BSOD problems
Hi, Recently i've been getting BSOD's lately. I have reinstalled my OS to make sure that it wasn't a driver issue however i am unsure to which the problem is. I will attach the minidump files, If anyone could help me figure out the issue it would be much appreciated :)
Here are my system specs:
Operating System: Windows 7 Ultimate 64bit
Motherboard: Asus P5N-T Deluxe
Memory: Corsair XMS6400 4GB 800mhz
Processor: Intel Core 2 Quad Q9450 Yorkfield 2.66ghz, 12mb cache.
Hard Drive: Intel X25-V Mainstream 40GB, x2 Samsung SpinPoint 1TB 32MB Cache
Power Supply: Corsair 650W
Sound Card: Creative X-FI Xtreme Gamer
Graphics Card: Sapphire Radeon 6850 Toxic Edition 1GB
If you require anymore information, Let me know and i will try to get as much as i can.
Thanks
051311-13291-01.dmp
BugCheck D1, {cd9, 7, 1, fffff88001098350}
CURRENT_IRQL: 2
Probably caused by : memory_corruption
051311-19671-01.dmp
BugCheck D1, {fffff88064d30428, 2, 1, fffff880010cfeba}
CURRENT_IRQL: 2
Probably caused by : nvstor64.sys ( nvstor64+1ceba )
1. Make sure your hardware is running at stock now.
2. Replace Avast with MSE:
avast! Uninstall Utility
Virus, Spyware & Malware Protection | Microsoft Security Essentials
3. Check for the latest nForce at nVidia's site.
4. Update Creative drivers and software,
ctac32k.sys Wed Jul 02 04:38:22 2008
CRASH DUMPS
Loading Dump File [F:\DMP\051311-13291-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16792.amd64fre.win7_gdr.110408-1633
Machine Name:
Kernel base = 0xfffff800`02a19000 PsLoadedModuleList = 0xfffff800`02c56e50
Debug session time: Thu May 12 18:31:37.067 2011 (UTC - 4:00)
System Uptime: 0 days 2:41:39.221
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\system32\DRIVERS\nvstor64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvstor64.sys
*** ERROR: Module load completed but symbols could not be loaded for nvstor64.sys
Followup: memory_corruption
3: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000cd9, memory referenced
Arg2: 0000000000000007, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88001098350, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc10e0
 0000000000000cd9
CURRENT_IRQL:  7
FAULTING_IP:
storport!RaidGetKeyFromUnit+0
fffff880`01098350 0000            add     byte ptr [rax],al
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0xD1
PROCESS_NAME:  dwm.exe
TRAP_FRAME:  fffff8800af79700 -- (.trap 0xfffff8800af79700)
rax=0000000000000cd9 rbx=0000000000000000 rcx=fffffa8004ac91e8
rdx=000000000000000c rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001098350 rsp=fffff8800af79898 rbp=fffffa8004abb7b0
 r8=fffff8800af79910  r9=0000000000010100 r10=fffff88003d340e8
r11=fffff8800af799d0 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
storport!RaidGetKeyFromUnit:
fffff880`01098350 0000            add     byte ptr [rax],al ds:e963:00000000`00000cd9=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002a88c69 to fffff80002a89700
STACK_TEXT:
fffff880`0af795b8 fffff800`02a88c69 : 00000000`0000000a 00000000`00000cd9 00000000`00000007 00000000`00000001 : nt!KeBugCheckEx
fffff880`0af795c0 fffff800`02a878e0 : fffffa80`07444000 00000000`c0000225 00000000`0027bcce 00000000`00000001 : nt!KiBugCheckDispatch+0x69
fffff880`0af79700 fffff880`01098350 : fffff880`0108fc97 00000000`00000000 fffffa80`08190b30 fffffa80`000a9ea2 : nt!KiPageFault+0x260
fffff880`0af79898 fffff880`0108fc97 : 00000000`00000000 fffffa80`08190b30 fffffa80`000a9ea2 fffffa80`04e3b000 : storport!RaidGetKeyFromUnit
fffff880`0af798a0 fffff880`0109b347 : 00000000`00000002 00000000`00000000 fffffa80`04ae2008 fffffa80`04ad81b0 : storport!StorFindDictionary+0x57
fffff880`0af798e0 fffff880`0109e753 : 00000000`00000000 00000000`00000000 fffffa80`04ae2008 fffffa80`04acd040 : storport!RaidAdapterFindUnitAtDirql+0x37
fffff880`0af79910 fffff880`0109f46f : 00000000`00000000 fffffa80`03000101 fffffa80`04ae2008 fffffa80`04acd2b0 : storport!RaidAdapterFindUnit+0x43
fffff880`0af79940 fffff880`010ec83b : fffff880`03000101 fffffa80`04acd040 fffffa80`08afd0d0 fffff800`02a91de7 : storport!StorPortGetLogicalUnit+0x2f
fffff880`0af79970 fffff880`03000101 : fffffa80`04acd040 fffffa80`08afd0d0 fffff800`02a91de7 fffff880`00000000 : nvstor64+0x183b
fffff880`0af79978 fffffa80`04acd040 : fffffa80`08afd0d0 fffff800`02a91de7 fffff880`00000000 fffff800`02c03e00 : 0xfffff880`03000101
fffff880`0af79980 fffffa80`08afd0d0 : fffff800`02a91de7 fffff880`00000000 fffff800`02c03e00 fffff880`03d340e8 : 0xfffffa80`04acd040
fffff880`0af79988 fffff800`02a91de7 : fffff880`00000000 fffff800`02c03e00 fffff880`03d340e8 00000000`00003000 : 0xfffffa80`08afd0d0
fffff880`0af79990 00000000`00000000 : fffff880`0108ae70 00000000`00003000 00000000`00000002 00000000`00003000 : nt!KeUpdateSystemTime+0x377
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !storport
    fffff88001098000-fffff8800109800b  12 bytes - storport!RaInitializeRaidResources+30
    [ 94 c0 83 61 38 00 c7 41:00 9c 00 ff 00 9b 00 ff ]
    fffff8800109800d-fffff8800109801b  15 bytes - storport!RaInitializeRaidResources+3d (+0x0d)
    [ 88 41 28 44 89 69 24 4c:9b 00 ff 00 8e 00 ff 00 ]
    fffff8800109801d-fffff8800109801e  2 bytes - storport!RaInitializeRaidResources+4d (+0x10)
    [ 00 33:34 00 ]
    fffff88001098020-fffff88001098046  39 bytes - storport!RaInitializeRaidResources+50 (+0x03)
    [ 80 7b 28 00 75 0f ba 52:00 16 00 ff 02 00 19 ff ]
    fffff88001098048-fffff88001098068  33 bytes - storport!RaInitializeRaidResources+78 (+0x28)
    [ 48 8b f0 48 85 c0 74 1f:01 00 18 ff 01 00 17 ff ]
    fffff8800109806a-fffff8800109806e  5 bytes - storport!RaInitializeRaidResources+9a (+0x22)
    [ 00 72 b3 eb 03:17 ff 01 00 1a ]
    fffff88001098070-fffff880010980da  107 bytes - storport!RaInitializeRaidResources+a0 (+0x06)
    [ 43 38 3b 7b 1c 73 17 44:40 3d 5a ff 80 7c 9b ff ]
    fffff880010980dc-fffff880010980df  4 bytes - storport!StorNextIoGatewayItem+1c (+0x6c)
    [ ff 15 d6 cf:00 00 01 ff ]
