Windows 7 background problem
well i formatted my windows 7 ultimate and all works fine but the wallpaper is black...i can't change the background i can choose only solid colors...when the install progress finished the pc load the files and after that my background got black ......what can i do?? P.S i downloaded the windows 7 and i activated them with Chew-WGA_0.9_
my specs
sony vaio VGN-FW235J
Windows 7 ultimate 32-bit 7100 build
RAK
Is this a legal copy of Windows 7? If so, you will have no need for the crack. If not, you will find you are breaking the site rules.
my specs
If you are not using a legal copy of Windows 7 -- yes, as mentioned, you are not only breaking the site rules but it would also account for your seeing a black solid wallpaper. Microsoft implemented the black wallpaper as a sign that the version of Windows 7 installed is not genuine.
Do you see "This windows is not genuine." In the bottom Right hand corner?
If you wish to receive further support, you will need to have a valid and legal copy of Windows 7 installed.
Jessica
Microsoft Windows Client Team
RAK
Agreed. I didn't want to spell it out so bluntly - lol
now you can't help me??but when i activated them the background would be visible right?
RAK
You have already spoiled the activation with the crack. reinstall and activate with the correct, legal key. Then all should work.
#7
that is the problem i don't know the right key
#8
You need to PURCHASE a legal key. Have you purchased Windows 7? If so, the Windows 7 key should be included with your copy of Windows 7.
Jessica
