Elmer
To Enable Minidumps:
The *.dmp files are located at C:\Windows\Minidump. Until a *.dmp file is generated, the Minidump folder may not exist.
GoTo your C:\Windows\Minidump folder. Copy the *.dmp files to a new folder on your desktop. Zip up the *.dmp files from that folder and attach to a post.
This btw, is a canned speech post, so if you know most of the answers, ignore it!
Where was you advised to uninstall Steam?
- Go to Start, in the Search Box type: sysdm.cpl, press Enter.
- Under the Advanced tab, click on the Startup and Recovery > Settings... button.
- Ensure that Automatically restart is unchecked.
- Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
- Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
- OK your way out.
- Reboot if changes have been made.