    fffff880010980e2-fffff8800109812e  77 bytes - storport!StorNextIoGatewayItem+22 (+0x06)
    [ 48 8d 54 24 20 48 8b cb:01 ff 00 00 00 ff 00 00 ]
    fffff88001098130-fffff88001098136  7 bytes - storport!StorNextIoGatewayItem+70 (+0x4e)
    [ 15 13 cf 00 00 48 85:8d 89 a2 ff a2 9e b8 ]
    fffff88001098138-fffff8800109815d  38 bytes - storport!StorNextIoGatewayItem+78 (+0x08)
    [ 74 74 48 8d 4b 40 ff 15:6d 69 82 ff 38 34 4e ff ]
    fffff8800109815f-fffff88001098167  9 bytes - storport!StorNextIoGatewayItem+9f (+0x27)
    [ 00 48 89 46 08 48 83 61:ff 00 00 00 ff 00 00 00 ]
    fffff88001098169-fffff8800109816c  4 bytes - storport!StorNextIoGatewayItem+a9 (+0x0a)
    [ 48 83 61 18:00 00 ff 00 ]
    fffff8800109816e-fffff88001098171  4 bytes - storport!StorNextIoGatewayItem+ae (+0x05)
    [ 48 83 61 48:00 ff 00 00 ]
    fffff88001098173-fffff8800109817b  9 bytes - storport!StorNextIoGatewayItem+b3 (+0x05)
    [ 48 83 61 50 00 48 83 61:ff 00 00 00 ff 00 00 00 ]
    fffff8800109817d-fffff88001098180  4 bytes - storport!StorNextIoGatewayItem+bd (+0x0a)
    [ 48 83 61 70:00 00 ff 00 ]
    fffff88001098182-fffff88001098185  4 bytes - storport!StorNextIoGatewayItem+c2 (+0x05)
    [ 48 83 a1 98:00 ff 00 00 ]
    fffff88001098187 - storport!StorNextIoGatewayItem+c7 (+0x05)
    [ 00:ff ]
    fffff8800109818a-fffff8800109818d  4 bytes - storport!StorNextIoGatewayItem+ca (+0x03)
    [ 48 83 a1 a0:00 ff 00 00 ]
    fffff8800109818f - storport!StorNextIoGatewayItem+cf (+0x05)
    [ 00:ff ]
    fffff88001098192-fffff88001098199  8 bytes - storport!StorNextIoGatewayItem+d2 (+0x03)
    [ 80 61 10 dc 48 83 61 58:00 ff 00 00 00 ff 00 00 ]
    fffff8800109819b-fffff88001098200  102 bytes - storport!StorNextIoGatewayItem+db (+0x09)
    [ b8 ff ff 00 00 66 89 41:ff 00 00 03 ff 00 00 06 ]
    fffff88001098202-fffff88001098206  5 bytes - storport!StorSubmitIoGatewayItem+32 (+0x67)
    [ 8b cf e8 67 fc:5d ff 01 00 0c ]
    fffff88001098208-fffff88001098235  46 bytes - storport!StorSubmitIoGatewayItem+38 (+0x06)
    [ ff 33 db 39 5f 2c 7f 2e:00 00 00 ff 00 00 00 ff ]
    fffff88001098237 - storport!StorSubmitIoGatewayItem+67 (+0x2f)
    [ 00:ff ]
    fffff88001098239-fffff8800109824b  19 bytes - storport!StorSubmitIoGatewayItem+69 (+0x02)
    [ 40 b6 01 eb 1d 48 8d 4f:00 00 ff 00 00 00 ff 00 ]
    fffff8800109824d-fffff88001098263  23 bytes - storport!StorSubmitIoGatewayItem+7d (+0x14)
    [ 48 89 45 08 48 89 28 48:00 00 ff 00 00 02 ff 00 ]
    fffff88001098266-fffff8800109826e  9 bytes - storport!StorSubmitIoGatewayItem+96 (+0x19)
    [ 40 3a f3 74 70 48 8d 4f:10 ff 00 00 10 ff 00 00 ]
    fffff88001098270-fffff88001098273  4 bytes - storport!StorSubmitIoGatewayItem+a0 (+0x0a)
    [ 15 4b ce 00:00 00 0f ff ]
    fffff88001098275-fffff880010982dc  104 bytes - storport!StorSubmitIoGatewayItem+a5 (+0x05)
    [ 4c 8b d8 48 8d 48 10 48:00 0f ff 00 00 0f ff 00 ]
    fffff880010982de-fffff88001098318  59 bytes - storport!StorSubmitIoGatewayItem+10e (+0x69)
