GeneralHiningII
Fantastic Member
- Joined
- Sep 21, 2012
- Location
- Sydney, Australia
DRIVER_IRQL_NOT_LESS_OR_EQUAL:
Got this problem after building a new computer (from scratch) and finished installing all the drivers, programs and related stuff. Began to play around with it (overclocking, overvolting, etc.) and found stables for everything.
After this:
Ran it through Prime95 on Small FFTs and Blend for 24 hours each, IntelBurnTest on High eXtreme testing.
Ran it through Memtest overnight for 6 passes, 0 errors.
Ran it through FurMark and Unigine Heaven and Valley, ~48FPS for both and average max temperature of 71 Celsius. No artifacts or unexpected problems.
Ran the SSD through CrystalDiskMark, performed to expectations.
Ran the HDD through HDTune, performed to expectations.
After all these stress tests showed my computer to be rock hard, I decided to run through some games.
About an hour into them, it crashed, and returned me to my desktop. Normally if it were a graphics driver error, a popup window saying "NVIDIA driver XXX.XX has crashed and successfully recovered" would show on the taskbar. This did not occur.
After roughly 3 more sessions, a bluescreen took over with the message DRIVER_IRQL_NOT_LESS_OR_EQUAL, and a stop error code of 0xD1.
First thing I did to fix this:
Returned both my CPU and GPU to stock clocks, and ran it through stress tests again. No problem. (I'm assuming this means that it's not the OC that's the problem)
Ran Driver verifier and selected ALL drivers and rebooted. No bluescreen, so I'm assuming once again that none of the drivers I'm currently running on are problematic.
Any help would be much appreciated
Thanks
(Extra note: I don't have my BSOD analyzing app installed on this computer or the standard debugging tools for Windows. If so, I'd probably already have this solved.)
After this:
