Windows 7 Alienware M17x R3 BSOD problem
davidthemaster3
Hi all,
After formatting my Alienware M17x R3, I started having DRIVER_POWER_STATE_FAILURE BSODs at seemingly random moments.
I was using the drivers on the dell website, so I updated to the most recent drivers.
My Windows 7 64 bits installation is up to date.
Recently, it happens everytime I try shutting down my laptop.
Thanks all,
David
All your dump files give:
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver.
All your dump files list pci.sys, the Windows NT Plug and Play PCI Enumerator drver as the probable cause.
For it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
All your dump files are unable to load symbols for your nVidia graphics drivers.
As a Priority:
nvlddmkm.sys Sat Oct 15 07:07:55 2011 nVidia Graphics Drivers.
Hi and Welcome to The Forum.
Usual causes:
Device driver
Your latest dump files list pci.sys as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
As a Priority:
dtsoftbus01.sys Fri Jan 13 13:45:46 2012 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved. But do not replace with Daemon Tools!!
May also be worth trying your Power Settings set at High Performance.
Then go to MsConfig.exe, click on the Start up tab, and decide how many of those don't really need to start with Windows as you are big enough to click on an icon to start them running when you need them.
Thanks for the reply!
My power settings are usually at high performance (I changed them to see if it helped my problem, but it did not).
I was also having BSODs before installing Daemon Tools Lite ... I uninstalled it anyways!
I cleaned up my startup tab ... I usually keep it minimal, but since switching to an SSD, it didn't change much for the boot up time.
So far, after the steps above, I managed to reboot it once without a BSOD ... on five tries!
Well after a few days, I am still having BSODs, although a less frequently.
I am uploading the most recent ones, which happened when the laptop was just rebooted and left there on until it happened (around 15 minutes tops).
Would it be possible to check the other .dmp files I uploaded to see if it's always the same reason for the crashes?
Thanks in advance.
Usual causes:
Device driver.
As a Priority:
  • Download and install DriverSweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
Drivers that pre-date Windows 7. Update:
EMSC.SYS Fri Jun 19 21:35:47 2009 Embedded System Control Windows Update. Unusual to find a Windows system driver that pre-dates Win 7, apart from good old secdrv.sys!
You have several Intel drivers that most likely have updates. Use the Link Removed (in Internet Explorer gives me the best results). Update any and all drivers available.
Drivers with Updates:
nusb3hub.sys Thu Feb 10 05:52:32 2011
nusb3xhc.sys Thu Feb 10 05:52:33 2011
Go to your Motherboard Mfr. Support website (or Link Removed - Invalid URL) and update your USB 3.0 drivers. A June 2011 set are available Here.
L1C62x64.sys Mon Sep 27 07:36:23 2010 #check if there is updates. Link Removed
Bugcheck Analysis:
[COLOR=#008000][B]BugCheck 9F[/B][/COLOR], {3, fffffa800722e060, fffff80001b5a3d8, fffffa800be70450}
[COLOR=#ff0000][B]Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys,[/B][/COLOR] Win32 error 0n2
*** WARNING: Unable to verify timestamp for[B][COLOR=#ff0000] nvlddmkm.sys[/COLOR][/B]
*** ERROR: Module load completed but symbols could not be loaded for [COLOR=#ff0000][B]nvlddmkm.sys[/B][/COLOR]
Probably caused by : [COLOR=#ff0000][B]pci.sys[/B][/COLOR]
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa800722e060, Physical Device Object of the stack
Arg3: fffff80001b5a3d8, Functional Device Object of the stack
Arg4: fffffa800be70450, The blocked IRP
Drivers:
fffff880`03da1000 fffff880`03db1000   Accelern Accelern.sys Fri Aug 20 19:04:57 2010 (4C6EC3C9)
fffff880`00edd000 fffff880`00f34000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03435000 fffff880`034be000   afd      afd.sys      Wed Dec 28 03:59:20 2011 (4EFA9418)
fffff880`03de0000 fffff880`03df6000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0121b000 fffff880`01226000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`03c00000 fffff880`03c36000   AMPPAL   AMPPAL.sys   Wed Oct 19 22:19:07 2011 (4E9F3ECB)
fffff880`015cd000 fffff880`015d6000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`015d6000 fffff880`01600000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff960`00840000 fffff960`008a1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00fa5000 fffff880`00fb1000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`03033000 fffff880`0303a000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03781000 fffff880`03792000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`1bfc0000 fffff880`1bfde000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`04412000 fffff880`04449000   bpenum   bpenum.sys   Sun May 16 15:28:26 2010 (4BF0010A)
fffff880`037b8000 fffff880`037ea000   bpmp     bpmp.sys     Sun May 16 15:28:36 2010 (4BF00114)
