Brand New HP Laptop G62 Intel i5 - Frequent BlueScreenOfDeath Problem
Hello -
I have recently started to get the Windows 7 BSOD error with in couple of months after buying my laptop. No 3rd party updates, basic programs for watching videos/movies and use of MsOffice thats all I use the computer for.
I removed the trial version of Norton that came preinstalled, after reading that the problem might be due to that. I have also updated all my device hardware drivers to the latest versions through windows.
The problem still remains. At times it crashes very frequently, say every 5 - 10 mins, at other times it survives a few hours.
I have added the minidump files as attachment. I am fairly new to windows 7 so a detailed advice of solution would be much appreciated.
Thanks,
Hey there...
Your machine is in very poor shape driver-wise, causing 0x124 errors. It's so bad that it is making Windows think there is a hardware error when there may be not.
There are drivers for all sorts of things you don't even have and should never have been installed. If I was being paid by rate, I'd gladly sort this all out as is.
My highest recommendation is to clean install Windows while formatting. Once to desktop, visit the manufacturer's site and install all the latest drivers offered for it.
I wouldn't bother with any recovery partitions or restoring the system from there. I would get a Windows 7 DVD by any means and install from that. If you can't get one, I'd say try harder.
Good luck.
I have updated all my hardware drivers through Windows Update, and double checked with Device Manager they are all updated.
Also under the Device Manager|Network Adapters I noticed a little yellow "!" shield icon beside the Realtek PCIe Family Controller, and under Device Status in properties it said the device was not functioning properly. So I did a 'Roll Back' for the driver and the "!" is now gone and its been a day since the last BSoD crash.
In what other ways can I update my drivers for a stable performance could you tell me that please, without having to format.
101910-19890-01.dmp
Probably caused by : hardware X64_0x124_GenuineIntel_PROCESSOR_MAE
WHEA_UNCORRECTABLE_ERROR (124)
Stack: nt! hal!
Please take the time to read what's well outlined here: Stop 0x124 - what it means and what to try - Windows 7 Forums
Follow TorrentG's advice to reformat, clean install, and get latest drivers:
a) visit you notebook support HP Support & Drivers
b) visit device manufacturers support sites directly
HP G62 and G62t series | HP
iirsp.sys Tue Dec 13 23:47:54 2005
Intel/ICP Raid Storport Driver
Intel
sisraid4.sys Thu Oct 02 00:56:04 2008
SiS AHCI Stor-Miniport Driver
Silicon Integrated Systems
Support
nfrd960.sys Wed Jun 07 00:11:48 2006
IBM ServeRAID Controller Driver
IBM Support & downloads - United States
ql2300.sys Fri Jan 23 01:05:06 2009
QLogic Fibre Channel Stor Miniport Driver
QLogic Support Center
MegaSR.sys Tue May 19 04:25:54 2009
LSI MegaRAID Software RAID
Support and Downloads
vsmraid.sys Sat Jan 31 03:18:57 2009
VIA RAID driver
VIA Contact Support - VIA Technologies, Inc.
HECIx64.sys Thu Sep 17 22:54:16 2009
iaStorV.sys Wed Apr 08 19:57:17 2009
Intel Matrix Storage
http://downloadcenter.intel.com/
adpu320.sys Wed Feb 28 02:04:15 2007
Adaptec Windows Ultra320 Family Driver
Adaptec StorPort Ultra320 SCSI Driver
Adaptec - Technical Support
adpahci.sys Tue May 01 20:30:09 2007
Adaptec Windows SATA Storport Driver
arc.sys Fri May 25 00:27:55 2007
Adaptec RAID Controller
elxstor.sys Wed Feb 04 00:52:11 2009
Emulex LightPulse Storport Miniport Drive
Emulex
athrx.sys Mon Oct 05 19:33:57 2009
Atheros Wireless CB42/CB43/MB42/MB43 Network Adapter
Atheros, Wireless LAN, WLAN, 2.4/5-GHz, 802.11a/b/g, 802.11b/g, 802.11n, Radio-on-a-Chip, Overview, Networking, Products and Technology
Test your hardware:
CPU CPU - Stress Test with Prime95 - Windows 7 Forums
RAM RAM - Test with Memtest86+ - Windows 7 Forums
HDD HD Diagnostic
Loading Dump File [I:\101910-19890-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c65000 PsLoadedModuleList = 0xfffff800`02ea2e50
Debug session time: Tue Oct 19 07:38:08.604 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:59.775
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 124, {0, fffffa8005c16028, b2000000, 30005}
Followup: MachineOwner
2: kd> !analyze -v
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005c16028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000030005, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  perfmon.exe
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`0396ba58 fffff800`02c2e903 : 00000000`00000124 00000000`00000000 fffffa80`05c16028 00000000`b2000000 : nt!KeBugCheckEx
fffff880`0396ba60 fffff800`02deb593 : 00000000`00000001 fffffa80`05c17ea0 00000000`00000000 fffffa80`05c17ef0 : hal!HalBugCheckSystem+0x1e3
