BSOD help, please.
I just got done rebuilding my computer a few days ago, ensuring all of the devices in it are compatible, and getting the proper drivers for them. Though obviously I've done something wrong along the way, or some part of my computer is malfunctioning because I'm getting 3-10 BSOD's a day.
I'm uploading 3 of the dumps from said BSOD's. If someone could look at them and give me some advice as to what to do, that would be much appreciated.
Elmer
Hi Zenogod and Welcome to The Forum.
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes:
System service, Device driver, graphics driver, ?memory
Although your dump files have different stop error codes, they all list Pool_Corruption as the probable cause which usually indicates bad drivers.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct AVG Remover for your system (32 or 64 bit).
If you have AVG ID protection installed, download the AVGID Protection Remover from the above link as well (it wouldn't hurt to download and run it anyway). Download BSOD friendly Microsoft Security Essentials as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the AVG Removal tool(s). Re-boot to normal mode and install MSE. Make sure your Windows firewall is enabled! After your blue screens have been resolved, feel free to re-try AVG.
dtsoftbus01.sys Fri Jan 13 13:45:46 2012 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved. But do not replace with Daemon Tools!!
Drivers that pre-date Windows 7. Update:
purendis.sys Sat Jun 06 05:32:06 2009
pnarp.sys Sat Jun 06 07:06:44 2009
Pure Networks, Inc.
Drivers with Updates:
Rt64win7.sys Tue Aug 23 14:55:41 2011 Realtek PCIe GBE Family Controller v7.050 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
Bugcheck Analysis:
BugCheck 3B, {c0000005, fffff800030139bc, fffff88007c7dee0, 0}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+100 )
Followup: Pool_corruption
Drivers:
fffff880`00f31000 fffff880`00f88000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`066e2000 fffff880`0676b000   afd      afd.sys      Wed Dec 28 03:59:20 2011 (4EFA9418)
fffff880`1303d000 fffff880`13053000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0689e000 fffff880`068b3000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00d94000 fffff880`00d9f000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00cda000 fffff880`00ce3000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00d6a000 fffff880`00d94000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`07fb7000 fffff880`07fe2000   AVGIDSDriver AVGIDSDriver.Sys Sun Jul 10 23:36:37 2011 (4E1A2975)
fffff880`0199e000 fffff880`019a8000   AVGIDSEH AVGIDSEH.Sys Sun Jul 10 23:36:50 2011 (4E1A2982)
fffff880`095b9000 fffff880`095c4000   AVGIDSFilter AVGIDSFilter.Sys Sun Jul 10 23:37:05 2011 (4E1A2991)
fffff880`0682f000 fffff880`06878000   avgldx64 avgldx64.sys Fri Oct 07 04:55:41 2011 (4E8E783D)
fffff880`019de000 fffff880`019ee000   avgmfx64 avgmfx64.sys Mon Aug 08 04:41:46 2011 (4E3F5AFA)
fffff880`01992000 fffff880`0199e000   avgrkx64 avgrkx64.sys Tue Sep 13 05:02:34 2011 (4E6ED5DA)
fffff880`0663d000 fffff880`0669d000   avgtdia  avgtdia.sys  Sun Jul 10 23:46:53 2011 (4E1A2BDD)
fffff880`019f7000 fffff880`019fe000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0681e000 fffff880`0682f000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`07efa000 fffff880`07f18000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00620000 fffff960`00647000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`07a7f000 fffff880`07a9c000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`015c5000 fffff880`015ef000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01962000 fffff880`01992000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d0c000 fffff880`00d6a000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`012f1000 fffff880`01363000   cng      cng.sys      Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`1302d000 fffff880`1303d000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`07a9c000 fffff880`07aaa000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`06965000 fffff880`069e8000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`06800000 fffff880`0681e000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`06956000 fffff880`06965000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`0194c000 fffff880`01962000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06d67000 fffff880`06d89000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0137e000 fffff880`013c7000   dtsoftbus01 dtsoftbus01.sys Fri Jan 13 13:45:46 2012 (4F10358A)
fffff880`07ab6000 fffff880`07abf000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`07aaa000 fffff880`07ab6000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`07abf000 fffff880`07ad2000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07ad2000 fffff880`07ade000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`06ac4000 fffff880`06bb8000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`06bb8000 fffff880`06bfe000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`00deb000 fffff880`00dff000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00d9f000 fffff880`00deb000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01374000 fffff880`0137e000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01912000 fffff880`0194c000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`0180f000 fffff880`01859000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`02e1e000 fffff800`02e67000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`06a00000 fffff880`06a24000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`06d8f000 fffff880`06deb000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`06c00000 fffff880`06c19000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06c19000 fffff880`06c21080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06deb000 fffff880`06df9000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`07e00000 fffff880`07ec9000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01909000 fffff880`01912000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`13000000 fffff880`1301e000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`1301e000 fffff880`1302d000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00b9e000 fffff800`00ba8000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`06c34000 fffff880`06c77000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`012d6000 fffff880`012f1000   ksecdd   ksecdd.sys   Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`0159a000 fffff880`015c5000   ksecpkg  ksecpkg.sys  Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`06d89000 fffff880`06d8e200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07b0f000 fffff880`07b24000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07aec000 fffff880`07b0f000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00ceb000 fffff880`00cf8000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`07ade000 fffff880`07aec000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`013e3000 fffff880`013f2000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06c24000 fffff880`06c31000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`07f18000 fffff880`07f45000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`07f45000 