    [ 00 00 48 8b 6c 24 58 48:0e ff 01 00 11 ff 01 00 ]
    fffff8800109831a-fffff88001098394  123 bytes - storport!RaidUnitConvertToNormalUnit+a (+0x3c)
    [ 00 00 20 48 8b d9 74 18:0e ff 00 00 0e ff 00 00 ]
    fffff88001098396-fffff880010983a6  17 bytes - storport!RaidUnitGetCompatibleIds+16 (+0x7c)
    [ 00 00 48 8b f1 8d 4a c9:10 ff 00 00 0f ff 00 00 ]
    fffff880010983a8-fffff880010983b3  12 bytes - storport!RaidUnitGetCompatibleIds+28 (+0x12)
    [ ff 33 ed 48 8b d8 48 3b:00 00 0f ff 00 00 0f ff ]
    fffff880010983b6-fffff8800109843f  138 bytes - storport!RaidUnitGetCompatibleIds+36 (+0x0e)
    [ 00 48 8b 4e 50 8d 55 1c:0f ff 00 00 0f ff 01 01 ]
    fffff88001098500-fffff8800109850a  11 bytes - storport!RaidUnitGetHardwareIds+80 (+0x14a)
    [ 78 08 48 8b e8 48 8d 05:22 23 20 ff 22 23 20 ff ]
    fffff8800109850c-fffff88001098536  43 bytes - storport!RaidUnitGetHardwareIds+8c (+0x0c)
    [ 48 89 7c 24 38 48 89 4c:21 22 20 ff 21 22 20 ff ]
    fffff88001098538-fffff8800109855b  36 bytes - storport!RaidUnitGetHardwareIds+b8 (+0x2c)
    [ 48 8b 8c 24 80 00 00 00:03 06 03 ff 03 06 03 ff ]
    fffff8800109855d-fffff88001098563  7 bytes - storport!RaidUnitGetHardwareIds+dd (+0x25)
    [ 48 89 94 24 88 00 00:00 1d ff 00 00 23 ff ]
    fffff88001098565-fffff88001098568  4 bytes - storport!RaidUnitGetHardwareIds+e5 (+0x08)
    [ 0f 8c d9 01:00 25 ff 00 ]
    fffff8800109856a-fffff88001098571  8 bytes - storport!RaidUnitGetHardwareIds+ea (+0x05)
    [ 00 48 8b 45 00 4c 89 64:24 ff 00 00 24 ff 00 00 ]
    fffff88001098573-fffff88001098582  16 bytes - storport!RaidUnitGetHardwareIds+f3 (+0x09)
    [ 40 48 89 7c 24 38 48 89:ff 00 00 24 ff 00 00 24 ]
    fffff88001098584-fffff8800109858b  8 bytes - storport!RaidUnitGetHardwareIds+104 (+0x11)
    [ ff 4c 8d 8c 24 88 00 00:00 00 23 ff 00 00 23 ff ]
    fffff8800109858d-fffff88001098597  11 bytes - storport!RaidUnitGetHardwareIds+10d (+0x09)
    [ 48 89 44 24 28 4c 8d 84:00 22 ff 00 00 22 ff 00 ]
    fffff8800109859a-fffff880010985a2  9 bytes - storport!RaidUnitGetHardwareIds+11a (+0x0d)
    [ 4c 89 74 24 20 e8 9c bf:21 ff 00 00 21 ff 00 00 ]
    fffff880010985a4-fffff880010985a8  5 bytes - storport!RaidUnitGetHardwareIds+124 (+0x0a)
    [ 48 8b 8c 24 80:00 00 20 ff 00 ]
    fffff880010985aa-fffff880010985b0  7 bytes - storport!RaidUnitGetHardwareIds+12a (+0x06)
    [ 00 00 48 8b 94 24 88:20 ff 00 00 20 ff 00 ]
    fffff880010985b2-fffff880010985c3  18 bytes - storport!RaidUnitGetHardwareIds+132 (+0x08)
    [ 00 00 48 83 c1 02 48 ff:20 ff 00 00 21 ff 00 00 ]
    fffff880010985c6-fffff880010985cb  6 bytes - storport!RaidUnitGetHardwareIds+146 (+0x14)
    [ 48 89 94 24 88 00:21 ff 00 00 21 ff ]
    fffff880010985ce-fffff880010985d4  7 bytes - storport!RaidUnitGetHardwareIds+14e (+0x08)
    [ 44 8b d8 0f 8c 6d 01:21 ff 00 00 21 ff 00 ]
WARNING: !chkimg output was truncated to 50 lines. Invoke !chkimg without '-lo [num_lines]' to view  entire output.
