DeadGoon2041
I've had this problem for years, and I can't seem to fix it myself, so i've decided to seek your expert help.
I've attached the required files as per the sticky.
I always get a BSOD with the ati graphics driver as the culprit, however I used to have a nvidia card in this same setup, and the BSOD used to say it was caused by the nvidia driver. I was hoping by upgrading the video card it would solve the BSOD issue but it hasn't :(
Other things I've done.
Windows update fully up to date.
Using latest graphic drivers
Updated BIOS
Reformated windows 7
Disconnected all extra hardware besides 1 hard drive
Tried the graphics card in the 2 other PCI-E slots on the motherboard
New PSU
Have temperature warnings on CPU and case (but it never goes off)
Ran memtest on the RAM
My hardware setup is:
Intel I7-2600k (not overclocked)
2 x 4gb DDR3 RAM
AMD Radeon 480 (used to be an Nvidia GF570 which would also give me BSOD)
650W PSU (brand new, old one also caused BSOD)
Gigabyte Z68MA-D2H-B3 mobo.
Thanks in advance for any help!
BugCheck 116, {fffffa8008a2c010, fffff8800400f948, 0, 2}
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+f948 )
Followup:     MachineOwner
Hi...
BugCheck 116, {fffffa8009a5d2d0, fffff88006b77948, 0, 2}
as your already aware something, either software or hardware, is causing the graphics driver to TDR. Causes for TDR's can be almost anything and it could be simply down to a particular application your using.
The above dump file is the most prolific but I also saw bugchecks caused by:
EtronXHCI.sys Fri Feb 25 17:51:52 2011: USB 3.00 driver please update using the driver (later version) found on your motherboard support site:
GA-Z68MA-D2H-B3 (rev. 1.3) | Motherboard | GIGABYTE
And:
AppleCharger.sys Mon Jan 10 09:57:29 2011: GIGABYTE On/Off Charge driver. See here for details - Link Removed May cause BSOD on Win7/8 systems - uninstall to test.
Looking over your drivers/apps in general I also noted these possible culprits:
dtsoftbus01.sys Thu Jan 13 08:27:08 2011: Daemon Tools driver. Possible BSOD issues in Win7 please remove.
xusb21.sys Thu Aug 13 23:10:17 2009: XBox USB wireless controller BSOD issues in Win7 with 2009 driver (found in mid-2012). Please update:
I'm pretty sure the above is the link for the later driver.
Please post any new dump files.
Cheers kemical.
I updated/removed all you recommended yesterday. Then I actually already got another BSOD today when I opened my browser.
I've attached the latest dmp file (20/11/17). Anything else you can recommend?
it can be a bit of trial and error chasing the culprit down but hopefully we'll get there.
Something I missed when I first read your post is:
Where do these temp warnings appear?
Check your CPU temperature at idle and at stress using something like HWiNFO64
To stress the CPU use something like this app: Link Removed
Check your CPU is ok by running Intel's chip diagnostic:
Stress test your gpu using Furmark, again, please monitor temps using the app suggested above.
These drivers need updating:
Rt64win7.sys Thu Jan 13 11:57:19 2011: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC please update using the link provided above for the motherboard support page. Look under Realtek LAN for the 2015 update.
HECIx64.sys Wed Oct 20 00:33:43 2010: Intel Management Engine Interface please update. You need both drivers found under 'chipset' on the moBo support page.
RTKVHD64.sys Fri Feb 11 10:16:05 2011: Realtek High Definition Audio Function Driver please update using the latest driver from Realtek:
Realtek
Can you ensure that all browsers are latest versions.
See how you go with those changes and please post any new dump files.
