The experiment described by ZDNET — asking six popular AI assistants the same set of trick questions and watching every one produce at least one confident-but-false answer — is not a sensational outlier; it’s a precise, reproducible snapshot of a structural weakness in contemporary conversational AI. The ZDNET piece documents how simple “gotcha” prompts expose hallucination, inconsistent sourcing, and safety filter mismatches across widely used models. The pattern it describes matches wider independent audits and clinical warnings about real-world harm, and it shows why AI hallucination remains the single most important practicalical risk for everyday users and IT teams deploying assistants in workflows. review
The headline from ZDNET distilled a straightforward claim: six mainstream assistants were given identical trick prompts and each produced at least one fabricated or unreliable answer. Those outputs ranged from invented book titles and legal cases to mistaken film identifications and overactive safety responses for innocuous symbols. The test intentionally used the same wording and default settings across systems to isolate model-level behavior rather than UI or configuration differences.
This single-article an expanding body of independent checks and journalist-led audits showing similar failure classes. The European Broadcasting Union (EBU), coordinated with the BBC and 22 public broadcasters, evaluated thousands of news-related assistant replies and reported that roughly 45% of AI-produced news answers contained at least one significant issue — with serious sourcing problems in about 31% of responses. That audit concluded the behaviour is systemic across languages and platforms. Consumer testing from Which? reached a comparable practical conclusion in the consumer advice domain: six mainstream assistants (ChatGPT, Google Gemini/AIO, Microsoft Copilot, Meta AI and Perplexity) were given 40 realistic consumer prompts and scored by experts; Perplexity came out highest at 71% reliability while Meta AI scored 55%, and ChatGPT was rated around 64% — again highlighting large variance and non-trivial error rates for everyday advice. A medical case study completed this worrying chain: clinicians documented a 60‑year‑old man who developed bromide toxicity (bromism) after following AI-generated diet guidance; the incident was published in the clinical literature and widely reported by major outlets, showing that hallucinations can produce direct physical harm when users take generated text as actionable advice.
A futuristic neon holographic interface centered on a glowing question mark, surrounded by AI avatars.What ZDNET’s test shows (summary and verification)​
  • The test used short, adversarially chosen prompts that target common hallucination triggers: false premises, requests for rare facts, continuity checks in pop culture, and image-based identification produced at least one confidently stated falsehood — examples included fabricated bibliographies, a nonexistent court case described with procedural detail, and misidentified imagery.
  • The experiment’s methodology (identical wording, default settings) was aimed at isolating model behavior rather than product configuration, emphasizing a model-centric explanation for the failures.
These findings are consistent with the EBU/BBC and Which? audits: the problem is not confined to a single vendor or one-off prompt choices. Independent journalistic and consumer tests repeatedly find a non-trivial proportion of answers with serious accuracy or provenance problems, especially for facts, legal claims, medical guidance, and news summaries. Caveat: ZDNET’s test is short-form journalism, not a formal academic benchmark; it’s diagnostic and illustrative rather than statistically exhaustive. Nevertheless, its results align with larger, methodical audits — which strengthens the overall claim that hallucination is a widespread, reproducible failure mode.
Why these hallucinations happen: the technical anatomy​
At a high level, hallucination is a predictable outcome of how large language models are trained and evaluated. A recent research and engineering explanation from a leading model developer frames the root cause precisely: models are trained as next-token predictors on very large text corpora and are not taught, during pretraining, which statements are false. Evaluation regimes often reward confident answers rather than calibrated abstention, effectively incentivizing plausible guessing over honest uncertainty. That statistical and incentive structure explains why even advanced models continue to fabricate facts when the required verification signal is weak or absent. Key technical points:
  • Next-token prediction does not provide an internal “truth oracle.” Rare facts, low-frequency details, and niche citations are hard to reconstruct reliably from patterns alone.
  • Training and leaderboard incentives often reward completion and accuracy metrics that give models reason to attempt an answer rather than say “I don’t know.”