3767 errors : !storport (fffff88001098000-fffff88001098fff)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  LARGE_4096
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_LARGE_4096
Loading Dump File [F:\DMP\051311-19671-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a1b000 PsLoadedModuleList = 0xfffff800`02c58e50
Debug session time: Fri May 13 10:03:57.236 2011 (UTC - 4:00)
System Uptime: 0 days 0:28:06.000
Followup: MachineOwner
0: kd> !analyze -v
Arguments:
Arg1: fffff88064d30428, memory referenced
Arg2: 0000000000000002, IRQL
Arg4: fffff880010cfeba, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc30e0
 fffff88064d30428
CURRENT_IRQL:  2
FAULTING_IP:
nvstor64+1ceba
fffff880`010cfeba 5d              pop     rbp
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff8800ca70270 -- (.trap 0xfffff8800ca70270)
rax=fffff880010d04e8 rbx=0000000000000000 rcx=fffff88003d30380
rdx=00000000c0000010 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880010cfeba rsp=fffff8800ca70400 rbp=fffffa8004aeb000
 r8=0000000000000000  r9=0000000000000002 r10=fffff88003d300e8
r11=fffff88003d303c0 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
nvstor64+0x1ceba:
LAST_CONTROL_TRANSFER:  from fffff80002a8ac69 to fffff80002a8b700
STACK_TEXT:
fffff880`0ca70128 fffff800`02a8ac69 : 00000000`0000000a fffff880`64d30428 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`0ca70130 fffff800`02a898e0 : 00000008`00000008 fffff880`03d30380 0000000c`00000040 ffffffff`0000000c : nt!KiBugCheckDispatch+0x69
fffff880`0ca70270 fffff880`010cfeba : 00000000`00000002 00000000`00000000 fffffa80`04af6008 fffffa80`04ad61b0 : nt!KiPageFault+0x260
fffff880`0ca70400 00000000`00000002 : 00000000`00000000 fffffa80`04af6008 fffffa80`04ad61b0 fffff880`03d30380 : nvstor64+0x1ceba
fffff880`0ca70408 00000000`00000000 : fffffa80`04af6008 fffffa80`04ad61b0 fffff880`03d30380 fffff880`010b8372 : 0x2
STACK_COMMAND:  kb
FOLLOWUP_IP:
nvstor64+1ceba
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nvstor64+1ceba
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvstor64
IMAGE_NAME:  nvstor64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4bbef1e1
FAILURE_BUCKET_ID:  X64_0xD1_nvstor64+1ceba
DRIVERS
fffff880`0803f000 fffff880`0807d000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f9b000 fffff880`00ff2000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`042cc000 fffff880`04356000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`081e0000 fffff880`081f6000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010f2000 fffff880`010fd000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`087f0000 fffff880`087f9000   aswFsBlk aswFsBlk.SYS Mon Apr 18 13:13:00 2011 (4DAC711C)
fffff880`0193e000 fffff880`01978000   aswMonFlt aswMonFlt.sys Mon Apr 18 13:13:11 2011 (4DAC7127)
fffff880`04356000 fffff880`04360000   aswRdr   aswRdr.SYS   Mon Apr 18 13:13:23 2011 (4DAC7133)
fffff880`04027000 fffff880`040bf000   aswSnx   aswSnx.SYS   Mon Apr 18 13:17:58 2011 (4DAC7246)
fffff880`06ec7000 fffff880`06f14000   aswSP    aswSP.SYS    Mon Apr 18 13:17:56 2011 (4DAC7244)
fffff880`04174000 fffff880`04184000   aswTdi   aswTdi.SYS   Mon Apr 18 13:16:21 2011 (4DAC71E5)
fffff880`00ed1000 fffff880`00eda000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00db8000 fffff880`00de2000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`09172000 fffff880`09192000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`07246000 fffff880`07b7a000   atikmdag atikmdag.sys Tue Apr 19 21:53:29 2011 (4DAE3C99)
fffff880`06f50000 fffff880`06fa0000   atikmpag atikmpag.sys Tue Apr 19 21:22:32 2011 (4DAE3558)
fffff880`040c8000 fffff880`040cf000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`06eb6000 fffff880`06ec7000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0635b000 fffff880`06379000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`007c0000 fffff960`007e7000   cdd      cdd.dll      unavailable (00000000)
fffff880`019a8000 fffff880`019d2000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00edb000 fffff880`00f9b000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0190e000 fffff880`0193e000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cfd000 fffff880`00d5b000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01177000 fffff880`011ea000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0807d000 fffff880`0808d000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`09192000 fffff880`091a0000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`06e15000 fffff880`06e98000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`08600000 fffff880`08635000   CT20XUT  CT20XUT.SYS  Wed May 05 09:01:28 2010 (4BE16C28)
fffff880`08725000 fffff880`087d3000   ctac32k  ctac32k.sys  Wed Jul 02 04:38:22 2008 (486B3E7E)
fffff880`08098000 fffff880`0813d700   ctaud2k  ctaud2k.sys  Wed May 05 08:59:48 2010 (4BE16BC4)
fffff880`09015000 fffff880`09172000   CTEXFIFX CTEXFIFX.SYS Wed May 05 09:01:21 2010 (4BE16C21)
fffff880`08be0000 fffff880`08bfb000   CTHWIUT  CTHWIUT.SYS  Wed May 05 09:01:32 2010 (4BE16C2C)
fffff880`08000000 fffff880`08031000   ctoss2k  ctoss2k.sys  Wed May 05 08:57:46 2010 (4BE16B4A)
fffff880`08031000 fffff880`08039000   ctprxy2k ctprxy2k.sys Wed May 05 08:59:51 2010 (4BE16BC7)
fffff880`086ed000 fffff880`08725000   ctsfm2k  ctsfm2k.sys  Wed May 05 08:57:33 2010 (4BE16B3D)
