BSOD Help Please
I am having a problem with BSOD on a fresh and updated version of Windows 7 Ultimate 64 bit.
My computer is a Gateway GT5678 with a Nvidia 9800GT video card, AUZEN XPlosion 7.1 Sound card and a Western Digital Raptor 74GB Hard Drive as my main drive.
I received 2 seperate BSOD while running the video game Guild Wars 2.
I have attach all the info needed from the sticky that is required.
If you need any more information please let me know.
I would also like to add that before I reinstalled Windows 7, I was getting numerous BSOD even while just surfing the web. I figured I would do a fresh install to see if that would clear up the problem. Unfortunately the reinstall did not seem to fix the BSODing.
usasma
Fantastic Member
First, since the problem still exists after reinstalling Windows - a hardware problem is a likely cause.
Please run these free, bootable diagnostics: Initial Hardware Diagnostics
If they all pass, then try these free diagnostics: Additional Hardware Diagnostics
The biggest issue that I see in your memory dumps is that your chipset drivers are outdated. Please update them using the driver package from this link: NVIDIA DRIVERS 15.56WHQL
It appears that you've just installed SP1 - so I'd suggest visiting Windows Update repeatedly until you get all available Windows Updates.
Analysis:
[font=lucida console]**************************Sun Sep  2 18:07:33.606 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-23119-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:12:53.838[/B]
BugCheck Code: [B]BugCheck D1, {6, 2, 8, 6}[/B]
*** WARNING: Unable to verify timestamp for cmudax3.sys
*** ERROR: Module load completed but symbols could not be loaded for cmudax3.sys
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]cmudax3.sys ( cmudax3+4fc9 )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_cmudax3+4fc9[/B]
CPUID:        "Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz"
MaxSpeed:     2400
CurrentSpeed:[B]2400[/B]
  BIOS Version                  A7399NG2.108
  BIOS Release Date             05/28/2008
  Manufacturer                  Gateway
  Product Name                  GT5678
**************************Sun Sep  2 15:13:57.723 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-19422-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (4 procs) Free x64
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:09:20.173[/B]
BugCheck Code: [B]BugCheck D1, {fffffa804d30c45c, 9, 1, fffff8800ffb9578}[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+bc578 )[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_nvlddmkm+bc578[/B]
MaxSpeed:     2400
  Product Name                  GT5678
[/font]
3rd Party Drivers:The following is for information purposes only. Any drivers in red should be updated.
[COLOR=RED][B]nvsmu.sys                   Fri Oct 12 19:53:40 2007 (47100904)[/B][/COLOR]
[COLOR=RED][B]nvmfdx64.sys                Sat Nov 17 18:47:57 2007 (473F7DAD)[/B][/COLOR]
[COLOR=RED][B]nvrd64.sys                  Fri Dec  7 18:27:23 2007 (4759D6DB)[/B][/COLOR]
[COLOR=RED][B]nvstor64.sys                Fri Dec  7 18:27:28 2007 (4759D6E0)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
nvstor.sys                  Fri Mar 19 16:45:11 2010 (4BA3E257)
nvraid.sys                  Fri Mar 19 16:59:20 2010 (4BA3E5A8)
cmudax3.sys                 Wed Mar 30 00:16:32 2011 (4D92AEA0)
nvlddmkm.sys                Thu Jun 28 18:58:00 2012 (4FECE178)
[COLOR=RED][B]amdxata.sys                 Tue May 19 13:56:59 2009 (4A12F2EB)[/B][/COLOR]
[COLOR=RED][B]nvraid.sys                  Wed May 20 02:39:40 2009 (4A13A5AC)[/B][/COLOR]
[COLOR=RED][B]nvstor.sys                  Wed May 20 02:45:37 2009 (4A13A711)[/B][/COLOR]
[/font]
http://www.carrona.org/drivers/driver.php?id=nvsmu.sys
http://www.carrona.org/drivers/driver.php?id=nvmfdx64.sys
http://www.carrona.org/drivers/driver.php?id=nvrd64.sys
http://www.carrona.org/drivers/driver.php?id=nvstor64.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=nvstor.sys
http://www.carrona.org/drivers/driver.php?id=nvraid.sys
http://www.carrona.org/drivers/driver.php?id=cmudax3.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
Thank you for your reply. I will run the hardware diag and update the chipset drivers and report back.
