I can help you troubleshoot the Blue Screen of Death (BSOD) issue on your father's computer. Here are some steps you can follow to try and resolve the issue:
1. Check for Overheating: Make sure that the computer is not overheating. Dust accumulation can cause overheating. Clean the fans and ensure proper ventilation.
2. Update Drivers: Outdated drivers can cause BSOD errors. Update the drivers for the motherboard, graphics card, and other components.
3. Check RAM: Faulty RAM can lead to BSOD errors. You can try reseating the RAM sticks or running a memory diagnostic tool to check for issues.
4. Check Hard Drive Health: A failing hard drive can also cause BSOD errors. Use a tool like CrystalDiskInfo to check the...
