Windows 7 Best tool for mounting images
Jonniesweb
Hey, A quick question: I need to mount an .iso file for the installation for one of my programs. My problem is that my DVD drive is toast and I need to get a program that works with windows 7. I have tried Daemon Tools Lite but I had no success. Any help would be appreciated. Thanks.
Yes,Daemon Tools isn't working yet with Windows 7. I'm using Virtual Clone Drive.Work's perfectly. It's freeware and can be downloaded from SlySoft homepage (Link Removed).
I need a help with that too, installed Daemon tools with a lots of problems, and alcohol 120% and same thing, also tried as Vista and XP, didnt help..
Daemon tools has been working with windows 7 for a few days now. You have to half-install pro then install the lite. Or just pay for pro and use that.
Link Removed - Invalid URL
MagicISO
I've been using MagicISO/disc for the past few years without issue - it's very easy to use and it's free. no probs at all in build 7048 either
