Azure Linux CVE-2025 38041 Attestation and Per Artifact Risk
Cloud security diagram featuring Linux penguin, CVE/CSAF/VEX badges, and product attestation icons.
The short answer is: No — Azure Linux is not necessarily the only Microsoft product that includes the sunxi‑ng h616 clock code and is therefore potentially affected; it is the only Microsoft product Microsoft has publicly attested so far to include the upstream component for CVE‑2025‑38041, and that attestation should be treated as authoritative for Azure Linux while other Microsoft artifacts remain unverified until Microsoft expands its CSAF/VEX attestations or until operators perform per‑artifact inspections.
Background / Overview​
CVE‑2025‑38041 is a Linux kernel fix in the sunxi‑ng clock driver for the Allwinner H616 SoC family. The upstream patch corrects how the GPU PLL and its parent clock are changed during frequency transitions so device dynamic voltage and frequency scaling (DVFS) does not cause panfrost (GPU) oopses and GPU hangs. The technical change re‑parents the GPU clock to a safe parent during frequency changes, reusing an algorithm already used by CPU PLL notifier code. The vulnerability has been cataloged by multiple vulnerability trackers and distribution advisories. This is primarily an availability/robustness fix: the practical symptom is deterministic GPU crashes or hangs when DVFS is attempted on affected hardware and driver builds. Public trackers and distro advisories classify the impact as a local, hardware‑specific DoS risk rather than an obvious remote code‑execution or privilege escalation vector. However, for systems that run user workloads that can exercise the GPU driver (embedded devices, single‑board computers, or cloud VM images that target SoC hardware or emulation), these failures are operationally serious. Microsoft’s public advisory language for the CVE says, in effect, that “Azure Linux includes this open‑source library and is therefore potentially affected,” and it also explains Microsoft’s recent rollout of machine‑readable CSAF/VEX attestations (starting with Azure Linux) and the company’s commitment to update CVE records if additional Microsoft products are later identified to include the same upstream component. That phrasing is deliberate: it is a product‑scoped attestation, not a vendor‑wide inventory statement.
What the MSRC sentence actually means (precise reading)​
Microsoft’s wording — that Azure Linux includes this open‑source library and is therefore potentially affected — should be read in two parts:
  • Authoritative attestation for a named product: Microsoft has completed an internal inventory for the Azure Linux distribution (the Microsoft‑maintained Linux images) and found the upstream sunxi‑ng code present in those artifacts; therefore Azure Linux images are a confirmed, in‑scope product that must be remediated according to Microsoft’s guidance.
  • Not a universal exclusion for every Microsoft artifact: the sentence does not assert that no other Microsoft product can or does contain the same upstream code. Absence of a product name from Microsoft’s VEX/CSAF feed is absence of attestation, not proof that the product is unaffected. Microsoft’s VEX rollout began as a phased, product‑by‑product program (Azure Linux first); the company has committed to expand attestations as inventory work continues.
Put simply: Microsoft is telling Azure Linux customers “we checked this product and it includes the code,” and promising to tell you about other products when they finish checking them — but it is not telling you that other Microsoft images are already clean.
Why attestation scope matters: kernel artifact differences are decisive​
Whether a given product is affected by a kernel CVE depends on three concrete, verifiable facts:
  • Kernel version: does the kernel binary include the upstream commit range that introduced or fixed the bug? Fixed releases and stable backports determine whether a given kernel tree is vulnerable.
  • Kernel configuration (build‑time CONFIG_* flags): kernel features and drivers (for example, sunxi‑ng, amdgpu, ivpu, etc. are enabled or disabled at build time; two kernels built from the same source can differ dramatically depending on which drivers were compiled in or built as modules.
  • Vendor backports and packaging choices: vendors commonly backport selective upstream fixes into older kernel branches; the presence of a commit in a vendor kernel is therefore determined by packaging/backport decisions rather than purely by upstream version numbers.
Because these three axes vary per artifact (WSL kernel, linux‑azure kernels used by some VM SKUs, Marketplace images, Azure Linux images, partner appliances, IoT/Edge artifacts), the only correct way to determine exposure is per‑artifact verification — either the vendor publishes a machine‑readable attestation for that artifact (CSAF/VEX) or the operator inspects the kernel binary and its configuration. Microsoft’s Azure Linux attestation is authoritative for that product family, but does not eliminate the need for artifact checks elsewhere.
