A bunch of BSOD - Startup, and shortly after
Lately I've been getting these more and more frequently. I'm not really too sure what could possibly cause this, but I have all the minidump files here and this:
Problem signature:
  Problem Event Name:    BlueScreen
  OS Version:    6.1.7600.2.0.0.768.3
  Locale ID:    1033
Additional information about the problem:
  BCCode:    1e
  BCP1:    FFFFFFFFC0000005
  BCP2:    FFFFF800032647E7
  BCP3:    0000000000000000
  BCP4:    000000007EFA0000
  OS Version:    6_1_7600
  Service Pack:    0_0
  Product:    768_1
Thanks in advance!
Hello,
I ran all 23 dumps. You only have a few different bugcheck codes:
[FONT=lucida console]
BugCheck 1E, {ffffffffc0000005, fffff800032647e7, 0, 7efa0000}
BugCheck 50, {fffff880077fd928, 0, fffffa8007820058, 0}
BugCheck 1000007E, {ffffffffc0000005, 0, fffff8800828fa68, fffff8800828f2d0}
BugCheck 1E, {ffffffffc0000005, fffff80002cae7e7, 0, 7efa0000}
BugCheck 1E, {ffffffffc0000005, fffff80002fbf72a, 1, 18}
BugCheck 1E, {ffffffffc0000005, fffff80002d0bf4b, 0, 2e0}
BugCheck 1E, {ffffffffc0000005, fffff80002c537e7, 0, 7efa0000}
BugCheck A, {dc, 2, 1, fffff80002ca6055}
BugCheck 1E, {ffffffffc0000096, fffff80002ca30fa, 0, 0}
BugCheck A, {dc, 2, 1, fffff8000326b055}
BugCheck A, {1, 2, 0, fffff80002c7f8b6}
BugCheck 1E, {ffffffffc0000005, fffff80002c597e7, 0, 7efa0000}
BugCheck 1E, {ffffffffc0000005, fffff80002c7fcd8, 0, ffffffffffffffff}
BugCheck 1E, {ffffffffc0000005, fffff80002c6b7e7, 0, 7efa0000}
BugCheck 50, {fffff88002903910, 0, fffff80002c796a6, 0}
BugCheck 1E, {ffffffffc0000005, fffff80002c697e7, 0, 7efa0000}
BugCheck 1E, {ffffffffc0000005, fffff80002fc172a, 1, 18}
BugCheck 1E, {ffffffffc0000096, fffff80002c970fa, 0, 0}
BugCheck 1E, {ffffffffc0000005, fffff80002c6b7e7, 0, 7fffffa0000}
BugCheck 1E, {ffffffffc0000005, fffff80002cbdf4b, 0, 2e0}
BugCheck A, {dc, 2, 1, fffff80002c4d055}
[/FONT]
Four of the crashes were while sf.bin was the top process. That is a component of Avast. Also, Firefox and Skype were reported as the top process for two other dumps.
I suggest you start out by removing Avast. Cleanup with this tool: http://files.avast.com/files/eng/aswclear5.exe
Microsoft Security Essentials is the recommended replacement.
aswFsBlk.SYS      Tue Sep 07 10:47:09 2010 (4C86506D)
aswMonFlt.sys     Tue Sep 07 10:47:32 2010 (4C865084)
aswRdr.SYS        Tue Sep 07 10:47:47 2010 (4C865093)
aswSP.SYS         Tue Sep 07 10:52:07 2010 (4C865197)
aswTdi.SYS        Tue Sep 07 10:52:27 2010 (4C8651AB)
Also, remove Daemon Tools, or whatever similar program you may be using. It is using SPTD, a driver well-known to cause BSODs:
sptd.sys          Sun Oct 11 16:55:14 2009 (4AD24632)
a566jcm0.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
a866gcgo.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
audx55ef.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
ar5m2euj.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
abyymigq.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
ajg7chg2.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
a3h3akzj.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
aajyl3wm.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
azdxveez.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
abftif01.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
a40pu9gh.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
av4cydi6.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
avpxsx87.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
a2c5622g.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
awmin6j5.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
awv0shh2.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
a6f4ig7k.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
abo5kitf.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
auq5klq9.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
abxu38e8.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
abtbmz70.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
amkmrmp8.SYS      Tue Jul 14 17:12:55 2009 (4A5CF4D7)
Use this SPTD removal tool when you're done with the Daemon uninstall: http://www.duplexsecure.com/download/SPTDinst-v174-x64.exe
You have some out-of-date network card drivers, which may be contributing to Avast crashing.
athrx.sys         Fri Jun 05 18:10:06 2009 (4A2997BE)
What is the model of your network card? Perhaps one of us can locate some newer drivers for you.
