The thread discusses the comparison between cheap and expensive Thunderbolt 4 cables, with the original post sharing a video that tests both types. The findings indicate that budget cables, such as those from AliExpress, can perform similarly to premium brands like Apple and Anker in terms of power delivery and data transfer, despite lower build quality. Overall, the thread suggests that affordable Thunderbolt 4 cables may be a cost-effective option for typical use, prompting community members to share their experiences with budget tech accessories.
whoosh
Cooler King
:iee:
I tried a cheap and expensive Thunderbolt 4 cable In a recent video, the creator explores the price differences and performances of cheap versus expensive Thunderbolt 4 cables, shedding light on a topic that's increasingly relevant for tech enthusiasts and Mac users.
Overview of Thunderbolt 4 Cables​
Thunderbolt 4 cables are essential for maximizing the capabilities of Thunderbolt 4 docks, especially when it comes to data transfer speeds and power delivery. With prices soaring for branded cables—$129 for Apple and $60 for Anker—consumers might be wondering if cheaper alternatives are worth the risk.
The Price Comparison​
The creator checks prices online and in local stores, noting dramatic cost differences. On platforms like AliExpress, prices are significantly lower compared to traditional retailers. For example:
  • A one-meter cable could be as low as $8.99 on AliExpress compared to $129 for an Apple branded cable. This disparity raises questions about the reliability and longevity of cheaper options.
    Testing Performance​
    The video features hands-on testing of a cheap cable versus a more expensive model:
    1. Power Delivery Test: Both cables were able to provide similar power delivery, with both showing comparable wattage during use.
    2. Data Transfer Speeds: Using a Crucial X8 external SSD for testing, the cheap cable delivered similar data rates to those of premium cables, indicating that it could transfer data as effectively for normal uses.
      Conclusions​
      While the cheap Thunderbolt 4 cable did not boast the same quality of connectors and flexibility, it effectively handled the required tasks without performance loss. If you're looking to save radically on cables without sacrificing performance, it seems sensible to consider these alternatives, bearing in mind potential variances in build quality and durability.
      Discussion​
      What do you think about buying cheaper alternatives for tech accessories? Have you tested any budget cables or accessories that performed surprisingly well? Share your experience and thoughts in this thread!
      Feel free to explore more threads on affordable tech solutions or share your experiences with Thunderbolt 4 devices.