fffff880`06e98000 fffff880`06eb6000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0429d000 fffff880`042ac000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`018f8000 fffff880`0190e000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0817b000 fffff880`0819d000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04200000 fffff880`04243000   dtsoftbus01 dtsoftbus01.sys Thu Jan 13 03:27:08 2011 (4D2EB75C)
fffff880`091a0000 fffff880`091aa000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
fffff880`091e9000 fffff880`091fc000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`091aa000 fffff880`091e9000   dump_nvstor64 dump_nvstor64.sys Fri Apr 09 05:22:41 2010 (4BBEF1E1)
fffff880`09000000 fffff880`0900c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`07c51000 fffff880`07d45000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`07d45000 fffff880`07d8b000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`08a00000 fffff880`08a4a000   emupia2k emupia2k.sys Wed May 05 08:57:27 2010 (4BE16B37)
fffff880`01149000 fffff880`0115d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010fd000 fffff880`01149000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01000000 fffff880`0100a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018be000 fffff880`018f8000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`07c00000 fffff880`07c0d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff880`08a5f000 fffff880`08be0000   ha20x2k  ha20x2k.sys  Wed May 05 08:59:10 2010 (4BE16B9E)
fffff800`02ff7000 fffff800`03040000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`07d8b000 fffff880`07daf000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`08643000 fffff880`0865c000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0900c000 fffff880`09014080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`08635000 fffff880`08643000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`06293000 fffff880`0635b000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018b5000 fffff880`018be000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`06f3a000 fffff880`06f50000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`07c3d000 fffff880`07c4c000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`08669000 fffff880`08677000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba4000 fffff800`00bae000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`0819d000 fffff880`081e0000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0115d000 fffff880`01177000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015c1000 fffff880`015ec000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`08039000 fffff880`0803e200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`01978000 fffff880`0198d000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`041d5000 fffff880`041f8000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ca5000 fffff880`00ce9000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`08677000 fffff880`08685000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`06e00000 fffff880`06e0f000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0865c000 fffff880`08669000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c6c000 fffff880`00c86000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`06379000 fffff880`06391000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06391000 fffff880`063be000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:15:23 2011 (4D6497EB)
fffff880`06200000 fffff880`0624e000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:15:14 2011 (4D6497E2)
fffff880`0624e000 fffff880`06271000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:15:13 2011 (4D6497E1)
fffff880`0412d000 fffff880`04138000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00eb3000 fffff880`00ebd000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01200000 fffff880`0125e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`04292000 fffff880`0429d000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018a3000 fffff880`018b5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0146f000 fffff880`01561000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`07c31000 fffff880`07c3d000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`07bd0000 fffff880`07bff000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`08a4a000 fffff880`08a5f000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`043d4000 fffff880`043e3000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04360000 fffff880`043a5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01561000 fffff880`015c1000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`04138000 fffff880`04149000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04286000 fffff880`04292000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a1b000 fffff800`02ff7000   nt       ntkrnlmp.exe Sat Apr 09 00:14:44 2011 (4D9FDD34)
fffff880`0125e000 fffff880`01400000   Ntfs     Ntfs.sys     Thu Mar 10 22:39:25 2011 (4D79996D)
fffff880`040bf000 fffff880`040c8000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06fa0000 fffff880`06ff3600   nvmf6264 nvmf6264.sys Wed Nov 11 18:16:48 2009 (4AFB45E0)
fffff880`01026000 fffff880`01051000   nvstor   nvstor.sys   Fri Mar 19 16:45:11 2010 (4BA3E257)
fffff880`010b3000 fffff880`010f2000   nvstor64 nvstor64.sys Fri Apr 09 05:22:41 2010 (4BBEF1E1)