fffff880`0396baa0 fffff800`02c2e5c8 : 00000000`00000728 fffffa80`05c17ea0 fffff880`0396be30 fffff880`0396be00 : nt!WheaReportHwError+0x263
fffff880`0396bb00 fffff800`02c2df1a : fffffa80`05c17ea0 fffff880`0396be30 fffffa80`05c17ea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0396bc50 fffff800`02c2ddd5 : 00000000`00000004 00000000`00000001 fffff880`0396beb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0396bc90 fffff800`02c21e88 : 00000000`00000000 00000000`0000006a 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`0396bcc0 fffff800`02cd3fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`0396bcf0 fffff800`02cd3e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0396be30 fffff800`02cd775c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`097a8488 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!RtlCopyMemoryNonTemporal+0x5c
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_MAE
fffff800`00bcf000 fffff800`00bd9000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02c1c000 fffff800`02c65000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`02c65000 fffff800`03241000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00c6c000 fffff880`00c73000   aliide   aliide.sys   Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00c73000 fffff880`00c7a000   amdide   amdide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00c7a000 fffff880`00c82000   cmdide   cmdide.sys   Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00c82000 fffff880`00c9c000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00ca6000 fffff880`00cea000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:29:10 2009 (4A5BDF66)
fffff880`00cea000 fffff880`00cfe000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00cfe000 fffff880`00d5c000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d5c000 fffff880`00d8f000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00d8f000 fffff880`00db9000   mpio     mpio.sys     Tue Jul 14 03:01:27 2009 (4A5BCAD7)
fffff880`00db9000 fffff880`00dce000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00dce000 fffff880`00dd7000   compbatt compbatt.sys Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`00dd7000 fffff880`00de3000   BATTC    BATTC.SYS    Tue Jul 14 02:31:01 2009 (4A5BC3B5)
fffff880`00de3000 fffff880`00df8000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e0f000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e0f000 fffff880`00e66000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00e66000 fffff880`00e6f000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00e6f000 fffff880`00e79000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00e79000 fffff880`00e86000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00e86000 fffff880`00e8f000   isapnp   isapnp.sys   Tue Jul 14 02:31:08 2009 (4A5BC3BC)
fffff880`00e94000 fffff880`00f54000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00f54000 fffff880`00ff8000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ff8000 fffff880`01000000   intelide intelide.sys Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01000000 fffff880`0101b000   arcsas   arcsas.sys   Wed Jan 14 21:27:37 2009 (496E3CA9)
fffff880`0101b000 fffff880`01067000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`01088000 fffff880`010ae000   msdsm    msdsm.sys    Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`010ae000 fffff880`010d7000   nvraid   nvraid.sys   Wed May 20 09:39:40 2009 (4A13A5AC)
fffff880`010d7000 fffff880`01107000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01107000 fffff880`0110e000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`0110e000 fffff880`01116000   viaide   viaide.sys   Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`01116000 fffff880`0116c000   adpahci  adpahci.sys  Tue May 01 20:30:09 2007 (46377921)
fffff880`0116c000 fffff880`0118a000   amdsata  amdsata.sys  Tue May 19 20:53:21 2009 (4A12F211)
fffff880`0118a000 fffff880`011d1000   amdsbs   amdsbs.sys   Fri Mar 20 20:36:03 2009 (49C3E213)
fffff880`011d1000 fffff880`011ea000   arc      arc.sys      Fri May 25 00:27:55 2007 (4656035B)
fffff880`01200000 fffff880`01217000   HpSAMD   HpSAMD.sys   Tue May 19 02:43:49 2009 (4A11F2B5)
fffff880`01217000 fffff880`01292000   adp94xx  adp94xx.sys  Sat Dec 06 01:54:42 2008 (4939BF42)
fffff880`01292000 fffff880`012c1000   adpu320  adpu320.sys  Wed Feb 28 02:04:15 2007 (45E4C6FF)
fffff880`012cd000 fffff880`013eb000   iaStorV  iaStorV.sys  Wed Apr 08 19:57:17 2009 (49DCD76D)
fffff880`01400000 fffff880`01462000   storport storport.sys Tue Jul 14 03:01:18 2009 (4A5BCACE)
fffff880`01462000 fffff880`0146d000   msahci   msahci.sys   Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`0146d000 fffff880`01478000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`0147e000 fffff880`0159a000   iaStor   iaStor.sys   Tue Oct 13 21:15:56 2009 (4AD4C3DC)
