Another bsods :(
I just had my computer wiped and it was going well over a few weeks until I got this bluescreen:
Dump File : 071711-22448-01.dmp
Crash Time : 7/17/2011 5:01:16 PM
Bug Check String :
Bug Check Code : 0x00000124
Parameter 1 : 00000000`00000000
Parameter 2 : fffffa80`05cf3028
Parameter 3 : 00000000`b6004000
Parameter 4 : 00000000`b5000135
Caused By Driver : hal.dll
Caused By Address : hal.dll+12a3b
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7fd00
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\071711-22448-01.dmp
Processors Count : 6
Major Version : 15
Minor Version : 7601
Dump File Size : 292,544
Can anyone tell me whats wrong? and I also just installed a game (Battle of immortals) the night before It crased. Thanks
zigzag3143
Honorable Member
Microsoft MVP
Bug Check String :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Major Version : 15
To enable us to assist you with your computer's BSOD symptoms, upload the contents of your "\Windows\Minidump" folder.
The procedure:
* Copy the contents of \Windows\Minidump to another (temporary) location somewhere on your machine.
* Zip up the copy.
* Attach the ZIP archive to your post using the "paperclip" (file attachments) button.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
Elmer
Hi Adhit.
STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR
Usual causes:
Hardware, Incompatibility, May be driver corruption
Your latest dump file lists hardware as the probable cause.
You're getting a stop0x124, which means blame the hardware.
Stop 0x124 Checks
  • Ensure that none of the hardware is being overclocked.
  • Ensure that the machine is adequately cooled. Chase out those dust bunnies!
  • Make sure all hardware related drivers are up to date.
  • Possibly update the motherboard BIOS according to the manufacturer's instructions.
  • Always keep The Windows system itself up to date.
See this thread for additional pointers: Stop 0x124 - what it means and what to try
Some hardware tests you should be prepared to run:
Outdated Drivers. Update:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also comes with iTunes
Bugcheck Analysis:
BugCheck 124, {0, fffffa8005cf3028, b6004000, b5000135}
Probably caused by : hardware
Followup: MachineOwner
5: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005cf3028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6004000, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000b5000135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  left4dead2.exe
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`0308fb08 fffff800`0300ba3b : 00000000`00000124 00000000`00000000 fffffa80`05cf3028 00000000`b6004000 : nt!KeBugCheckEx
fffff880`0308fb10 fffff800`02b9d563 : 00000000`00000001 fffffa80`05af1010 00000000`00000000 fffffa80`05af1060 : hal!HalBugCheckSystem+0x1e3
fffff880`0308fb50 fffff800`0300b700 : 00000000`00000728 fffffa80`05af1010 fffff880`0308feb0 00000000`05474800 : nt!WheaReportHwError+0x263
fffff880`0308fbb0 fffff800`0300b052 : fffffa80`05af1010 fffff880`0308feb0 fffffa80`05af1010 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0308fd00 fffff800`02ffee8f : 00000000`05474810 00000000`00000001 fffff880`0308ff30 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0308fd40 fffff800`02a8e5ec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`0308fd70 fffff800`02a8e453 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0308feb0 00000000`1b1cec2f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`1733fe10 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x1b1cec2f
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: [COLOR=#ff0000][B]hardware[/B][/COLOR]
IMAGE_NAME:  [COLOR=#ff0000][B]hardware[/B][/COLOR]
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_AuthenticAMD_PROCESSOR_CACHE
Drivers:
fffff880`11d95000 fffff880`11dd3000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00ebd000 fffff880`00f14000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`0423c000 fffff880`042c5000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`11de3000 fffff880`11df9000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`06c79000 fffff880`06c8e000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00ead000 fffff880`00eb8000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`02dd6000 fffff880`02dde000   ASACPI   ASACPI.sys   Thu Jul 16 04:31:29 2009 (4A5E9F11)
fffff880`06c4d000 fffff880`06c53000   AsIO     AsIO.sys     Thu Apr 22 12:18:03 2010 (4BD0306B)
fffff880`08e85000 fffff880`08e8e000   aswFsBlk aswFsBlk.SYS Mon Jul 04 12:32:13 2011 (4E11A4BD)
fffff880`08e4b000 fffff880`08e85000   aswMonFlt aswMonFlt.sys Mon Jul 04 12:32:23 2011 (4E11A4C7)
fffff880`042c5000 fffff880`042cf000   aswRdr   aswRdr.SYS   Mon Jul 04 12:32:33 2011 (4E11A4D1)
fffff880`01000000 fffff880`01098000   aswSnx   aswSnx.SYS   Mon Jul 04 12:36:55 2011 (4E11A5D7)
fffff880`06c00000 fffff880`06c4d000   aswSP    aswSP.SYS    Mon Jul 04 12:36:52 2011 (4E11A5D4)
fffff880`011dd000 fffff880`011eb000   aswTdi   aswTdi.SYS   Mon Jul 04 12:35:26 2011 (4E11A57E)
fffff880`00e7a000 fffff880`00e83000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e83000 fffff880`00ead000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01689000 fffff880`01691000   AtiPcie  AtiPcie.sys  Tue May 05 16:00:22 2009 (4A005486)
fffff880`019f9000 fffff880`01a00000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`06daf000 fffff880`06dc0000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`06398000 fffff880`063b6000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`016c7000 fffff880`016f1000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d31000 fffff880`00df1000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01659000 fffff880`01689000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cd3000 fffff880`00d31000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0116b000 fffff880`011dd000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`11dd3000 fffff880`11de3000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`08fed000 fffff880`08ffb000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`06d0e000 fffff880`06d91000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`06d91000 fffff880`06daf000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`06cff000 fffff880`06d0e000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01643000 fffff880`01659000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0743d000 fffff880`0745f000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04385000 fffff880`043c8000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 08:27:08 2011 (4D2EB75C)
