The forum thread discusses recent concerns about Nvidia GPUs and upcoming technology changes, highlighting that support for older Windows versions like 7 and 8 will end in early 2024, affecting user access to updates. The conversation covers new CPU offerings from AMD and the upcoming release of Nvidia's RTX 4060 series, alongside worries about the performance of current Nvidia GPUs, such as the RTX 3070, which may struggle with modern games. The overall sentiment suggests that Nvidia GPU owners should consider upgrading their hardware and operating systems to meet evolving gaming and performance demands.
whoosh
Cooler King
Your Nvidia GPU Has A BIG PROBLEM! In a recent YouTube video titled "Your Nvidia GPU Has A BIG PROBLEM!", the creator dives deep into some concerning trends affecting Nvidia GPU owners as advancements in technology continue. Here’s a summary of the key points discussed.
Key Highlights of the Video​
1. End of Support for Older Windows Versions
Starting January 1, 2024, Valve will officially cease support for Steam on Windows 7, 8, and 8.1. This means gamers still using these versions will lose access to new updates and may find the Steam client unusable. The shift seems driven by the demand for features that rely on updated infrastructure, namely an embedded version of Google Chrome, which no longer functions on these older operating systems.
2. Introduction of AMD’s Hybrid Core CPU
The video also touches on AMD's new hybrid core CPUs, hinted at in their upcoming Ryzen APU lineup. These processors adopt a "big.LITTLE" architecture, which could enhance processing efficiency by balancing performance and energy use. The benchmarks shared suggest promising frequencies for performance and efficiency cores; however, these are early samples and might not reflect final specs.
3. Upcoming Nvidia GPUs
Several upcoming Nvidia GPUs were highlighted, including the anticipated RTX 4060 and 4060 Ti, expected to launch in May. Another GPU, the RTX 4050, should follow suit in June. These releases are supported by leaked packaging templates and reports from reliable GPU insiders, indicating that Nvidia is gearing up for a busy launch season.
4. Performance Concerns with Existing GPUs
A substantial concern raised in the video is about Nvidia's existing graphics cards, particularly the RTX 3070, which reportedly struggles with titles like "The Last of Us Part 1". Reports show the card's dismal performance at 1440p and 4K, leading to unplayable frame rates. This raises questions regarding Nvidia’s VRAM strategy, as many users may find their GPUs inadequate for newer gaming demands.
The community is urged to consider these developments seriously. As Nvidia releases newer GPUs, gamers are left asking if their current setups can handle modern requirements. If you're an Nvidia GPU owner, it might be time to consider upgrading, especially if you’re still relying on older operating systems.
Community Engagement​
What are your thoughts on the upcoming Nvidia GPUs? Are you still using Windows 7 or 8, and how do you feel about the end of support? Let us know your experiences and insights in the comments! Also, check out related threads on GPU performance and gaming in 2024!​
If you're interested in deep dives into tech trends or need advice on upgrading your setup, feel free to explore our forum further!
