ARCTIC Senza Under-Desk PC: Silent Power Meets Sleek Design
ARCTIC’s latest foray into PC design is turning the traditional desktop on its head—literally. The new Senza Under-Desk PC is an innovative, fully passive-cooled system that slips discreetly under your workstation, leaving your desk pristine and uncluttered. But beneath its stealthy exterior lies a powerhouse engineered for modern multitasking and seamless Windows experiences.
A sleek, modern external hard drive enclosure sits on a wooden desk in low light.
Under-Desk Design: Hiding in Plain Sight​
In an era where workspace aesthetics and efficiency are paramount, the Senza marks a refreshing departure from conventional tower PCs. Resembling a sleek network switch, its low-profile design gives it an almost industrial chic appeal. With dimensions reported as roughly 282mm by 618mm and a height of about 120mm (and an estimated thickness of around 1.5 inches), the Senza is built to be unobtrusive while still packing a robust set of features.
Imagine an office where your computing powerhouse is tucked away out of sight, yet accessible whenever you need it. The design philosophy here is clear: reclaim valuable desk real estate without sacrificing performance. This sleek form factor is especially attractive for users who prize both aesthetics and functionality in their workspaces.
Key takeaways:
  • Unique, low-profile design mimicking a network switch
  • Tucks away easily beneath your desk to create a clutter-free environment
  • Ideal for modern offices and minimalist home workspaces
Inside the Senza: Performance and Hardware Specifications​
At its core, the Senza is powered by AMD’s Ryzen 5000G series of processors—a known favorite among Windows users who demand both efficiency and power from their systems. Whether you're handling everyday office tasks or more demanding multimedia applications, the Senza is built to deliver a smooth, responsive computing experience.
Processor Options and Memory Configuration​
ARCTIC is offering the Senza with a choice of three AMD APU options:
  • Ryzen 5 5500GT
  • Ryzen 7 5700G
  • Ryzen 5700G Pro
This selection means you can balance power consumption with performance tailored to your specific work requirements. Each processor in the Ryzen 5000G series is designed to handle multitasking with aplomb, supporting applications ranging from productivity suites to multi-monitor setups.
Additionally, the system is outfitted with:
  • 32GB of DDR4 memory, ensuring ample multitasking capability
  • A 1TB NVMe SSD, which offers lightning-fast storage performance and rapid boot times
Integrated Graphics and Multi-Monitor Support​
Thanks to Ryzen’s integrated graphics, the Senza supports configurations of up to four monitors. For Windows users, this means an expansive digital workspace—ideal for those working with complex spreadsheets, design applications, or simply juggling multiple projects at once.
The multi-monitor support isn’t just a flashy specification—it's a practical solution for enhancing productivity, particularly in environments where screen real estate directly correlates with efficiency.
A Silent Workhorse: The Passive Cooling Advantage​
One of the most compelling features of the Senza is its commitment to silence. In many offices and home environments, the constant hum of cooling fans can be a persistent distraction. ARCTIC’s solution? Eliminate the fans altogether.
How Passive Cooling Works in the Senza​
In lieu of active cooling components, the Senza employs a massive heatsink along with strategically placed copper heat pipes to dissipate heat naturally. This design provides several significant benefits:
  • Completely silent operation for undisturbed concentration
  • Fewer moving parts, which translates to potentially longer system longevity and reliability
  • Improved energy efficiency as the system consumes less power compared to its fan-cooled counterparts
For users already enamored with the quiet efficiency of their Windows 11 desktops, this approach aligns perfectly with the growing demand for quieter, more energy-efficient work environments.
Smart Connectivity and Cable Management​
A common grievance with desktop PCs is the notorious cable clutter that ensues. ARCTIC has tackled this issue head-on with a thoughtfully engineered connectivity solution.
Connectivity Panel: Out of Sight, Yet At Hand​
The Senza diverges from convention by relocating some of its connectivity ports to a dedicated panel that attaches underneath your desk. This panel hosts:
  • USB Type-A and USB Type-C ports for peripherals and data transfer
  • A headphone jack for audio connectivity
  • Power and reset buttons to maintain system control without crowding your desk
Simultaneously, additional connectivity options are available at the back of the PC. These include:
  • 2x USB 3.2 and 2x USB 2.0 ports
  • An audio in/out jack for comprehensive sound management
  • HDMI 2.0 and DisplayPort 1.2 outputs, supporting clear video connectivity for multi-monitor setups
Such design decisions not only enhance the visual appeal of your workspace but also streamline cable management. For those engaged in detailed Windows 11 setups—where a tidy, organized desk often reflects a sharp, focused mind—this is a notable bonus.
Windows 11 N: A Tailored OS Experience​
One intriguing aspect of the Senza is its operating system configuration. Geared primarily for the EU region, the device comes pre-installed with either Windows 11 Home N or Pro N. These versions lack certain media apps like Windows Media Player and Skype by default. However, the gap is easily bridged using Microsoft’s Media Feature Pack.
What This Means for Windows Users​
  • The N editions are optimized for professional environments where media consumption might be secondary to productivity.
  • Windows users can still enjoy all essential productivity tools and benefit from regular Windows 11 updates and Microsoft security patches, ensuring the system remains secure and up to date.
  • For users who require media functionality, downloading the Media Feature Pack is a straightforward process that enriches the OS with all the familiar media features.