fffff880`07f93000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`07f93000 fffff880`07fb7000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`013c7000 fffff880`013d2000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f91000 fffff880`00f9b000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01278000 fffff880`012d6000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`0694b000 fffff880`06956000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`018f7000 fffff880`01909000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01447000 fffff880`0153a000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`068e0000 fffff880`068ec000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`07b77000 fffff880`07b8a000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0122f000 fffff880`0125e000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`06ce3000 fffff880`06cf8000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`067b0000 fffff880`067bf000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0669d000 fffff880`066e2000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0153a000 fffff880`0159a000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`013d2000 fffff880`013e3000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0693f000 fffff880`0694b000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e67000 fffff800`03450000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01044000 fffff880`011e7000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`019ee000 fffff880`019f7000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`06cf8000 fffff880`06d2a000   nvhda64v nvhda64v.sys Tue Jan 17 12:45:46 2012 (4F156D7A)
fffff880`13059000 fffff880`13d77000   nvlddmkm nvlddmkm.sys Wed Feb 29 18:04:52 2012 (4F4E68C4)
fffff880`07b24000 fffff880`07b77000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`06774000 fffff880`0679a000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fdb000 fffff880`00ff0000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f9b000 fffff880`00fce000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00ff0000 fffff880`01000000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01363000 fffff880`01374000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`09400000 fffff880`094a6000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07b8a000 fffff880`07b96000   pnarp    pnarp.sys    Sat Jun 06 07:06:44 2009 (4A2A0774)
fffff880`06d2a000 fffff880`06d67000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cf8000 fffff880`00d0c000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`07b96000 fffff880`07ba2000   purendis purendis.sys Sat Jun 06 05:32:06 2009 (4A29F146)
fffff880`068bc000 fffff880`068e0000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`06614000 fffff880`0662f000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`01000000 fffff880`01021000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0125e000 fffff880`01278000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`068ee000 fffff880`0693f000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`069e8000 fffff880`069f3000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01600000 fffff880`01609000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01435000 fffff880`0143e000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0143e000 fffff880`01447000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018bd000 fffff880`018f7000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`07ba2000 fffff880`07bba000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06a24000 fffff880`06ab1000   Rt64win7 Rt64win7.sys Tue Aug 23 14:55:41 2011 (4E53B15D)
fffff880`094a6000 fffff880`094b1000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`13deb000 fffff880`13df7000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`067bf000 fffff880`067dc000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`018b5000 fffff880`018bd000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`09521000 fffff880`095b9000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`094b8000 fffff880`09521000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`07ec9000 fffff880`07efa000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`06abc000 fffff880`06abd480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0160b000 fffff880`0180f000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`095c4000 fffff880`095d6000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01222000 fffff880`0122f000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01200000 fffff880`01222000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`06600000 fffff880`06614000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00580000 fffff960`0058a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`06878000 fffff880`0689e000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`06c77000 fffff880`06c89000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`07a64000 fffff880`07a7ec80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`01021000 fffff880`0103e000   usbccgp  usbccgp.sys  Sat Nov 20 10:44:03 2010 (4CE7A673)
fffff880`06c22000 fffff880`06c23f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`13dda000 fffff880`13deb000   usbehci  usbehci.sys  Sat Nov 20 10:43:54 2010 (4CE7A66A)
fffff880`13dcd000 fffff880`13dda000   usbfilter usbfilter.sys Tue Dec 22 08:26:22 2009 (4B3082AE)
fffff880`06c89000 fffff880`06ce3000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`06ab1000 fffff880`06abc000   usbohci  usbohci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`13d77000 fffff880`13dcd000   USBPORT  USBPORT.SYS  Sat Nov 20 10:44:00 2010 (4CE7A670)
fffff880`00fce000 fffff880`00fdb000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`015ef000 fffff880`015fd000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01400000 fffff880`01425000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01859000 fffff880`01869000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01869000 fffff880`018b5000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0679a000 fffff880`067b0000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`067dc000 fffff880`067f7000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01425000 fffff880`01435000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e7e000 fffff880`00f22000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f22000 fffff880`00f31000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0676b000 fffff880`06774000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a5000   win32k   win32k.sys   Fri Feb 03 04:34:05 2012 (4F2B63BD)
fffff880`068b3000 fffff880`068bc000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f88000 fffff880`00f91000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
Unloaded modules:
fffff880`019a8000 fffff880`019b6000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019b6000 fffff880`019c2000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019c2000 fffff880`019cb000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019cb000 fffff880`019de000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
I just finished following your instructions. I'll let you know how the computer's running after a few days. Thank you for the help.