  • Retrieval and grounding layers (the systems that fetch up‑to‑date documents or database records) are brittle: when retrieval returns partial, stale, or noisy evidence, the generator will nonetheless synthesize a fluent final answer, sometimes weaving retrieved snippets into invented connective tissue.
  • Safety and content filters operate as separate heuristics; when misaligned with cultural or contextual nuance they can either over-block legitimate content or inject misleading safety messages.
This isn’t an unsolvable mystery — it’s an engineering problem with multiple interacting layers (retrieval, grounding, generation, evaluation, and incentives) that need better alignment.
Practical failure modes exposed by trick questions​
  • Confabulated references and bibliographies — plausible book or paper titles manufactured to satisfy a request.
  • Fabricated legal cases or statutes — detailed case captions and procedural histories that don’t exist but look authentic.
  • Temporal staleness — asserting current facts that are out of date because the model’s knowledge cutoff or retrieval layer returned obsolete sources.
  • Image misidentification and cultural-knowledge errors — failing to correctly identify well-known visual artifacts or symbols.
  • Overactive safety responses — treating benign symbols as crisis signals or misapplying refusal behaviors in context.
These failure classes have been repeatedly observed in larger audits (news and consumer tests) and in real-world clinical consequences such as the bromism case. Together they show why “answer-first” conversational interfaces are risky when used for consequential decisions.
Cross-referencing the big audits (context and validation)​
  • EBU / BBC cross-market audit: 3,000+ assistant replies across 14 languages, 45% with at least one significant issue; 31% with serious sourcing problems; specific vendors showed markedly different sourcing performance. This is an authoritative, multi-organizational dataset that reinforces the ZDNET diagnostic at scale.
  • Which? consumer test: 40 real-world consumer prompts, expert scoring on accuracy/relevance/ethical responsibility; Perplexity ranked top at 71% and Meta AI bottom at 55%. This test shows that even for accessible, everyday advice the error rate is material and varies by vendor and UI design.
  • Medical case reports and clinical harms: The documented bromism hospitalization shows translation from hallucinated text to physical harm when users enact AI suggestions without professional oversight; the clinical record and multiple news outlets corroborate the incident. That demonstrates the real-world stakes beyond reputational damage.
Taken together, these references provide independent, cross-validated evidence that hallucination is not a marginal bug but an engineering and safety problem with real consequences.
What works to reduce hallucination (approaches and trade-offs)​
Several practical engineering patterns can materially reduce hallucination risk when implemented thoughtfully. None is a silver bullet; each carries trade-offs in cost, latency, and infrastructure complexity.
  • Retrieval-Augmented Generation (RAG): ground answers on retrieved documents from a curated knowledge base or live web; include explicit citations and snippets. RAG reduces reliance on the model’s internal memory and enables verifiable outputs, but it depends critically on the quality and freshness of the retriever and on careful context selection.
  • Calibration and abstention: design models and evaluation metrics that reward saying “I don’t know” or asking for clarification instead of guessing. Engineering incentives and evaluation protocols must penalize confident falsehoods more heavily than admission of uncertainty. This is a central recommendation from recent internal research on hallucinations.
  • Provenance-first UIs: surface the source, timestamp, and an excerpt so users can verify claims quickly. Interfaces that prioritize transparency (links, short quotes, and clear labels) shift the default user behavior toward verification rather than implicit trust.
  • Human-in-the-loop (HITL) and domain gating: for legal, medical, or financial outputs restrict “final” suggestions to human review and route high-risk prompts to systems that use authoritative, specialist databases (LexisNexis, PubMed, official government datasets). This reduces automation risk but increases human cost and slows workflows.
  • Continuous monitoring and ModelOps: deploy production telemetry, red-team adversarial testing, and periodic audits to catch regressions after model updates or retrieval changes. Operational governance (ModelOps / AgentOps) is necessary to keep assistants within acceptable risk bands across releases.
Trade-offs: RAG and provenance add complexity, governance overhead, and compute cost. Abstention reduces apparent helpfulness on easy queries and mayesponsiveness. Strike a balance: for high‑stakes contexts prioritize grounding and human review; for low‑stakes creative tasks keep the model’s ideation strengths while making the limits explicit.
