BSOD analysis needed 64 bit
A friend asked me to help him with his new computer that randomly gets bsod from time to time. He custom build it.
can anyone help analyse it?
Wow for a minute i thought i wrote this in danish, then i realised the website translated it...
Hello there, welcome...
1) Remove Daemon Tools normally. Then use the installer/uninstaller at the link to remove sptd.sys, while being careful to click on "Uninstall" while using:
DuplexSecure - Downloads
Reboot and install PowerISO to replace it, as the disc emulation is free forever and is perfectly stable, unlike DT:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
2) Update Realtek lan driver:
Rt64win7 Rt64win7.sys Thu Mar 04 08:42:52 2010
RTL8111
3) Update VIA HD Audio driver. Look in device manager or motherboard manual for the type, then download from here:
viahduaa viahduaa.sys Wed Nov 25 08:06:00 2009
VIA Drivers Download - VIA Technologies, Inc.
4) Must update this old Serial Infrared driver from the motherboard manufacturer's website:
irsir irsir.sys Sat Jan 19 01:36:11 2008
5) If issues persist, uninstall ZoneAlarm then download and run CPU-Z, make a screen shot of the memory and spd tabs. Post them here by attaching, along with new crash dumps.
Im very thankful for the quick reply! I will do as asked and then post future dumps if they occur.