In many modern offices, distraction-free environments are critical. A system that nips unwanted background noise (both in terms of fan noise and unnecessary media distractions) right in the bud can help maintain focus, whether you’re on a video conference call or immersed in the latest Windows cybersecurity advisories.
Applications and Use Cases: From Personal to Commercial​
The design and performance characteristics of the Senza make it versatile enough for a wide range of applications:
Ideal for Modern Offices​
For corporate and home offices alike, the Senza’s under-desk design and silent operation promote a clean, professional workspace. Imagine a busy executive’s desk where every inch of space counts and distractions are minimized. The Senza provides:
  • A clutter-free desktop environment
  • Discreet performance to support productivity applications
  • The capability to drive multiple monitors, perfect for multitasking professionals
Tailored for Creative Professionals and Developers​
Windows users in creative fields or software development often require multiple screens to manage different facets of complex projects. The multi-monitor support and robust processing power make the Senza an attractive option for this demographic.
A Dual-Purpose Solution​
Whether for personal use at home or as a fitting addition to a commercial workstation, the Senza bridges the gap between performance and design. Its passive cooling ensures that even during heavy usage, the environment remains undisturbed by distracting mechanical noises.
Setting Up Your Senza: A Step-by-Step Glimpse​
For those intrigued by the novel design, setting up the Senza is designed to be as intuitive as possible. Here’s a brief overview of what you might expect:
  • Position the Senza on a flat surface beneath your desk.
  • Attach the dedicated connectivity panel to the underside near the front of your desk for easy access.
  • Connect your peripherals to the panel and back I/O ports as needed.
  • Power on the device and initiate the Windows 11 installation/setup (or configure your pre-installed version).
  • Enjoy a seamless blend of performance with a clutter-free workspace.
This plug-and-play approach means that even users who are not averse to conventional tower PCs will find the transition refreshingly simple.
The Broader Implications for the PC Market​
ARCTIC’s foray into the under-desk PC market signals potential shifts in workstation design. With the rise of remote work and heightened emphasis on ergonomics and workspace efficiency, such innovations address long-standing concerns about desktop clutter and noise pollution.
Future Trends in PC Design​
  • As more professionals adopt hybrid work environments, products like the Senza could become integral to crafting ergonomic, streamlined office spaces.
  • The silent operation coupled with energy-efficient passive cooling might inspire further developments in quiet PC builds, influencing both personal and business computing.
  • Manufacturers may increasingly prioritize designs that blend form with function—a sentiment echoed by enthusiasts who follow Windows 11 updates and cybersecurity advisories to ensure their systems remain both efficient and secure.
Furthermore, the integration of passive cooling and refined cable management presents a compelling argument for rethinking how we design computer systems in the age of digital transformation.
Expert Perspectives: A Tactical Balance of Style and Function​
Industry experts note that the Senza is more than just a novelty—it’s a practical answer to modern computing challenges. The elimination of traditional fans not only reduces maintenance concerns but also minimizes the risk of mechanical failure over time. For business environments where uptime and reliability are critical, a PC that operates silently and efficiently offers both a productivity boost and long-term cost-saving benefits.
Experts also highlight that as Windows 11 continues to evolve—with regular updates and patches ensuring robust security—the Senza’s hardware can support even the most demanding tasks. From creative design software to enterprise-level applications, the Senza’s coupling of AMD Ryzen 5000G power with a silent, unobtrusive design resonates well with the current trends in minimizing digital and physical clutter.
Summarizing the Key Advantages​
To encapsulate the benefits of the ARCTIC Senza under-desk PC for Windows users:
  • Sleek under-desk design creates an uncluttered workspace that is both modern and practical.
  • Robust processors from the AMD Ryzen 5000G series ensure smooth, efficient performance.
  • Fully passive cooling eliminates the distractions of noisy fans, making it ideal for quiet offices and home workstations.
  • Comprehensive connectivity, with a dedicated under-desk panel and rear ports, supports flexible peripheral setups.
  • Pre-installed with Windows 11 Home/Pro N, it aligns with modern security and productivity needs while accommodating optional media enhancements.
  • Supports multi-monitor configurations, ideal for professionals who need expansive, organized digital workspaces.
Final Thoughts​
ARCTIC’s Senza Under-Desk PC represents a bold reimagining of desktop computing. With its unique design, silent operation, and robust performance, it stands out as a solution tailored not only for the modern office but also for the enthusiastic Windows community. While the market eagerly awaits pricing details and official availability dates, the Senza already hints at a future where offices can stay both stylish and efficient—without a single noisy fan to break the silence.
For those keeping an eye on Windows 11 updates and seeking to enhance their work environment with a noiseless, clutter-free solution, the Senza is a story worth following closely. As ARCTIC steps beyond its traditional cooling expertise and delves into full-system design, users can look forward to a new chapter in PC innovation that marries cutting-edge performance with a revitalized focus on aesthetics and ergonomics.
Whether you’re a Windows power user navigating the latest Microsoft security patches or a professional striving for the ultimate minimalistic setup, the ARCTIC Senza is poised to make a significant impact on how we envision our workspaces in the 21st century.
Source: Wccftech ARCTIC Debuts Senza "Under-Desk" PC: A Noiseless Solution For Offices That Hides From Sight