Cross‑checking the technical facts (independent verification)​
Key technical facts in this advisory are confirmed by independent public trackers:
  • NVD (the US NIST National Vulnerability Database) contains the CVE summary describing the sunxi‑ng h616 reparenting change and the problem it addresses.
  • Debian’s security tracker and the Debian package status table list affected kernel package versions and the fixed upstream commits, providing a distribution perspective on which releases are vulnerable or patched.
  • SUSE and other distro advisory pages provide a severity assessment and the vendor’s own backport/fix status for the CVE, giving a third independent confirmation of the nature and impact of the change.
Cross‑referencing NVD plus at least one distribution tracker (Debian or SUSE) is a practical minimum to validate that the CVE description and fixed commits are accurate for an operational triage. Use those two independent sources to map a kernel binary’s release string or package version to the commit ranges cited as “fixed.”
Is Azure Linux the only Microsoft product that could include the sunxi‑ng code?​
Short answer: No — but currently Azure Linux is the only Microsoft product Microsoft has publicly attested to include the component for CVE‑2025‑38041. That nuance is important for defenders:
  • Attested = Azure Linux. Microsoft has published a product‑level attestation for Azure Linux; act on it immediately for any Azure Linux instances you run.
  • Possible carriers = many Microsoft artifacts. Any Microsoft artifact that ships or runs a Linux kernel build could, in principle, include the same sunxi‑ng h616 code — for example, WSL2 kernels, linux‑azure kernel packages used by certain VM SKUs, Azure Marketplace images that include a kernel, and specialized appliances or IoT images Microsoft maintains. Each of those artifacts must be validated individually until Microsoft expands its VEX/CSAF attestations.
Operationally, treat Azure Linux as “Known‑Potentially Affected” and treat other Microsoft artifacts as “Unknown” until you verify them.
Practical, verifiable steps for defenders (runbook)​
Below is a concise, reproducible runbook you can hand to a Linux/Cloud engineering team to triage Microsoft artifacts in your estate. Follow these steps in order.
  • Prioritize Azure Linux images (apply fixes).
  • If you run Microsoft‑published Azure Linux images, update to Microsoft’s patched Azure Linux kernel images or apply the distribution patches Microsoft recommends. Azure Linux is the only Microsoft product attested so act quickly.
  • Inventory all Microsoft Linux artifacts you run.
  • Examples to check: WSL2 clients in developer machines, linux‑azure kernels used by Azure VMs, Azure Marketplace VM images (Microsoft‑published), AKS node images that include Microsoft kernels, IoT/Edge images maintained by Microsoft, partner appliances distributed via Microsoft Marketplace.
  • For each artifact, perform these verification steps on a representative host or image:
  • Show kernel release: uname -r
  • List kernel modules and check for sunxi‑ng (or related SoC driver paths): lsmod | grep sunxi || true
  • Inspect /lib/modules/$(uname -r)/kernel for the driver path: ls /lib/modules/$(uname -r)/kernel/drivers/clk/ | egrep -i 'sunxi|h616' || true
  • Check kernel config for relevant flags: zcat /proc/config.gz 2>/dev/null | egrep -i 'CONFIGSUNXI|CONFIGCLK' || grep -i 'CONFIG_CLK' /boot/config-$(uname -r) 2>/dev/null
  • If you cannot boot the image, unpack the kernel package or image and inspect the modules directory and kernel config offline.
  • Map the kernel release/config to upstream fixed commits:
  • Compare the kernel version/release string to the fixed commit ranges published by upstream and tracked in NVD/Debian/SUSE. If the kernel predates the fix and includes the driver, plan to update/replace with a fixed kernel.
  • Apply mitigations where patching is delayed:
  • Restrict access to exposed GPU interfaces (for example /dev/dri/*) by tightening device permissions or using device ACLs.
  • Avoid exposing GPU passthrough or device nodes to untrusted containers and CI runners.
  • For multi‑tenant hosts, limit who can perform DVFS or load device‑specific modules; if possible, disable automatic GPU DVFS until patched. (Note: these mitigations vary by platform and may not be applicable for all SoC devices.
