Windows 7 BSOD, could Somebody help me?
YUNJIN
what happend with my computer?
does anyone analyze DUMP file?
BugCheck 1A, {41790, fffffa8000970140, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2f8b4 )
Followup: MachineOwner
the above bugcheck is caused by a memory management issue and can mean you have some faulty RAM although software can also be a cause...
the above bugcheck is caused by a memory management issue and can mean you have some faulty RAM although software can also be a cause too.
A program was running at the time of BSOD called 'LOLPatcher.exe' and is associated with League of Legends? You may want to re-install this or if it isn't used removed altogether.
Please update your system drivers using your motherboard support page:
GIGABYTE - Motherboard - Socket 1150 - GA-Z97X-UD3H-BK (rev. 1.0)
If the bsod continues then you'll need to test your RAM. Windows does have a memory testing app but it can miss errors and the best app for the job is Memtest86.
If you open the link below you'll see you can run Memtest86 in two ways. You can either burn it to disk or install it onto a USB drive it's entirely up to you. You'll then need to enter the bios to change the boot order so you can boot from either the Disk or USB stick you have Memtest86 on.
You must test for at least 12 hours unless it becomes obvious there is a problem straight away.
Memtest86+ - Advanced Memory Diagnostic Tool
Post any new dump files.
