Windows 7 BSoD - DRIVER_IRQL_NOT_LESS_THAN_OR_EQUAL Randomly
Travis4261
My PC:
OS - Windows 7 Ultimate
Case - Rosewill CHALLENGER Black Gaming ATX
MB - ASUS M4A79XTD EVO AM3 AMD 790X ATX
CPU - AMD Phenom II 965 Black Edition 3.4Ghz
PSU - CORSAIR CMPSU-750TX 750W
RAM - G-Skill Ripjaw Series 4GB DDR3 1600 x4 (16GB)
HDD - Seagate Barracuda 7200 1.5TB
GPU - XFX Radeon HD 4850
Display - ASUS MS238 23'' LED (Primary)
Display - VIZIO E-Series 60” Razor LED™ E601i-A3 (Secondary)
1st off my build is now 2 1/2 years old now (built Feb 2011)
I used to have a serious blue screen issue when I 1st built it and it took forever to figure out what was causing it, basically I had my ram speed set to high. I have not had any persistent issues since Feb - May of 2011. Now recently I have been noticing more and more frequent BS's, but only when I am actually using my PC it is on 24/7 and I have program/games running all the time and I never wake up to a PC that has rebooted. I have no idea if this has anything to do with it or its just a fluke but the last 3 BS's have happened while browsing the internet 2 of which happened the exact moment I opened a new tab. I get the message Driver_IRQL_NOT_LESS_OR_EQUAL. That is all I really know about them, I have included the last 5 dmp files which are not very frequent but very annoying, any help will be greatly appreciated!
I've posted this on a different forum and was not able to pin point the exact problem.
Things I have noticed, this might sound REALLY weird but all of the recent BSODs has all been while using mozilla firefox and WHILE I am checking my hotmail.
I will be adding my most recent .dmp files, if anyone can pin point this it would be so awesome!
  • New BsoDs.zip
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
All of the memory dumps point to tcpip.sys - a networking driver for Windows. Most often Windows files aren't the problem - but rather it's a problem with other, 3rd party drivers that utilize the networking stack. As such, try:
- downloading new wired and wireless (if so equipped) drivers
- un-installing the current wired and wireless driver software
- installing the freshly downloaded driver software
- monitor for further BSOD's
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
xusb21.sys belongs to a wireless USB XBox controller that is known to have BSOD issues. Please uninstall it's software and physically remove the device from your system (in order to test it).
Rtnic64.sys Fri May 30 11:12:23 2008 (48401957)
Realtek Ethernet NIC driver
http://www.carrona.org/drivers/driver.php?id=Rtnic64.sys
AtiPcie.sys Tue May 5 11:00:22 2009 (4A005486)
ATI PCIE Driver for ATI PCIE chipset or [br] ATI PCI Express (3GIO) Filter[br]Found in my ATI video drivers (I have an Intel chipset)
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
viahduaa.sys Tue Jun 2 04:55:21 2009 (4A24E8F9)
VIA High Definition Audio Function Driver
http://www.carrona.org/drivers/driver.php?id=viahduaa.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Fri Jul  5 18:46:04.940 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070513-24819-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]1 days 6:43:00.439[/B]
*** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
Probably caused by :[B]tcpip.sys ( tcpip+6420e )[/B]
BugCheck [B]D1, {1c, 2, 1, fffff8800186420e}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#Example]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 000000000000001c, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8800186420e, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0xD1_tcpip+6420e[/B]
  BIOS Version                  2102
  BIOS Release Date             06/17/2010
**************************Thu Jul  4 12:01:58.133 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070413-24741-01.dmp]
System Uptime:[B]1 days 13:19:24.257[/B]
Arguments:
BUGCHECK_STR:  0xD1
  BIOS Version                  2102
**************************Tue Jul  2 22:41:18.218 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070213-22354-01.dmp]
System Uptime:[B]11 days 0:23:22.589[/B]
Arguments:
BUGCHECK_STR:  0xD1
PROCESS_NAME:  vprot.exe
  BIOS Version                  2102
**************************Fri Jun 21 19:05:56.025 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062113-25989-01.dmp]
System Uptime:[B]8 days 20:42:33.149[/B]
