formidable
- Joined
- Jan 9, 2011
To do a total cleanup of my laptop and reinstall Win 7 32bit.
It is a:
Dell Precision Mobile WorkStation M6400.
But a problem immediately with the error message:
"A key driver needed for CD - DVD drive is missing"
Then just my DVD / CD may malfunction (rails sometimes with CDs), I thought
the fault lay there.
Made a bootable usb, changed boot order via the F12 but may
exactly the same error message still
Googled around a bit and find many people who get the same error.
But this will then stop when I do not really understand what the problem is.
And have not found anyone who has a solution to the problem without more proposals for updating
Driver / business software for DVD / CD player (updated)
Others have suggested that you should disconnect the DVD / CD player entirely.
Someone speaks about the jumper.
Etc. ...
Now I know soon not sure how I should do anymore.
Is used to reformat / reinstall everything from 3.11 (a hundred years ago), Win 95, 98, ME, XP.
However, not Vista.
Much of the support is in English and here I get a little difficult with
Judgement technical terms .. unfortunately.
So the sum of my problem then is that I now sit with a bootable USB with Win 7 but will not be one meter ahead anyway.
I also have windows disc but it does not work.
What is known. malfunctioning unit should then be this, I think:
HLDS HLDS GS20N 9.5mm Slot Load DVDRW SATA
Firma Ware is uppdated.
Thanks in advance.
A//from Sweden
It is a:
Etc. ...
However, not Vista.
Thanks in advance.
A//from Sweden