fffff880`08e0c000 fffff880`08e15000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`08e00000 fffff880`08e0c000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`08e15000 fffff880`08e28000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`08f9d000 fffff880`08fa9000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`02cd6000 fffff880`02dca000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`02c00000 fffff880`02c46000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`08fa9000 fffff880`08fdf000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`010f9000 fffff880`0110d000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010ad000 fffff880`010f9000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013cf000 fffff880`013d9000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01609000 fffff880`01643000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`018ff000 fffff880`01949000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`02cc5000 fffff880`02cd2000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`02ff9000 fffff800`03042000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`02c46000 fffff880`02c6a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`08f6e000 fffff880`08f87000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`08f87000 fffff880`08f8f080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`08f60000 fffff880`08f6e000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`08f53000 fffff880`08f60000   HPMo4DE3 HPMo4DE3.sys Wed Mar 09 02:44:43 2011 (4D76E99B)
fffff880`08f48000 fffff880`08f53000   HPub4DE3 HPub4DE3.sys Tue Apr 12 04:45:48 2011 (4DA3CAEC)
fffff880`062cf000 fffff880`06398000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01600000 fffff880`01609000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`02dde000 fffff880`02dfc000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`11d86000 fffff880`11d95000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bcc000 fffff800`00bd6000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`074d3000 fffff880`07516000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013a3000 fffff880`013be000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015af000 fffff880`015da000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`075dc000 fffff880`075e1200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`08e8e000 fffff880`08ea3000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`08e28000 fffff880`08e4b000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cb2000 fffff880`00cbf000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`08fdf000 fffff880`08fed000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`074c2000 fffff880`074d1000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`08f90000 fffff880`08f9d000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e10000 fffff880`00e2a000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`063b6000 fffff880`063ce000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`063ce000 fffff880`063fb000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`06200000 fffff880`0624e000   mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`01691000 fffff880`016b5000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01450000 fffff880`0145b000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f1d000 fffff880`00f27000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0110d000 fffff880`0116b000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`06cf4000 fffff880`06cff000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`019e7000 fffff880`019f9000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0145c000 fffff880`0154f000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`06de4000 fffff880`06df0000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`062a4000 fffff880`062b7000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04200000 fffff880`0422f000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`0759a000 fffff880`075af000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`04359000 fffff880`04368000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`042cf000 fffff880`04314000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0154f000 fffff880`015af000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`015e8000 fffff880`015f9000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`06ce8000 fffff880`06cf4000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02a10000 fffff800`02ff9000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`01200000 fffff880`013a3000   Ntfs     Ntfs.sys     Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`016f1000 fffff880`016fa000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`07528000 fffff880`07540000   nusb3hub nusb3hub.sys Fri Jan 22 03:22:18 2010 (4B5919EA)
fffff880`02c6a000 fffff880`02c9a000   nusb3xhc nusb3xhc.sys Fri Jan 22 03:22:21 2010 (4B5919ED)
fffff880`11d2b000 fffff880`11d30000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`075af000 fffff880`075dc000   nvhda64v nvhda64v.sys Tue May 10 10:41:18 2011 (4DC9083E)
