BSOD - Driver Power State Failure
I have upgraded from Vista to Win 7 and keep getting the driver power state failure BSOD. I have attached the dumpt files for someone way smarter than me to look at and hopefully tell me which driver is the culprit.
Thanks!!!
Hey there.
Update your Realtek HD Audio driver:
RTKVHDA RTKVHDA.sys Tue Aug 04 05:48:13 2009
RtkHDAudio
Update your Hauppage TV card driver:
hcw18bda hcw18bda.sys Thu May 28 11:46:17 2009
Hauppauge Computer Works : Support
Update your Intel Matrix Storage drivers, and others. Let the Intel website scan and install the latest updates. If for some reason it doesn't update the storage, then go to your motherboard website to download it instead:
iaStor iaStor.sys Mon Jun 02 21:03:35 2008
http://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr
Navigate to C:\Windows\System32\drivers and delete PxHelp20.sys. Reboot. Run Ccleaner to clean the registry.
XAudio32 XAudio32.sys Wed Apr 29 14:20:55 2009
Update your Conexant modem drivers.
nvlddmkm nvlddmkm.sys Sun Sep 27 20:13:17 2009
Update your video card driver:
NVIDIA
e1e6032 e1e6032.sys Tue Mar 24 14:16:11 2009
This Intel network driver should be updated the same way as the above Intel driver.
Update your wireless adapter driver from manufacturer's site:
netr73 netr73.sys Wed May 20 04:47:39 2009
zigzag3143
Honorable Member
Microsoft MVP
Thanks!!!
My collegue TorrentG is spot on, I would also do a few others just to be sure
Old drivers needing update
mdmxsdk.sys        0xa1778000    0xa177b180    0x00003180    0x449716a3    6/19/2006 17:26:59
PxHelp20.sys        0x8b5e8000    0x8b5f0b80    0x00008b80    0x45c3abed    2/2/2007 17:23:57
dump_iaStor.sys        0x91400000    0x914c7000    0x000c7000    0x48449867    6/2/2008 21:03:35
[B]iaStor.sys        0x8b507000    0x8b5ce000    0x000c7000    0x48449867    6/2/2008 21:03:35          [/B]
HSX_DP.sys        0x82477000    0x82579000    0x00102000    0x4995de7b    2/13/2009 16:56:27
HSX_CNXT.sys        0x8262e000    0x826e3000    0x000b5000    0x4995deb5    2/13/2009 16:57:25
HSXHWBS2.sys        0x8242b000    0x82477000    0x0004c000    0x4995def3    2/13/2009 16:58:27
e1e6032.sys        0x99f87000    0x99fbf000    0x00038000    0x49c9236b    3/24/2009 14:16:11
[B]iaStorV.sys        0x8b42c000    0x8b507000    0x000db000    0x49dcd6e2    4/8/2009 12:54:58[/B]
XAudio32.sys        0xa3ef7000    0xa3eff000    0x00008000    0x49f89a87    4/29/2009 14:20:55
spldr.sys        0x8b993000    0x8b99b000    0x00008000    0x4a084ebb    5/11/2009 12:13:47
GEARAspiWDM.sys        0x826f0000    0x826f5280    0x00005280    0x4a1151b5    5/18/2009 08:16:53
amdxata.sys        0x8b5ce000    0x8b5d7000    0x00009000    0x4a12f30f    5/19/2009 13:57:35
netr73.sys        0x8ce0c000    0x8ce9c000    0x00090000    0x4a13c3ab    5/20/2009 04:47:39
hcw18bda.sys        0x91f69000    0x91fc8880    0x0005f880    0x4a1eb1c9    5/28/2009 11:46:17
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
