing both successes and frustrations, especially with RGB lighting issues. Overall, the thread discusses the complexity of building custom loops with AMD hardware, inviting community sharing of similar experiences and tips.
whoosh
Cooler King
All AMD Custom Loop Gaming PC: Ft. RGB Struggles In a recent YouTube video titled "All AMD Custom Loop Gaming PC: Ft. RGB struggles", the creator takes viewers through the process of building a custom water-cooled gaming PC featuring AMD hardware. This project, highlighted with unique challenges and humor, centers around the setup of the Corsair custom loop cooling system, including RGB components that proved to be both a joy and a vexation.
Overview of the Build​
The video begins with the creator expressing mixed feelings about revisiting custom loop builds, referencing past difficulties with materials. The choice of a soft line build is introduced as a way to simplify the process while still achieving an appealing visual aesthetic. Key Components Used:
  • CPU: AMD Ryzen 9 5900X
  • GPU: AMD RX 6800
  • Motherboard: MSI X570 Tomahawk
  • Coolant System: Corsair custom loop components
Building Process and Unique Challenges​
The creator encountered various hurdles throughout the build. While unboxing the Corsair parts, they noted how the experience was both exciting and fraught with the anxiety that typically accompanies complex setups. Initially, securing the Ryzen CPU and RX 6800 GPU was seamless, but the real struggle emerged with the custom loop assembly.
  1. Cooling Blocks Installation:
    • The installation of cooling blocks on both the CPU and GPU required careful handling. The creator humorously noted the "virginity" of the graphics card being broken in the process.
  2. Tubing and Assembly:
    • After some cursing and palpitations, the creator opted to simplify the tubing setup by forgoing an additional radiator, leading to a smoother assembly experience. However, getting the water flowing through required a leap of faith, which naturally raised concerns about potential leaks.
  3. RGB Troubles:
    • The RGB integration became a significant point of frustration, highlighting the chaotic nature of connecting various RGB components. Despite meticulous planning, issues arose with lighting control, culminating in the humorously chaotic attempt to troubleshoot the RGB setup at the end of the process.
      Performance Insights​
      After the custom loop was established and water poured, initial tests suggested a successful setup with manageable temperatures. The RX 6800 hovered around the low to mid-40s Celsius, while the CPU reportedly reached up to 73 degrees. The creator planned to conduct gaming performance tests during an upcoming Twitch stream, promising further insights into the system's capabilities.
      Conclusion and Community Engagement​
      Throughout the video, viewers are treated to a candid, humorous take on building a custom PC, emphasizing both the triumphs and trials of the process. The creator invites audiences to join their gameplay sessions for a firsthand experience of the new build's performance. For anyone considering a custom loop system, this video serves as both a guide and a reminder of the potential complications that come with it—particularly when RGB lighting is involved! What are your thoughts on custom loop builds? Have you experienced similar challenges in your setups? Share your experiences or any tips you might have below!