fffff880`1107d000 fffff880`11d2b000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`06251000 fffff880`062a4000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`0431d000 fffff880`04343000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f67000 fffff880`00f7c000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f27000 fffff880`00f5a000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fed000 fffff880`00ff4000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e00000 fffff880`00e10000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013be000 fffff880`013cf000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0a490000 fffff880`0a536000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07400000 fffff880`0743d000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cbf000 fffff880`00cd3000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`06dc0000 fffff880`06de4000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`07461000 fffff880`0747c000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0747c000 fffff880`0749d000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0749d000 fffff880`074b7000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`06c97000 fffff880`06ce8000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`074b7000 fffff880`074c2000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01435000 fffff880`0143e000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0143e000 fffff880`01447000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01447000 fffff880`01450000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`019ad000 fffff880`019e7000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`062b7000 fffff880`062cf000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`11000000 fffff880`11070000   Rt64win7 Rt64win7.sys Mon Mar 21 13:20:32 2011 (4D8750A0)
fffff880`08ea7000 fffff880`08f20000   RTL8187B RTL8187B.sys Wed Mar 31 04:10:17 2010 (4BB2BD19)
fffff880`0a536000 fffff880`0a541000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`02dca000 fffff880`02dd6000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04368000 fffff880`04385000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`019a5000 fffff880`019ad000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0a84c000 fffff880`0a8e4000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0a584000 fffff880`0a5ed000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0a541000 fffff880`0a572000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`074d1000 fffff880`074d2480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`016fb000 fffff880`018ff000   tcpip    tcpip.sys    Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`0a572000 fffff880`0a584000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01098000 fffff880`010a5000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`013d9000 fffff880`013fb000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`043e3000 fffff880`043f7000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`004d0000 fffff960`004da000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`06c53000 fffff880`06c79000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`0a8e4000 fffff880`0a939000   udfs     udfs.sys     Sat Nov 20 09:26:11 2010 (4CE79433)
fffff880`07516000 fffff880`07528000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`02c9a000 fffff880`02c9bf00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`02cb4000 fffff880`02cc5000   usbehci  usbehci.sys  Sat Nov 20 10:43:54 2010 (4CE7A66A)
fffff880`02c9c000 fffff880`02ca9000   usbfilter usbfilter.sys Tue Dec 22 08:26:22 2009 (4B3082AE)
fffff880`07540000 fffff880`0759a000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`02ca9000 fffff880`02cb4000   usbohci  usbohci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`11d30000 fffff880`11d86000   USBPORT  USBPORT.SYS  Sat Nov 20 10:44:00 2010 (4CE7A670)
fffff880`08f2d000 fffff880`08f48000   USBSTOR  USBSTOR.SYS  Sat Nov 20 10:44:05 2010 (4CE7A675)
fffff880`00f5a000 fffff880`00f67000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`015da000 fffff880`015e8000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`08a3e000 fffff880`08bef000   viahduaa viahduaa.sys Tue Mar 02 11:30:18 2010 (4B8CF6CA)
fffff880`01400000 fffff880`01425000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e2a000 fffff880`00e66000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01949000 fffff880`01959000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00f7c000 fffff880`00f91000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f91000 fffff880`00fed000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01959000 fffff880`019a5000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`08f20000 fffff880`08f2d000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`04343000 fffff880`04359000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`043c8000 fffff880`043e3000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01425000 fffff880`01435000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00df1000 fffff880`00e00000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`04314000 fffff880`0431d000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00333000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff880`00e66000 fffff880`00e7a000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`11070000 fffff880`11079000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f14000 fffff880`00f1d000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`08a00000 fffff880`08a21000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`0a939000 fffff880`0a96a000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`0a96a000 fffff880`0a9db000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01691000 fffff880`0169f000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0169f000 fffff880`016ab000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`016ab000 fffff880`016b4000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`016b4000 fffff880`016c7000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes.
Hi Adhit.
Usual causes:
Stop 0x124 Checks
Bugcheck Analysis:
5: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL:  f
STACK_TEXT:
STACK_COMMAND:  kb
MODULE_NAME: [COLOR=#FF0000][B]hardware[/B][/COLOR]
IMAGE_NAME:  [COLOR=#FF0000][B]hardware[/B][/COLOR]
Drivers:
Unloaded modules:
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
Alright thanks for helping out. I'll let you know about how my computer is doing in a few days. Thanks again
If its windows 7 here!