fffff880`043ae000 fffff880`043d4000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00d8e000 fffff880`00da3000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d5b000 fffff880`00d8e000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00eca000 fffff880`00ed1000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`011ea000 fffff880`011fb000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0961d000 fffff880`096c3000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0813e000 fffff880`0817b000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ce9000 fffff880`00cfd000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`07c0d000 fffff880`07c31000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`07200000 fffff880`0721b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0721b000 fffff880`0723c000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`042ac000 fffff880`042c6000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04184000 fffff880`041d5000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0808d000 fffff880`08098000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`04112000 fffff880`0411b000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0411b000 fffff880`04124000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04124000 fffff880`0412d000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01869000 fffff880`018a3000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0198d000 fffff880`019a5000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0427c000 fffff880`04286000   SASDIFSV64 SASDIFSV64.SYS Mon Feb 08 19:11:52 2010 (4B70A848)
fffff880`04272000 fffff880`0427c000   SASKUTIL64 SASKUTIL64.SYS Tue Feb 09 17:27:34 2010 (4B71E156)
fffff880`096c3000 fffff880`096ce000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`07dcc000 fffff880`07dd8000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`07daf000 fffff880`07dcc000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01861000 fffff880`01869000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0a48a000 fffff880`0a51f000   srv      srv.sys      Wed Feb 23 00:16:24 2011 (4D649828)
fffff880`0977e000 fffff880`097e5000   srv2     srv2.sys     Wed Feb 23 00:15:59 2011 (4D64980F)
fffff880`096ce000 fffff880`096fb000   srvnet   srvnet.sys   Wed Feb 23 00:15:49 2011 (4D649805)
fffff880`01051000 fffff880`010b3000   storport storport.sys Thu Mar 10 23:24:35 2011 (4D79A403)
fffff880`081f6000 fffff880`081f7480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`096fb000 fffff880`0970d000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`04167000 fffff880`04174000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`04149000 fffff880`04167000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0425e000 fffff880`04272000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004a0000 fffff960`004aa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`06f14000 fffff880`06f3a000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0a51f000 fffff880`0a573000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`043e3000 fffff880`043f5000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0a573000 fffff880`0a58dc00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`087d3000 fffff880`087f0000   usbccgp  usbccgp.sys  Thu Mar 24 23:23:03 2011 (4D8C0A97)
fffff880`091fc000 fffff880`091fdf00   USBD     USBD.SYS     Thu Mar 24 23:22:51 2011 (4D8C0A8B)
fffff880`07de3000 fffff880`07df4000   usbehci  usbehci.sys  Thu Mar 24 23:22:57 2011 (4D8C0A91)
fffff880`08693000 fffff880`086ed000   usbhub   usbhub.sys   Thu Mar 24 23:23:22 2011 (4D8C0AAA)
fffff880`07dd8000 fffff880`07de3000   usbohci  usbohci.sys  Thu Mar 24 23:22:56 2011 (4D8C0A90)
fffff880`07b7a000 fffff880`07bd0000   USBPORT  USBPORT.SYS  Thu Mar 24 23:23:03 2011 (4D8C0A97)
fffff880`00ebd000 fffff880`00eca000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`040cf000 fffff880`040dd000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`040dd000 fffff880`04102000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0144a000 fffff880`0145a000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00da3000 fffff880`00db8000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01815000 fffff880`01861000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`04243000 fffff880`0425e000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`04102000 fffff880`04112000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`043a5000 fffff880`043ae000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a2000   win32k   win32k.sys   unavailable (00000000)
fffff880`00ff2000 fffff880`00ffb000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`04000000 fffff880`04021000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0970d000 fffff880`0977e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0193e000 fffff880`0194c000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0194c000 fffff880`01956000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01956000 fffff880`01995000   dump_nvstor6
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`01995000 fffff880`019a8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Okay, I've done everything you've said, Reinstalled my Chipset and my Audio Drivers with the fully updated ones and replaced Avast with MSE. Now just to wait and see and hope the problem has resolved :)
Let's hope, but if blue screens reoccur, attach this:
- passmark RAMMon HTML.zip
- cpu-z MEMORY and CPU tabs
