Windows 10 BSOD sporadic. SSD issue?
JMor90
Getting BSOD often. Sometimes every few minutes. Complete power removed seems to help.
This is a 5 year old PC.
Upgraded from Win 7 to Win 10. Seemed stable at the time.
Issues started in December 2015.
Getting a host of different errors. Most often: critical process died, unexpected store exception, disk read error.
Windows is on C: (6 month old Samsung SSD) drive with most files on E: (5 yr old SATA HDD).
BugCheck 119, {700, 31e8a, 31e90, 0}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : dxgmms2.sys ( dxgmms2!VidSchiAdvanceContextSubmissionId+797b )
Followup: MachineOwner...
the above bugcheck 119 means the video scheduler suffered a fatal violation causing the bsod. I can also see in the 'Call Stack' ( a blow by blow account of the last sub routines) that the Nvidia driver was involved.
Looking through your drivers however I see some which are simply too old for Windows 10:
anodlwfx.sys Fri Mar 06 10:10:08 2009: ALPHA Networks Filter Driver Is this something you added as the motherboard carries a Realtek Lan chip? If it's no longer used please remove.
HECIx64.sys Thu Sep 17 20:54:16 2009: Intel engine management driver. A slightly later version is on the motherboard support page. It's in the Windows 7 section so try installing under compatibility mode.
GIGABYTE - Motherboard - Socket 1156 - GA-H57M-USB3 (rev. 2.0)
iaStor.sys Fri Oct 02 20:58:50 2009: Intel rapid storage driver. Same as the above.
MarvinBus64.sys Fri Sep 23 22:17:03 2005: likely a part of Pinnacle Studio's Marvin Bus? Please update if possible:
Pinnacle Systems - Software Updates
nvlddmkm.sys Thu Nov 05 14:35:23 2015: Nvidia display driver. Try re-installing your gpu driver but first remove the original using the Display driver uninstaller which will also remove any old bits of driver left behind by previous installs:
Display Driver Uninstaller (DDU) V15.7.3.0 Released. - Wagnardmobile Forum
Re-install driver:
Drivers - Download NVIDIA Drivers
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Post any new dump files.