fffff880`079dd000 fffff880`079f7000   bpusb    bpusb.sys    Sun May 16 15:28:29 2010 (4BF0010D)
fffff960`007d0000 fffff960`007f7000   cdd      cdd.dll      unavailable (00000000)
fffff880`03000000 fffff880`0302a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cf8000 fffff880`00db8000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01dcd000 fffff880`01dfd000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c9a000 fffff880`00cf8000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`069b0000 fffff880`069b4500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`01000000 fffff880`01072000   cng      cng.sys      Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`00f9c000 fffff880`00fa5000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`03dd0000 fffff880`03de0000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`1a301000 fffff880`1a30a000   cpuz135_x64 cpuz135_x64.sys Wed Sep 21 09:23:41 2011 (4E799F0D)
fffff880`07853000 fffff880`07861000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`036e0000 fffff880`03763000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`03763000 fffff880`03781000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`036d1000 fffff880`036e0000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01db7000 fffff880`01dcd000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07987000 fffff880`079a9000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`07861000 fffff880`07874000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0303a000 fffff880`033dc000   dump_iaStor dump_iaStor.sys Mon Oct 17 23:54:08 2011 (4E9CB210)
fffff880`07874000 fffff880`07880000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`03aa8000 fffff880`03b9c000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`03b9c000 fffff880`03be2000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`01dad000 fffff880`01db7000   EMSC     EMSC.SYS     Fri Jun 19 21:35:47 2009 (4A3BF6A3)
fffff880`0113e000 fffff880`01152000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010f2000 fffff880`0113e000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0162c000 fffff880`01636000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01d73000 fffff880`01dad000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c54000 fffff880`01c9e000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`01c1b000 fffff800`01c64000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`03a56000 fffff880`03a7a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05fd2000 fffff880`05fe3000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`03644000 fffff880`0365d000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`078b9000 fffff880`078c1080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`078ab000 fffff880`078b9000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`1bef7000 fffff880`1bfc0000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d6a000 fffff880`01d73000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`069b5000 fffff880`069d3000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0122b000 fffff880`015cd000   iaStor   iaStor.sys   Mon Oct 17 23:54:08 2011 (4E9CB210)
fffff880`05415000 fffff880`05fd19a0   igdkmd64 igdkmd64.sys Wed Aug 31 20:53:13 2011 (4E5E9129)
fffff880`07800000 fffff880`07853000   IntcDAud IntcDAud.sys Fri Oct 15 09:28:17 2010 (4CB810A1)
fffff880`03dba000 fffff880`03dd0000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`1d8f1000 fffff880`1d920000   ipnat    ipnat.sys    Tue Jul 14 01:10:03 2009 (4A5BCCDB)
fffff880`069d3000 fffff880`069e2000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`01b84000 fffff800`01b8e000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`051b2000 fffff880`051f5000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01600000 fffff880`0161b000   ksecdd   ksecdd.sys   Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01955000 fffff880`01980000   ksecpkg  ksecpkg.sys  Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`079a9000 fffff880`079ae200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05400000 fffff880`05415000   L1C62x64 L1C62x64.sys Mon Sep 27 07:36:23 2010 (4CA03B67)
fffff880`037ea000 fffff880`037ff000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03600000 fffff880`03623000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c37000 fffff880`00c86000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`07880000 fffff880`0788e000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03d92000 fffff880`03da1000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`010d8000 fffff880`010f2000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`01a0e000 fffff880`01a3f000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`1a1d4000 fffff880`1a1e4000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`1bfde000 fffff880`1bff6000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`1be00000 fffff880`1be2d000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`1a28f000 