fffff880`0159a000 fffff880`015a3000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`015a3000 fffff880`015cd000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`015cd000 fffff880`015ea000   lsi_sas  lsi_sas.sys  Tue May 19 03:20:23 2009 (4A11FB47)
fffff880`01600000 fffff880`01673000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`0169a000 fffff880`01721000   elxstor  elxstor.sys  Wed Feb 04 00:52:11 2009 (4988CA9B)
fffff880`01721000 fffff880`01732000   iirsp    iirsp.sys    Tue Dec 13 23:47:54 2005 (439F418A)
fffff880`01732000 fffff880`01751000   lsi_fc   lsi_fc.sys   Wed Dec 10 00:46:09 2008 (493EF531)
fffff880`01751000 fffff880`01764000   lsi_sas2 lsi_sas2.sys Tue May 19 03:31:48 2009 (4A11FDF4)
fffff880`01764000 fffff880`01783000   lsi_scsi lsi_scsi.sys Fri Apr 17 01:13:50 2009 (49E7AD9E)
fffff880`01783000 fffff880`0178f000   megasas  megasas.sys  Tue May 19 04:09:46 2009 (4A1206DA)
fffff880`0178f000 fffff880`017ed000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01800000 fffff880`0185f000   ql40xx   ql40xx.sys   Tue May 19 04:18:11 2009 (4A1208D3)
fffff880`0185f000 fffff880`01889000   vsmraid  vsmraid.sys  Sat Jan 31 03:18:57 2009 (4983A701)
fffff880`01889000 fffff880`018d5000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`018d5000 fffff880`018e9000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`018f6000 fffff880`0199a000   MegaSR   MegaSR.sys   Tue May 19 04:25:54 2009 (4A120AA2)
fffff880`0199a000 fffff880`019aa000   nfrd960  nfrd960.sys  Wed Jun 07 00:11:48 2006 (4485EF94)
fffff880`019aa000 fffff880`019d5000   nvstor   nvstor.sys   Wed May 20 09:45:37 2009 (4A13A711)
fffff880`01a09000 fffff880`01bad000   ql2300   ql2300.sys   Fri Jan 23 01:05:06 2009 (4978FBA2)
fffff880`01bad000 fffff880`01bbb000   SiSRaid2 SiSRaid2.sys Wed Sep 24 21:28:20 2008 (48DA86C4)
fffff880`01bbb000 fffff880`01bd3000   sisraid4 sisraid4.sys Thu Oct 02 00:56:04 2008 (48E3F1F4)
fffff880`01bd3000 fffff880`01bdd000   stexstor stexstor.sys Wed Feb 18 01:03:36 2009 (499B4248)
fffff880`01bdd000 fffff880`01bf1000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01c00000 fffff880`01c11000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01c11000 fffff880`01c1b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01c1b000 fffff880`01c36000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`01c42000 fffff880`01de5000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`01de5000 fffff880`01dff000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01e00000 fffff880`01e4a000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`01e4a000 fffff880`01f3c000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`01f3c000 fffff880`01f9c000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01f9c000 fffff880`01fc7000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`01fc7000 fffff880`01fcf000   wd       wd.sys       Tue Jul 14 02:19:55 2009 (4A5BC11B)
fffff880`01fcf000 fffff880`01fd7000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`01fd7000 fffff880`01ff4000   sbp2port sbp2port.sys Tue Jul 14 02:19:53 2009 (4A5BC119)
fffff880`02002000 fffff880`021ff000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02200000 fffff880`0228a000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`0228a000 fffff880`022a0000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`022a0000 fffff880`022af000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`022b8000 fffff880`022f2000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`022f2000 fffff880`02304000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`02304000 fffff880`0230d000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`0230d000 fffff880`02347000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`02347000 fffff880`0235d000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`0236b000 fffff880`02389000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02389000 fffff880`023ce000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`023ce000 fffff880`023f4000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`03000000 fffff880`0304e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`0304e000 fffff880`03071000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`030a6000 fffff880`0316e000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`0316e000 fffff880`0318c000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`0318c000 fffff880`031a4000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`031a4000 fffff880`031d1000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`03417000 fffff880`034bd000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`034bd000 fffff880`034c8000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`034c8000 fffff880`034f5000   srvnet   srvnet.sys   Fri Aug 27 06:37:24 2010 (4C7732F4)