Probably caused by :[B]tcpip.sys ( tcpip!TcpBeginTcbSend+33e )[/B]
BugCheck [B]D1, {1c, 2, 1, fffff88001863b4e}[/B]
Arguments:
Arg4: fffff88001863b4e, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_tcpip!TcpBeginTcbSend+33e[/B]
  BIOS Version                  2102
**************************Wed Jun 12 22:21:57.400 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\061213-24679-01.dmp]
System Uptime:[B]0 days 3:15:31.899[/B]
Probably caused by :[B]tcpip.sys ( tcpip!IpNlpChecksumDatagram+b4 )[/B]
BugCheck [B]D1, {a, 2, 0, fffff88001860e24}[/B]
Arguments:
Arg1: 000000000000000a, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001860e24, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_tcpip!IpNlpChecksumDatagram+b4[/B]
  BIOS Version                  2102
**************************Tue Jun  4 16:35:58.068 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\060413-25053-01.dmp]
System Uptime:[B]0 days 7:35:19.566[/B]
Arguments:
BUGCHECK_STR:  0xD1
  BIOS Version                  2102
**************************Wed May 22 15:53:34.226 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\052213-24242-01.dmp]
System Uptime:[B]0 days 3:53:07.724[/B]
Arguments:
BUGCHECK_STR:  0xD1
  BIOS Version                  2102
[/font]
3rd Party Drivers:
[COLOR=RED][B]Rtnic64.sys                 Fri May 30 11:12:23 2008 (48401957)[/B][/COLOR]
[COLOR=RED][B]AtiPcie.sys                 Tue May  5 11:00:22 2009 (4A005486)[/B][/COLOR]
ASACPI.sys                  Wed May 13 21:25:17 2009 (4A0B72FD)
[COLOR=RED][B]viahduaa.sys                Tue Jun  2 04:55:21 2009 (4A24E8F9)[/B][/COLOR]
[COLOR=RED][B]xusb21.sys                  Thu Aug 13 18:10:17 2009 (4A848F49)[/B][/COLOR]
amdiox64.sys                Thu Feb 18 10:17:53 2010 (4B7D5A21)
acedrv11.sys                Wed Feb 24 05:20:17 2010 (4B84FD61)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
[COLOR=RED][B]dtsoftbus01.sys             Thu Jan 13 03:27:08 2011 (4D2EB75C)[/B][/COLOR]
SmartDefragDriver.sys       Wed Feb 23 03:37:56 2011 (4D64C764)
AtihdW76.sys                Thu Mar 31 03:15:43 2011 (4D942A1F)
atikmpag.sys                Tue Apr 19 21:22:32 2011 (4DAE3558)
atikmdag.sys                Tue Apr 19 21:53:29 2011 (4DAE3C99)
point64.sys                 Wed May 18 04:07:20 2011 (4DD37E38)
kmxcfg.sys                  Mon Jun 13 08:28:12 2011 (4DF6025C)
KmxFile.sys                 Mon Jun 13 08:33:43 2011 (4DF603A7)
KmxSbx.sys                  Mon Jun 13 08:43:46 2011 (4DF60602)
WinVDEdrv.sys               Fri Jul 15 07:24:05 2011 (4E202355)
kmxfw.sys                   Wed Jul 27 09:18:34 2011 (4E30102A)
KmxFilter.sys               Wed Jul 27 10:09:51 2011 (4E301C2F)
WinVDEdrv6.sys              Wed Aug  3 00:38:39 2011 (4E38D0CF)
KmxCF.sys                   Mon Sep  5 07:21:15 2011 (4E64B0AB)
kmxagent.sys                Wed Oct 26 12:08:05 2011 (4EA83065)
KmxAMRT.sys                 Thu Oct 27 16:01:05 2011 (4EA9B881)
WinFLAdrv.sys               Thu Jun 21 10:30:32 2012 (4FE33008)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
avgtpx64.sys                Tue Jan 29 05:44:37 2013 (5107A815)
ssudbus.sys                 Tue Jan 22 23:48:32 2013 (50FF6BA0)
[/font]
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=xusb21.sys
http://www.carrona.org/drivers/driver.php?id=amdiox64.sys
http://www.carrona.org/drivers/driver.php?id=acedrv11.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=SmartDefragDriver.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=point64.sys
http://www.carrona.org/drivers/driver.php?id=kmxcfg.sys
http://www.carrona.org/drivers/driver.php?id=KmxFile.sys
http://www.carrona.org/drivers/driver.php?id=KmxSbx.sys
http://www.carrona.org/drivers/driver.php?id=WinVDEdrv.sys
http://www.carrona.org/drivers/driver.php?id=kmxfw.sys
http://www.carrona.org/drivers/driver.php?id=KmxFilter.sys
http://www.carrona.org/drivers/driver.php?id=WinVDEdrv6.sys
http://www.carrona.org/drivers/driver.php?id=KmxCF.sys
http://www.carrona.org/drivers/driver.php?id=kmxagent.sys
http://www.carrona.org/drivers/driver.php?id=KmxAMRT.sys
http://www.carrona.org/drivers/driver.php?id=WinFLAdrv.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=avgtpx64.sys
http://www.carrona.org/drivers/driver.php?id=ssudbus.sys
Top Bottom