fffff880`1a2dd000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`1a2dd000 fffff880`1a301000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01200000 fffff880`0120b000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`019c7000 fffff880`019d2000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f3d000 fffff880`00f47000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01152000 fffff880`011b0000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`036c6000 fffff880`036d1000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01d58000 fffff880`01d6a000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01802000 fffff880`018f5000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`06024000 fffff880`06030000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`1becc000 fffff880`1bedf000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`06030000 fffff880`0605f000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`044bc000 fffff880`044d1000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03548000 fffff880`03557000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`034be000 fffff880`03503000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`018f5000 fffff880`01955000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`06072000 fffff880`068fa000   NETwNs64 NETwNs64.sys Mon Oct 31 22:57:43 2011 (4EAF27E7)
fffff880`1d920000 fffff880`1d938000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`019d2000 fffff880`019e3000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`036ba000 fffff880`036c6000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`01c64000 fffff800`0224d000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01652000 fffff880`017f5000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0302a000 fffff880`03033000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`044a3000 fffff880`044bc000   nusb3hub nusb3hub.sys Thu Feb 10 05:52:32 2011 (4D537D20)
fffff880`0697d000 fffff880`069ae000   nusb3xhc nusb3xhc.sys Thu Feb 10 05:52:33 2011 (4D537D21)
fffff880`044e3000 fffff880`0515a000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`1be79000 fffff880`1becc000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`0350c000 fffff880`03532000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f87000 fffff880`00f9c000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f47000 fffff880`00f7a000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`0120b000 fffff880`0121b000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0161b000 fffff880`0162c000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`1a30a000 fffff880`1a3b0000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0794a000 fffff880`07987000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c86000 fffff880`00c9a000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`06000000 fffff880`06024000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`069e2000 fffff880`069fd000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`03a7a000 fffff880`03a9b000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`03be2000 fffff880`03bfc000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03669000 fffff880`036ba000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0605f000 fffff880`0606a000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`033f3000 fffff880`033fc000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`1d938000 fffff880`1d966000   rdpdr    rdpdr.sys    Sat Nov 20 11:06:41 2010 (4CE7ABC1)
fffff880`019b5000 fffff880`019be000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`019be000 fffff880`019c7000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`1d980000 fffff880`1d9b9000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`01d1e000 fffff880`01d58000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`1a01c000 fffff880`1a1d4000   rikvm_9EC60124 rikvm_9EC60124.sys Thu Apr 29 03:26:32 2010 (4BD8EE58)
fffff880`1bedf000 fffff880`1bef7000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06907000 fffff880`0695d000   RtsPStor RtsPStor.sys Fri Feb 11 13:21:07 2011 (4D5537C3)
fffff880`0695d000 fffff880`0697d000   sdbus    sdbus.sys    Sat Nov 20 09:37:42 2010 (4CE796E6)
fffff880`1a1e4000 fffff880`1a1ef000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01d0b000 fffff880`01d1e000   Soluto   Soluto.sys   Mon Feb 14 12:25:50 2011 (4D591F4E)
fffff880`01d03000 fffff880`01d0b000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`1d859000 fffff880`1d8f1000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`1a200000 fffff880`1a269000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`1a3b0000 fffff880`1a3e1000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`01cfa000 fffff880`01d03000   stdcfltn stdcfltn.sys Fri Aug 20 19:05:01 2010 (4C6EC3CD)
fffff880`078c7000 fffff880`0794a000   stwrt64  stwrt64.sys  Thu Mar 17 08:21:47 2011 (4D81C49B)