fffff880`034f5000 fffff880`03507000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`03507000 fffff880`0356e000   srv2     srv2.sys     Fri Aug 27 06:37:46 2010 (4C77330A)
fffff880`03613000 fffff880`0363d000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`0363d000 fffff880`03646000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`03646000 fffff880`0364d000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`0364d000 fffff880`0365b000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`0365b000 fffff880`03680000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`03680000 fffff880`03690000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`03690000 fffff880`03699000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`03699000 fffff880`036a2000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`036a2000 fffff880`036ab000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`036ab000 fffff880`036b6000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`036b6000 fffff880`036c7000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`036c7000 fffff880`036d4000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`036d4000 fffff880`037f0000   dump_iaStor dump_iaStor.sys Tue Oct 13 21:15:56 2009 (4AD4C3DC)
fffff880`037f7000 fffff880`03800000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`04800000 fffff880`0484f000   SynTP    SynTP.sys    Tue Nov 03 20:14:54 2009 (4AF0731E)
fffff880`0484f000 fffff880`04874180   Impcd    Impcd.sys    Mon Oct 26 22:39:41 2009 (4AE6090D)
fffff880`04875000 fffff880`0488b000   intelppm intelppm.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`0488b000 fffff880`0489b000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`0489b000 fffff880`048b1000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`048b1000 fffff880`048d5000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`048d5000 fffff880`048e1000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`048e9000 fffff880`0493a000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`0493a000 fffff880`04946000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`04946000 fffff880`04951000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`04951000 fffff880`04960000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`04960000 fffff880`0497e000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`0497e000 fffff880`0498f000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`0498f000 fffff880`049b5000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`049b5000 fffff880`049b9500   CmBatt   CmBatt.sys   Tue Jul 14 02:31:03 2009 (4A5BC3B7)
fffff880`049ba000 fffff880`049de000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`049de000 fffff880`049fc000   i8042prt i8042prt.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`04a03000 fffff880`04b80000   athrx    athrx.sys    Mon Oct 05 19:33:57 2009 (4ACA1FF5)
fffff880`04b80000 fffff880`04b8d000   vwifibus vwifibus.sys Tue Jul 14 03:07:21 2009 (4A5BCC39)
fffff880`04b8d000 fffff880`04be3000   Rt64win7 Rt64win7.sys Wed Jun 23 12:10:45 2010 (4C21CF95)
fffff880`04be3000 fffff880`04bef000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 16:48:30 2009 (49F85AAE)
fffff880`04bef000 fffff880`04bfe000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`04bfe000 fffff880`04bfff00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`04c00000 fffff880`04c12000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04c12000 fffff880`04c6c000   usbhub   usbhub.sys   Sat Sep 05 06:24:43 2009 (4AA1D9FB)
fffff880`04c6c000 fffff880`04c81000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`04cf7000 fffff880`04d26000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`04d26000 fffff880`04d41000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`04d41000 fffff880`04d62000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`04d62000 fffff880`04d7c000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`04d7c000 fffff880`04d7d480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`04d7e000 fffff880`04dc1000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`04dc1000 fffff880`04df7000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`05200000 fffff880`05246000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`05246000 fffff880`05257000   HECIx64  HECIx64.sys  Thu Sep 17 22:54:16 2009 (4AB293E8)
fffff880`05257000 fffff880`05268000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`05268000 fffff880`052be000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`052be000 fffff880`052cd000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`052d5000 fffff880`05cf36e0   igdkmd64 igdkmd64.sys Thu Jul 29 00:10:36 2010 (4C509CCC)
