Windows 7 BSOD happens every few days ever since I installed Civ 5, I uninstalled Steam and Civ 5
usasma
Fantastic Member
Please ask the staff to merge this post with your other one here: http://windows7forums.com/blue-screen-death-bsod/90495-bsod-while-playing-games.html
Please keep all posts in one topic so we can see what's happening with your system. And, please use the same user name - as it gets confusing and it took me 15 minutes to figure out who you were and where your previous post was.
Have you done this yet? If so, what were the results?
Only 119 Windows Updates installed after SP1. Most systems have 150 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
For starters:
At work we start all repairs with a set of diagnostics. Often they find problems that weren't even expected. It's a waste of time to try to fix software on a system that has hardware problems (I suspect a hardware problem in your case).
Please try these free diagnostics for starters: Initial Hardware Diagnostics
If the hardware diagnostics don't reveal anything, then please run Driver Verifier according to these instructions: Driver Verifier Settings
tmbd90
That is not my post, I read the other one because it was at the top of the board. I put it in the same general format because I thought that is what was most acceptable in this site. I can assure you that I am a different person and still need help. I will check into the other post to see if there is a solution. Thank you.
usasma
Fantastic Member
I apologize for the confusion and will start the analysis now.
There are numerous identical readings in many of the uploaded files.
usasma
Fantastic Member
Only 119 Windows Updates installed since SP1. Most systems have 150 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
Looking like a hardware problem from what I see in MSINFO32. Please run these free diagnostics (I suspect the hard drive(s), so start with those tests): Hardware Diagnostics
If that doesn't fix the BSOD's, then try running Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Fri Mar 29 22:01:42.255 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032913-27627-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 5:40:13.800[/B]
Probably caused by :[B]win32k.sys ( win32k!W32pArgumentTable+6220b )[/B]
BugCheck [B]50, {fffff95dc085f098, 1, fffff96000197b27, 5}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff95dc085f098, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff96000197b27, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  Skype.exe
FAILURE_BUCKET_ID: [B]X64_0x50_win32k!W32pArgumentTable+6220b[/B]
  BIOS Version                  F4
  BIOS Release Date             10/19/2012
  Manufacturer                  Gigabyte Technology Co., Ltd.
  Product Name                  GA-78LMT-USB3
[/font]
3rd Party Drivers:
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
Rt64win7.sys                Wed Feb 16 04:03:57 2011 (4D5B92FD)
lvuvc64.sys                 Wed Jan 18 01:41:08 2012 (4F166984)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
EtronXHCI.sys               Tue Jul  3 07:00:15 2012 (4FF2D0BF)
EtronHub3.sys               Tue Jul  3 07:00:21 2012 (4FF2D0C5)
avgfwd6a.sys                Tue Sep  4 04:31:15 2012 (5045BC53)
avgrkx64.sys                Thu Sep 13 20:41:40 2012 (50527D44)
avgloga.sys                 Thu Sep 20 21:23:51 2012 (505BC1A7)
avgtdia.sys                 Thu Sep 20 21:25:33 2012 (505BC20D)
avgldx64.sys                Mon Oct  1 21:05:50 2012 (506A3DEE)
avgidsha.sys                Sun Oct 14 21:22:54 2012 (507B656E)
avgidsdrivera.sys           Mon Oct 22 06:47:11 2012 (5085242F)
avgmfx64.sys                Thu Nov 15 17:03:50 2012 (50A566C6)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
nvlddmkm.sys                Sat Feb  9 18:13:08 2013 (5116D804)
[/font]
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=lvuvc64.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=EtronXHCI.sys
http://www.carrona.org/drivers/driver.php?id=EtronHub3.sys
http://www.carrona.org/drivers/driver.php?id=avgfwd6a.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgtdia.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