fffff880`03df6000 fffff880`03df7480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`03c37000 fffff880`03d92000   SynTP    SynTP.sys    Fri Oct 15 02:31:11 2010 (4CB7AEDF)
fffff880`01a50000 fffff880`01c54000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`1a000000 fffff880`1a012000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`019e3000 fffff880`019f0000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`1d966000 fffff880`1d971000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`011b0000 fffff880`011d2000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`035d4000 fffff880`035e8000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`004e0000 fffff960`004ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`1d971000 fffff880`1d980000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`03792000 fffff880`037b8000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04400000 fffff880`04412000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0788e000 fffff880`078ab000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`069ae000 fffff880`069aff00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`05fe3000 fffff880`05ff4000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04449000 fffff880`044a3000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`03a00000 fffff880`03a56000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`079af000 fffff880`079dc280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`03598000 fffff880`035d4000   VBoxDrv  VBoxDrv.sys  Mon Dec 19 12:43:53 2011 (4EEF3189)
fffff880`0515a000 fffff880`05184000   VBoxNetAdp VBoxNetAdp.sys Mon Dec 19 12:43:53 2011 (4EEF3189)
fffff880`05184000 fffff880`051b2000   VBoxNetFlt VBoxNetFlt.sys Mon Dec 19 12:43:51 2011 (4EEF3187)
fffff880`03572000 fffff880`03598000   VBoxUSBMon VBoxUSBMon.sys Mon Dec 19 12:43:53 2011 (4EEF3189)
fffff880`00f7a000 fffff880`00f87000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01a3f000 fffff880`01a4d000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01980000 fffff880`019a5000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01c9e000 fffff880`01cae000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00fb1000 fffff880`00fc6000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`0107c000 fffff880`010d8000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01cae000 fffff880`01cfa000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`068fa000 fffff880`06907000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03532000 fffff880`03548000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`1a1ef000 fffff880`1a1f9000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`03557000 fffff880`03572000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`019a5000 fffff880`019b5000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e2a000 fffff880`00ece000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ece000 fffff880`00edd000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03503000 fffff880`0350c000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00375000   win32k   win32k.sys   unavailable (00000000)
fffff880`03db1000 fffff880`03dba000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f34000 fffff880`00f3d000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`03623000 fffff880`03644000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`1f2cb000 fffff880`1f33c000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01a00000 fffff880`01a0e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0303e000 fffff880`033e0000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`033e0000 fffff880`033f3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes.
Thank you Elmer!
I successfully uninstalled the Nvidia driver and I installed the driver from the dell website (it's not the most recent, but if i start having BSODs I'll change later).
Also updated my Intel drivers.
Is there anything I have to do with the EMSC.SYS driver?
I couldn't find the usb driver on the renesas site and the one you linked doesn't work with mine (when i install it, the usb ports don't work).
There were no updates for the Atheros NIC.
Will update if all goes well!
Only make sure your system is fully up to date. Other than that it's a waiting game with MS.
Bummer!! :( Been to your laptop site and the drivers you have are newer than they are offering, so...
Was worth a try!! :)
Hi guys!
After a few I have still not had a BSOD! yeah! :D
Many thanks to Elmer for his support and help!
I would just like to add that before posting here, I had already tried reinstalling all my drivers, but without Driversweeper! I will definitely add it to my list of debugging apps! And I also used CCleaner, because it found a few Nvidia registry keys after Driversweeper!
Thanks again!
Thanks for the feedback and hope all stays well for you.
We hope to continue to see you around (under better circumstances!!).
Would I be allowed to post my Alienware m17x r3 BSOD crash file here? I don't want to ruffle feathers if I'm in the wrong area, I am new to posting error logs