fffff880`05cf4000 fffff880`05de8000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`05de8000 fffff880`05df5000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 15:17:04 2009 (4A1151C0)
fffff880`05df5000 fffff880`05dfe000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`06653000 fffff880`06871a00   RTKVHD64 RTKVHD64.sys Tue Dec 22 13:07:12 2009 (4B30A860)
fffff880`06872000 fffff880`068af000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`068af000 fffff880`068d1000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`068d1000 fffff880`068d6200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`068d7000 fffff880`06904200   usbvideo usbvideo.sys Thu Mar 04 06:40:57 2010 (4B8F39D9)
fffff880`06905000 fffff880`06928000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`06928000 fffff880`06949000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`06949000 fffff880`0699c000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`0699c000 fffff880`069af000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`069af000 fffff880`069c7000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`06a09000 fffff880`06b3a000   agrsm64  agrsm64.sys  Tue Jul 21 21:03:31 2009 (4A6602F3)
fffff880`06b3a000 fffff880`06b49000   modem    modem.sys    Tue Jul 14 03:10:48 2009 (4A5BCD08)
fffff880`06b49000 fffff880`06b8a000   IntcDAud IntcDAud.sys Fri Oct 30 16:56:33 2009 (4AEAFEA1)
fffff880`06b8a000 fffff880`06b9d000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`06b9d000 fffff880`06bab000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`06bab000 fffff880`06bc0000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`06bc6000 fffff880`06be3000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`06be3000 fffff880`06bef000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`06bef000 fffff880`06bfd000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06e00000 fffff880`06e71000   spsys    spsys.sys    Mon May 11 20:20:58 2009 (4A085E7A)
fffff880`06efe000 fffff880`06f94000   srv      srv.sys      Fri Aug 27 06:38:00 2010 (4C773318)
fffff960`00070000 fffff960`0037f000   win32k   win32k.sys   Wed Sep 01 05:58:04 2010 (4C7DC13C)
fffff960`005c0000 fffff960`005ca000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`007a0000 fffff960`007c7000   cdd      cdd.dll      Wed May 19 22:48:26 2010 (4BF4408A)
Unloaded modules:
fffff880`06f94000 fffff880`06f96000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0235d000 fffff880`0236b000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`036db000 fffff880`037f7000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`03600000 fffff880`03613000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06b8a000 fffff880`06bc6000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003C000
fffff880`01c1b000 fffff880`01c38000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
Tried installing a fresh Windows, did the update through Windows Update as well as through the HP Update Manager but still experiencing crashes often.
First, install this patch:
An update that improves the compatibility of Windows 7 and Windows Server 2008 R2 with Advanced Format Disks is available
Absolutely uninstall Norton in safe mode using the tool found here:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE.
Update Realtek HD Audio driver:
RtkHDAudio
RTKVHD64 RTKVHD64.sys Tue Dec 22 06:07:12 2009
Update Realtek LAN driver:
Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010
RTL8111
Update RAID drivers from manufacturer's site:
You again have all sorts of RAID drivers on the system that are very old and do not belong.
#7
Ok, I have removed Norton as you said and installed the sound drivers and updated other hardware drivers through windows. The RAID drivers I cant find exact ones on the manufacturer's website, there are tons of model IDs and I cant seem to find which ones are in my laptop.
#8
Any crashes yet? And did you install the Microsoft patch from my post?
#9
Yes I installed the Microsoft hotfix patch from your post, as well as MSE.
Its still crashing, even sometimes in between installations.
Also, when I try Windows update it repeatedly shows 2 updates as 'Failed'
1. Security Update for Windows 7 for x64-based Systems (KB981332)
2. Update for Windows 7 for x64-based Systems (KB2158563)
#10
Could someone please help me with updating RAID drivers...
#11
This thread keeps going down places, but no one wishes to offer some help i guess..
I'm still experiencing crashes, and its really frustrated me. I'm calling out for help for the last time.. can someone help plz!
#12
I'll tell ya what you can do. Post a screenshot of the Device Manager with the Storage Controllers section maximized. Also maximize the IDE ATA/ATAPI section if there is one, too.
#13
There..