Practical advice for Windows users, IT teams, and power users​
  • Treat chat assistants as ideation and drafting tools, not authoritative sources. Use them for outlines, brainstorming, and rewriting — and always verify facts, citations, and legal or medical guidance before acting.
  • Prefer assistants and configurations that show provenance and timestamped sources for factual claims. When a response includes no link or excerpt, treat it as unverified.
  • For enterprise deployment, require RAG-based connectors to curated knowledge bases and implement explicit human checkpoints for any action that could have regulatory, legal, or safety consequences.
  • Add acceptance criteria to pilots: define measurable hallucination tolerances, test with adversarial “gotcha” prompts, and require a roadmap for provenance and audit logging before rolling assistants into workflows.
  • Maintain a verification workflow: 1) ask the assistant; 2) request sources or citations; 3) cross-check two independent authoritative sources; 4) escalate to specialist or legal counsel when required.
  • Train users: make internal guidance and quick-reference checklists required learning for staff who will use AI outputs in decisions. Habits matter: habitual verification reduces downstream risk.
Strengths in the current generation (what to credit)​
  • Dramatic fluency and productivity gains: assistants transform editing, drafting, and rapid synthesis tasks, often saving time for routine operations and creative work.
  • Improved UI affordances: some vendors have matured UIs that surface sources, support citation modes, and integrate retrieval — measurable steps that help users verify outputs faster.
  • Rapid progress on calibration: companies have published internal research and started rolling out models with lower hallucination rates or better abstention behaviors; this is encouraging and demonstrates that the problem is tractable with investment.
Persistent risks and open challenges​
  • Incentive misalignment: until evaluation and benchmarking systems penalize confident errors more than they reward accuracy-only metrics, models will continue to guess under uncertainty.
  • Retrieval poisoning and low-quality sources: RAG systems rely on retrievers; if those index low-quality or maliciously-seeded pages, grounded outputs can still be misleading.
  • UI-driven trust: fluent language and conversational tone create an automatic credibility bias. Users often treat assistant outputs as definitive, so small error rates translate into widespread misinformation.
  • Regulatory and legal exposure: fabricated legal citations or incorrect medical recommendations can create liability for organizations that rely on unverified assistant outputs in professional work.
  • Hard-to-detect fabrications: some hallucinations are subtle — invented but plausible case names, plausible-sounding studies, or altered quotes — and require domain expertise to detect. Recent newsroom audits found many such subtle errors.
A realistic roadmap for safer deployment (recommended sequence)​
  • Inventory use-cases and classify them by risk (low, medium, high).
  • For medium/high risk, require RAG, provenance surfacing, and human review gates.
  • Implement continuous ModelOps telemetry that tracks hallucination rates and sourcing failures.
  • Run adversarial “trick prompt” suites periodically (including false-premise, citation, and image tests) and require vendors to remediate high‑severity failures.
  • Train users and publish a clear internal policy that AI outputs must be verified for consequential decisions.
This sequence balances speed-to-value (for low-risk tasks) with enforced safeguards where the potential for harm is material.
ZDNET’s experiment — six assistants, identical trick prompts, and universal hallucination — is not clickbait; it is a compact, practical demonstration of a well-understood engineering challenge that shows up in consumer tests, large cross‑market audits, and even clinical case reports. The technical causes are known: next-token training, incentive structures in evaluation, brittle retrieval, and UI-driven trust. There are effective mitigations — RAG, provenance-first interfaces, abstention-aware training, HITL gates, and disciplined ModelOps — but they require sustained product investment and deliberate governance.
For Windows enthusiasts, IT decision-makers, and everyday users, the takeaway is simple: enjoy the productivity and creative lift from AI assistants, but assume outputs are provisional, verify before acting, and demand provenance where decisions matter. The current generation of assistants is powerful and improving, but until grounding and incentives are fixed across the stack, hallucination will remain the single most consequential limitation of conversational AI.
Source: ZDNET I asked six popular AIs the same trick questions, and every one of them hallucinated