This is how to Fix Windows 7 BSOD.
Restart the computer and keep pressing F8 until the "Advance Boot Options" menu comes up.
Use up and down arrow buttons to navigate the menu, select "Safe Mode" and hit Enter
This time you won't see the computer blue screen error.
When the welcome screen comes up select Administrator and enter administrator's password(if you have one).
Click on the START button and navigate to the Accessories folder. There you will see a folder entitled "System Tools," navigate to that folder and click on System Restore.
In the System Restore program, make sure "Restore my computer to an earlier time" is selected and click NEXT.
Choose a date on the calendar that you want to restore your computer and click NEXT.
The last page of the System Restore will pop up with your date that you have chosen and click NEXT. The system will reboot and the computer blue screen will be gone
Hope This Helps!
nmsuk
Windows Forum Admin
#7
Could you get CPU-Z and post pictures from each of the tabs please. I've seen this error on AMD systems if something is undervolted or a bios misconfiguration.
Pictures of all your settings in the bios would also be useful if at all possible.
#8
Hey Guys It happened again! I downloaded the update Elmer suggested and it occured today while I was listening to music and playing Left 4 dead 2. Here is the dumpfile. View attachment 071811-22947-01.zip I really am starting to get tired of this I'm not sure what's wrong I do not have anything overclocked and I have a good airflow case. I also recently cleaned out the dust from my Haf 932 soo I'm not sure what's up. Please help and thanks
#9
OKay here they are:
and if you need to download them, I have the link. View attachment CPUZ.zip
nmsuk
Windows Forum Admin
#10
I see one problem can you set your command rate for your memory to 2T and see how it goes.
#11
I'm sorry but could you explain on how to do that? and to the other question about my BIOS, I've set everything to auto because I'm not good messing with that stuff. Thanks.
nmsuk
Windows Forum Admin
#12
What make and model is you motherboard? Once I have this info I'll check your mobo manual and we'll have it changed.
#13
Okay my mobo is Asus and its model is m4a87td evo AM3 socket and if you need to find it on the Asus website its this:http://www.asus.com/Motherboards/AMD_AM3/M4A87TD_EVO/
Also, I really appreciate you helping me out. I tried the Ibuypower forums and they have not answered me in weeks so I kinda gave up on thme haha. Thanks
nmsuk
Windows Forum Admin
#14
Cheers, If you go into your bios and go to AI Tweaker there should be Dram timing configuration. Near the bottom of the page there should be Command Rate, it's probably set to auto can you set it to 2T and see how your machine behaves.
#15
Thank you very much! I just changed it to 2T like you said and will give an update on how my system is doing later on. Thanks again :D
nmsuk
Windows Forum Admin
#16
Good luck. I've seen that misconfiguration quite a lot recently.
#17
ARGH another BSod it looks like its the same as the last one and this happened when my brother was playing Left 4 dead. So i'm thinking its left 4 dead 2 that's causing it but I'm not sure. here is the dump file: View attachment 071811-23384-01.zip
Thanks
zigzag3143
Honorable Member
Microsoft MVP
#18
ARGH another BSod it looks like its the same as the last one and this happened when my brother was playing Left 4 dead. So i'm thinking its left 4 dead 2 that's causing it but I'm not sure. here is the dump file: View attachment 15353
Thanks
Your .dmp file shows a stop error of 0x124 which is a general hardware error .
A "stop 0x124" is fundamentally different to many other types of bluescreens because it stems from a hardware complaint.
Stop 0x124 minidumps contain very little practical information, and it is therefore necessary to approach the problem as a case of hardware in an unknown state of distress.
You can read more on this error and what to try here... Stop 0x124 - what it means and what to try Stop 0x124 - what it means and what to try - Windows 7 Forums
#19
I've tried the Ram test and I ran it for 3-4 hours and it say it passed. I tried my CHKDSK/R and it said that no bad files were found. I've did this previously before I reinstalled windows a few months ago. I had soo many bluescreens and It turned out to be my software I had installed or something so I reinstalled windows then. I still get bluescreens even after the stress test and I stress tested on the 2nd bluescreen. The third just occured today.
#20
My friend suggested that it could be my mobo chipset, and I have no idea what that is. But could it be my motherboard that is the cause of this? I personally doubt it since i crash only playing l4d2 soo idk.