#14
Navigate to C:\Windows\System32\drivers. Rename each of these .sys drivers to .BAK:
sisraid4.sys
nfrd960.sys
ql2300.sys
MegaSR.sys
vsmraid.sys
adpu320.sys
adpahci.sys
arc.sys
elxstor.sys
Update this storage driver from HP.com:
Product search results
Reboot.
#15
There is an Intel Matrix Storage driver, under Utilities - Storage category. I've installed that.
#16
Still Crashing..
I have attached the minidump.. whts the problem ??
#17
BugCheck 124, {0, fffffa8003b4c028, b2000000, 30005}
Unable to load image \SystemRoot\system32\DRIVERS\athrx.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrx.sys
*** ERROR: Module load completed but symbols could not be loaded for athrx.sys
3: kd> lmvm athrx
fffff880`04216000 fffff880`0439f000   athrx    T (no symbols)
    Loaded symbol image file: athrx.sys
    Image path: \SystemRoot\system32\DRIVERS\athrx.sys
    Image name: athrx.sys
    Timestamp:        Tue Mar 02 19:45:21 2010 (4B8DB121)
    CheckSum:         00186AC4
    ImageSize:        00189000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
You can try to update the Atheros wireless driver, but that very likely is not going to fix anything. 0x124 errors mean that the hardware is defective, specifically, some part of the wireless adapter.
Suggest to return the machine for a new one. Every crash dump you just posted is a 0x124 stop.
Anyhow, many of those drivers I said to delete too are still there. They could be causing issues involving this.
If you want to attempt to do some things yourself, pay attention to any driver from before July 2009 in the crash dump. Update or remove them from the machine (leave secdrv.sys alone, it is well):
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [E:\Temp\Rar$DI00.565\110910-13540-01.dmp]
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Machine Name:
Kernel base = 0xfffff800`02c4d000 PsLoadedModuleList = 0xfffff800`02e8ae50
Debug session time: Tue Nov  9 23:50:03.971 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:04.516
3: kd> lmvm athrx
    CheckSum:         00186AC4
    ImageSize:        00189000
3: kd> lmtn
fffff800`00ba0000 fffff800`00baa000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff800`02c04000 fffff800`02c4d000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff800`02c4d000 fffff800`03229000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`00c5c000 fffff880`00c64000   cmdide   cmdide.sys   Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00c64000 fffff880`00c7e000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c86000 fffff880`00cca000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`00cca000 fffff880`00cde000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00cde000 fffff880`00d3c000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d3c000 fffff880`00dfc000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`00e57000 fffff880`00e60000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e60000 fffff880`00e6a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`00e6a000 fffff880`00e9d000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e9d000 fffff880`00eaa000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00eaa000 fffff880`00eb3000   isapnp   isapnp.sys   Mon Jul 13 19:31:08 2009 (4A5BC3BC)
fffff880`00eb3000 fffff880`00edd000   mpio     mpio.sys     Mon Jul 13 20:01:27 2009 (4A5BCAD7)
fffff880`00edd000 fffff880`00ef2000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00ef7000 fffff880`00f9b000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f9b000 fffff880`00faa000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00faa000 fffff880`00fb3000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fb3000 fffff880`00fbf000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`00fbf000 fffff880`00fd4000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00fd4000 fffff880`00fdc000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00fdc000 fffff880`00fec000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00fec000 fffff880`00ff3000   aliide   aliide.sys   Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff3000 fffff880`00ffa000   amdide   amdide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`01000000 fffff880`0101f000   lsi_scsi lsi_scsi.sys Thu Apr 16 18:13:50 2009 (49E7AD9E)
fffff880`0101f000 fffff880`0102b000   megasas  megasas.sys  Mon May 18 21:09:46 2009 (4A1206DA)
fffff880`0102b000 fffff880`01056000   nvstor   nvstor.sys   Wed May 20 02:45:37 2009 (4A13A711)
fffff880`01056000 fffff880`010b5000   ql40xx   ql40xx.sys   Mon May 18 21:18:11 2009 (4A1208D3)
fffff880`010b5000 fffff880`010c3000   SiSRaid2 SiSRaid2.sys Wed Sep 24 14:28:20 2008 (48DA86C4)
fffff880`010c3000 fffff880`010cd000   stexstor stexstor.sys Tue Feb 17 18:03:36 2009 (499B4248)
fffff880`010cd000 fffff880`010e3000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010f0000 fffff880`01116000   msdsm    msdsm.sys    Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01116000 fffff880`0113f000   nvraid   nvraid.sys   Wed May 20 02:39:40 2009 (4A13A5AC)
fffff880`0113f000 fffff880`0116f000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`0116f000 fffff880`01176000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`01176000 fffff880`0117e000   viaide   viaide.sys   Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0117e000 fffff880`011c5000   amdsbs   amdsbs.sys   Fri Mar 20 14:36:03 2009 (49C3E213)
fffff880`011c5000 fffff880`011e4000   lsi_fc   lsi_fc.sys   Tue Dec 09 17:46:09 2008 (493EF531)
fffff880`011e4000 fffff880`011f7000   lsi_sas2 lsi_sas2.sys Mon May 18 20:31:48 2009 (4A11FDF4)
fffff880`01200000 fffff880`0127b000   adp94xx  adp94xx.sys  Fri Dec 05 18:54:42 2008 (4939BF42)