  • Subscribe to Microsoft VEX/CSAF and MSRC updates:
  • Microsoft has begun publishing VEX attestations (Azure Linux was the initial product); subscribe to those feeds and to the vendor’s CVE page for updates indicating any expansion of product coverage.
  • Re‑scan and re‑validate after vendor updates:
  • When Microsoft expands the VEX attestation set or publishes a “Known‑Affected → Fixed” status for any product, re‑validate your inventory and apply fixes where applicable.
Risk analysis: strengths and remaining gaps​
Strengths
  • Microsoft’s move to publish machine‑readable CSAF/VEX attestations (Azure Linux first) is a real improvement for automation and triage: it gives customers a precise, authoritative signal for the product Microsoft has inspected. This reduces noisy triage and helps automation determine when a hosted image is known‑affected.
  • The upstream kernel fix for CVE‑2025‑38041 is limited and straightforward (a clock reparenting and notifier use); that makes backports and vendor updates easier to produce and distribute. Multiple distributions already mapped the fix into stable releases.
Risks and gaps
  • Attestation coverage lag: large vendors ship hundreds of distinct kernel artifacts and images; a phased VEX rollout inevitably leaves many artifacts “not yet attested,” creating an operational gap where absence of an attestation is often misread as “not affected.” Security teams need to avoid that assumption.
  • Artifact heterogeneity: the same kernel code can or cannot be present depending on CONFIG flags and packaging. Without per‑artifact checks or expanded vendor attestations, it’s risky to assume items like WSL2 kernels, linux‑azure images, or Marketplace images are safe.
  • Embedded device update constraints: the CVE affects SoC‑class devices where vendor update cycles can be slow (OEMs may lag upstream fixes). For embedded fleets (edge devices, single‑board computers), supply‑chain and OTA constraints are the main operational barrier to rapid remediation. Distribution advisories show which release lines have fixes and which remain vulnerable.
How to consume Microsoft’s VEX/CSAF outputs correctly​
Microsoft’s public blog explains the intent and mechanics of the VEX rollout: machine‑readable attestations reduce ambiguity by declaring, per product artifact, whether the vendor considers it Not Affected / Under Investigation / Known Affected / Fixed. Microsoft began publishing VEX attestations starting with Azure Linux in October 2025 and will expand to additional products over time. Use the vendor’s VEX output as the canonical automation signal for the product(s) it names — but do not treat “not listed” as “not affected.” Best practices for consuming VEX/CSAF:
  • Automate ingestion of the vendor’s CSAF/VEX feed and map attestations to specific artifact IDs you run (image hashes, package versions, kernel release strings).
  • Treat each VEX attestation as authoritative only for the product it names.
  • Maintain a parallel artifact inventory process (SBOMs, image unpack and grep, runtime checks) to cover artifacts vendors haven’t yet attested.
Final verdict and recommended actions (concise)​
  • Azure Linux: treated as Known‑Potentially Affectedpatch now according to Microsoft’s guidance.
  • Other Microsoft products and artifacts (WSL2 kernel, linux‑azure kernels, Marketplace images, AKS node images, IoT/Edge images): treat as “unknown” until Microsoft publishes a VEX/CSAF attestation for the product or until you verify the artifact yourself. Do not assume “not listed = safe.”
  • Operational checklist:
  • Patch Azure Linux images immediately.
  • Inventory and verify all Microsoft kernels and images you run.
  • Apply mitigations where patching is not immediate (restrict /dev/dri, limit DVFS control, isolate hosts).
  • Subscribe to Microsoft VEX/CSAF and MSRC updates and re‑scan when attestations expand.
Microsoft’s product‑scoped attestation model is a major transparency improvement and it makes triage faster for the assets it has checked. The operational challenge for defenders is to bridge the gap between attested artifacts and the much larger set of Microsoft‑distributed kernels and images that remain unverified. Treat the Azure Linux attestation as an authoritative “yes” and treat everything else as “verify me” until the vendor or your artifact inspection proves otherwise.
CVE‑2025‑38041 is now well‑documented in upstream trackers and distribution advisories; follow the runbook above to map your estate, patch Azure Linux instances immediately, and inventory Microsoft artifacts you run. Microsoft’s VEX/CSAF rollout will make this work easier over time — but in the meantime, per‑artifact verification remains the reliable path to safety.
