The thread discusses the recent price hike of HP #62 Black XL ink cartridges, with the original poster frustrated by the increasing costs and the unavailability of refills. A responder recommends switching to Epson printers with tank-based ink systems, which are more cost-effective over time despite higher initial costs. The original poster accepts this advice, indicating they plan to switch to a tank-based printer to save money.
rjordan
Active Member
I just noticed a price increase on HP #62 Blk XL ink cartridge from $35.00 and change to $37.99. That was outragious
before the increase. Does anyone have a solution for a cheaper way to make copies? I used to be able to refill the
cartridges but it seems that the refills are not available anymore.
whoosh
Cooler King
If you want cheaper copies and are willing to make an initial outlay look at Epson. Not cartridges but tanks. Two years of printing on average.
Cartridges are always more expensive then tanks. The downside is the initial investment but the cost will be worth it in the long run :up:
rjordan
Active Member
Thread Author #3
Thanks,
What you suggest is what I will go for. The cost for cartridge ink is way out of line.