fffff880`0127b000 fffff880`01299000   amdsata  amdsata.sys  Tue May 19 13:53:21 2009 (4A12F211)
fffff880`01299000 fffff880`012b2000   arc      arc.sys      Thu May 24 17:27:55 2007 (4656035B)
fffff880`012b2000 fffff880`012cd000   arcsas   arcsas.sys   Wed Jan 14 14:27:37 2009 (496E3CA9)
fffff880`012cf000 fffff880`013ed000   iaStorV  iaStorV.sys  Wed Apr 08 12:57:17 2009 (49DCD76D)
fffff880`013ed000 fffff880`013fe000   iirsp    iirsp.sys    Tue Dec 13 16:47:54 2005 (439F418A)
fffff880`01400000 fffff880`0141d000   lsi_sas  lsi_sas.sys  Mon May 18 20:20:23 2009 (4A11FB47)
fffff880`0141d000 fffff880`0147f000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`0147f000 fffff880`0148a000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0148a000 fffff880`01495000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`01496000 fffff880`015b2000   iaStor   iaStor.sys   Tue Oct 13 14:15:56 2009 (4AD4C3DC)
fffff880`015b2000 fffff880`015bb000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`015bb000 fffff880`015e5000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`015e5000 fffff880`015fc000   HpSAMD   HpSAMD.sys   Mon May 18 19:43:49 2009 (4A11F2B5)
fffff880`01600000 fffff880`0163a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0163a000 fffff880`01674000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0167a000 fffff880`016c6000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`016c6000 fffff880`016da000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`016da000 fffff880`01738000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01738000 fffff880`017ab000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`017ab000 fffff880`017f7000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01800000 fffff880`0180a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0180a000 fffff880`0181c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0182a000 fffff880`019cd000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019cd000 fffff880`019e7000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`019e7000 fffff880`019f8000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`01a00000 fffff880`01a2b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`01a2b000 fffff880`01a75000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`01a75000 fffff880`01a7d000   wd       wd.sys       Mon Jul 13 19:19:55 2009 (4A5BC11B)
fffff880`01a7d000 fffff880`01a85000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01a85000 fffff880`01aa2000   sbp2port sbp2port.sys Mon Jul 13 19:19:53 2009 (4A5BC119)
fffff880`01aa3000 fffff880`01b95000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01b95000 fffff880`01bf5000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01bf5000 fffff880`01bfe000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`01c01000 fffff880`01dfe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`02c00000 fffff880`02c23000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02c6e000 fffff880`02d36000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`02d36000 fffff880`02d54000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`02d54000 fffff880`02d6c000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02d6c000 fffff880`02d99000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02d99000 fffff880`02de7000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03013000 fffff880`0303d000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0303d000 fffff880`0306a000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
fffff880`0306a000 fffff880`03073000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`03073000 fffff880`0307a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0307a000 fffff880`03088000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`03088000 fffff880`030ad000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`030ad000 fffff880`030bd000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`030bd000 fffff880`030c6000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`030c6000 fffff880`030cf000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`030cf000 fffff880`030d8000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`030d8000 fffff880`030e3000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`030e3000 fffff880`031ff000   dump_iaStor dump_iaStor.sys Tue Oct 13 14:15:56 2009 (4AD4C3DC)
fffff880`03e00000 fffff880`03e26000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`03e26000 fffff880`03e3c000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03e3c000 fffff880`03e4b000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03e68000 fffff880`03e83000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`03e83000 fffff880`03e97000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff880`03e97000 fffff880`03ebb000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03ecc000 fffff880`03edd000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03edd000 fffff880`03efb000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03efb000 fffff880`03f08000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`03f08000 fffff880`03f92000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03f92000 fffff880`03fd7000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`03fd7000 fffff880`03fe0000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04000000 fffff880`04056000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`04056000 fffff880`040a5000   SynTP    SynTP.sys    Tue Nov 03 13:14:54 2009 (4AF0731E)
