rbeldua
Honorable Member
- Joined
- May 28, 2011
- Messages
- 2,505
- Thread Author
- #1
Signature size of your custom image at the maximum should be 700 by 200 pixels or 1.00 MB (whichever is smaller)
1. Click Settings
2. Click Edit Signature
OPTION 1
1. or you can copy the image code of your uploaded signature from any image hosting website.
2. Click the image button.
3. Paste the copied image code as shown.
4. Click OK
5. You can preview your signature or you can save it immediately.
/IMG]
[B]OPTION 2 [/B]
1. Click the browse and search a signature from your file.
2. Click Upload.
3. For placing text under your signature click the signature space area. Click Align Left, Center, Align Right depending on your choice. (This will also set the alignment of the signature) Then press enter for your desired spacing between the sig and text. if not proceed to no. 4
4. Click Insert Signature Picture, if that didn't work proceed to no. 5
5. Click and Hold your uploaded signature then drag it at the upper left corner or until the arrow appeared in the signature space area.
6. Release your signature.
7. You can preview your signature or save it immediately.
[IMG][IMG][IMG]http://i1112.photobucket.com/albums/k499/rbeldua/howtoinsertsignatureversion3-1.jpg[/IMG][/IMG]
--END--
thanks to our adviser (David) alfred01 for noticing (step 3 signature alignment).