Finally, your nForce networking drivers are out of date:
nvm62x64.sys      Fri Oct 17 17:01:06 2008 (48F8FD12)
Update them by installing a new nForce package, available here: Drivers - Download NVIDIA Drivers
...Summary of the dumps
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Debug session time: Fri Nov 12 03:31:02.313 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:14.077
Probably caused by : ntkrnlmp.exe ( nt!RtlImageNtHeaderEx+3f )
BUGCHECK_STR:  0x1E_c0000005
PROCESS_NAME:  Sf.bin
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!RtlImageNtHeaderEx+3f
Debug session time: Fri Nov 12 03:27:50.334 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:18.723
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+42837 )
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
FAILURE_BUCKET_ID:  X64_0x50_nt!_??_::FNODOBFM::_string_+42837
Debug session time: Fri Nov 12 02:52:01.881 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:05.270
Probably caused by : ntkrnlmp.exe ( nt!KxStartSystemThread+16 )
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID:  X64_0x7E_NULL_IP_nt!KxStartSystemThread+16
Debug session time: Fri Nov 12 02:48:32.871 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:04.650
Debug session time: Fri Nov 12 02:38:13.072 2010 (UTC - 5:00)
System Uptime: 0 days 0:08:04.852
Probably caused by : ntkrnlmp.exe ( nt!ObpCreateHandle+29a )
PROCESS_NAME:  firefox.exe
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!ObpCreateHandle+29a
Debug session time: Fri Nov 12 02:29:06.936 2010 (UTC - 5:00)
System Uptime: 0 days 0:06:53.325
Probably caused by : ntkrnlmp.exe ( nt!output_l+31b )
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!output_l+31b
Debug session time: Fri Nov 12 02:21:14.279 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:16.042
Debug session time: Fri Nov 12 02:18:02.064 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:42.843
Probably caused by : ntkrnlmp.exe ( nt!KeStackAttachProcess+115 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!KeStackAttachProcess+115
Debug session time: Fri Nov 12 02:13:53.153 2010 (UTC - 5:00)
System Uptime: 5 days 1:43:10.687
Probably caused by : ntkrnlmp.exe ( nt!KeStackAttachProcess+1ba )
BUGCHECK_STR:  0x1E_c0000096
FAILURE_BUCKET_ID:  X64_0x1E_c0000096_nt!KeStackAttachProcess+1ba
Debug session time: Fri Nov 12 02:13:52.576 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:57.355
BUGCHECK_STR:  0xA
Debug session time: Fri Nov 12 02:10:55.241 2010 (UTC - 5:00)
System Uptime: 0 days 0:07:52.020
Probably caused by : ntkrnlmp.exe ( nt!KeSetEvent+226 )
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_0xA_nt!KeSetEvent+226
Debug session time: Fri Nov 12 03:01:43.687 2010 (UTC - 5:00)
System Uptime: 0 days 0:08:34.466
PROCESS_NAME:  SkypeNames2.ex
Debug session time: Sun Nov  7 00:29:41.348 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:57.112
Probably caused by : ntkrnlmp.exe ( nt!KiTryUnwaitThread+28 )
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiTryUnwaitThread+28
Debug session time: Sun Nov  7 00:26:38.664 2010 (UTC - 5:00)
System Uptime: 0 days 8:35:55.443
Debug session time: Sat Nov  6 15:48:36.689 2010 (UTC - 5:00)
System Uptime: 8 days 1:59:48.722
Probably caused by : ntkrnlmp.exe ( nt!KeSetEvent+16 )
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID:  X64_0x50_nt!KeSetEvent+16
Debug session time: Fri Oct 29 13:47:44.694 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:57.083
PROCESS_NAME:  LSSrvc.exe
Debug session time: Thu Oct 21 21:01:45.444 2010 (UTC - 5:00)
System Uptime: 0 days 0:03:59.223
PROCESS_NAME:  svchost.exe
Debug session time: Thu Oct 21 20:56:34.335 2010 (UTC - 5:00)
System Uptime: 0 days 13:39:57.115
Debug session time: Thu Oct 21 00:39:31.580 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:04.969
PROCESS_NAME:  SearchIndexer.
Debug session time: Thu Oct 21 00:36:27.878 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:59.642
Debug session time: Thu Oct 21 00:33:23.713 2010 (UTC - 5:00)
System Uptime: 0 days 4:09:54.477
PROCESS_NAME:  PresentationFo
Debug session time: Mon Oct 18 22:17:47.713 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:34.476
BUGCHECK_STR:  0xA
[/FONT]