fffff880`040a5000 fffff880`040bb000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`040c5000 fffff880`04116000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04116000 fffff880`04122000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff880`04122000 fffff880`0412d000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0412d000 fffff880`0413c000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0413c000 fffff880`0415a000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0415a000 fffff880`0416b000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0416b000 fffff880`04191000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04191000 fffff880`04195500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`04196000 fffff880`041ec000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04200000 fffff880`0420d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff880`0420d000 fffff880`04216000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`04216000 fffff880`0439f000   athrx    athrx.sys    Tue Mar 02 19:45:21 2010 (4B8DB121)
fffff880`0439f000 fffff880`043ac000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`043ac000 fffff880`043ca000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`043ca000 fffff880`043d6000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
fffff880`043d6000 fffff880`043e5000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`043e5000 fffff880`043e6f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`043e7000 fffff880`043f6000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04800000 fffff880`04836000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`04836000 fffff880`0484b000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`048b1000 fffff880`048e0000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`048e0000 fffff880`048fb000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`048fb000 fffff880`0491c000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0491c000 fffff880`04936000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04936000 fffff880`04937480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`04938000 fffff880`0497b000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0497b000 fffff880`0498d000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0498d000 fffff880`049e7000   usbhub   usbhub.sys   Fri Sep 04 23:24:43 2009 (4AA1D9FB)
fffff880`04a00000 fffff880`04a96000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`04aa0000 fffff880`04b46000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04b46000 fffff880`04b51000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04b51000 fffff880`04b7e000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04b7e000 fffff880`04b90000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`04b90000 fffff880`04bf7000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`04c00000 fffff880`04c46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`04c46000 fffff880`04c57000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`04c57000 fffff880`04c68000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04c68000 fffff880`04c8c000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04c8c000 fffff880`04cb2d00   Impcd    Impcd.sys    Fri Feb 26 18:32:11 2010 (4B8859FB)
fffff880`04cb7000 fffff880`056d5b60   igdkmd64 igdkmd64.sys Wed Aug 25 15:35:58 2010 (4C75709E)
fffff880`056d6000 fffff880`057ca000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`057ca000 fffff880`057e0000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`057e0000 fffff880`057f0000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`057f0000 fffff880`057fc000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06200000 fffff880`06218000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06279000 fffff880`06497a00   RTKVHD64 RTKVHD64.sys Tue Dec 22 06:07:12 2009 (4B30A860)
fffff880`06498000 fffff880`064d5000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`064d5000 fffff880`064f7000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`064f7000 fffff880`064fc200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`064fd000 fffff880`0652a200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`0652b000 fffff880`06539000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`06539000 fffff880`0655c000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`0655c000 fffff880`0657d000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`0657d000 fffff880`06592000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06592000 fffff880`065e5000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`065e5000 fffff880`065f8000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`06800000 fffff880`0681d000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`06822000 fffff880`06953000   agrsm64  agrsm64.sys  Thu Aug 13 11:20:43 2009 (4A842F4B)
fffff880`06953000 fffff880`06962000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`06962000 fffff880`069ad000   IntcDAud IntcDAud.sys Mon Aug 30 07:17:36 2010 (4C7B9350)
fffff880`069ad000 fffff880`069bb000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`069bb000 fffff880`069ce000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`069ce000 fffff880`069e9000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`069e9000 fffff880`069f5000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff960`00010000 fffff960`0031f000   win32k   win32k.sys   unavailable (00000000)
fffff960`00560000 fffff960`0056a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00680000 fffff960`006a7000   cdd      cdd.dll      unavailable (00000000)
fffff960`00850000 fffff960`008b1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`04a96000 fffff880`04a98000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0181c000 fffff880`0182a000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`030e4000 fffff880`03200000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`03000000 fffff880`03013000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`03e4b000 fffff880`03e68000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
