whoosh
Cooler King
I've never seen fans do this before... So cool! If you're a PC enthusiast looking to upgrade your cooling system, you might find the latest Lian Li Uni P28 fans intriguing. In a recent YouTube video titled I've Never Seen Fans Do This Before... So Cool!, the new features of these fans were showcased, and they certainly stand out from the crowd .
Key Features of the Lian Li Uni P28 Fans​
  1. Versatile Connectivity: One of the unique aspects of the Uni P28 fans is their ability to daisy chain multiple fans together. They can connect up to four channels of four fans using a single controller, which allows for streamlined cable management by only requiring one signal wire and one ARGB header.
  2. Enhanced Performance: The P28 fans come in at a thickness of 28mm, adding to their performance capabilities. With new blade designs, they feature a higher pitch and more blades compared to earlier models. This design is particularly effective for pulling static pressure through radiators, making them ideal for high-performance cooling setups.
  3. Adjustable RPM Settings: Users can benefit from multiple RPM settings: 1300, 2200, and 2600 RPM, providing nice flexibility depending on the system’s cooling needs. For example, at low RPMs, the fans can operate quietly while still providing airflow—precisely what you want for less intensive tasks.
  4. Efficient Airflow and Noise Levels: The specifications indicate impressive airflow capabilities, with advertised CFM ratings reaching up to 92 CFM at the highest RPM. The noise levels range from 20.4 dB at low settings to 32.1 dB at high, ensuring that while they perform efficiently, they do not become overly disruptive when operating at higher speeds.
  5. Aesthetic Options: While these fans do not have built-in RGB lighting, Lian Li offers a separate lighting kit that can be attached. This allows users who prefer non-RGB fans to still customize their setups aesthetically.
    So, what does this mean for the Windows community? If you're looking to build or upgrade a gaming PC or a workstation that demands solid cooling, the Lian Li Uni P28 fans present an appealing option. With their ability to handle high pressure and airflow within a compact footprint, they can contribute significantly to system performance, especially in machines with high-end graphics cards and CPUs. Moreover, the innovative design allows seamless integration into various builds without the clutter of additional cables. The unique selling point of these fans lies not only in their cooling efficiency but also in their user-friendly installation and management. If you’re considering a build or upgrade, the video offers an insightful look at the capabilities of the Lian Li Uni P28 fans. Check it out and see if these cooling solutions align with your next project .
