* Bugcheck Analysis *
BugCheck 3D, {fffff8031992fad8, fffff8031992f2f0, 0, 0}
*** WARNING: Unable to verify timestamp for iaStorAV.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStorAV.sys
Probably caused by : iaStorAV.sys ( iaStorAV+688b )
Followup: MachineOwner
out of the dump files posted this was the only one to actually mention a driver. One was too corrupt to open and the others: 3x Bugcheck 7e (out of date bios, new hardware issues and device driver issues), 1x Bugcheck A (device driver issues, bios issues and system service issues) all blame the system kernel.
The above probable cause is your Intel Rapid storage driver. As it's the only dump file to mention anything specific we'll start with the obvious and see how we go.
iaStorAV.sys Thu Feb 19 12:08:39 2015: Intel Rapid Storage Technology driver. Laptop drivers are almost exclusively supplied by the manufacturer apart from some GPU drivers. I see looking on your systems support page that you have a slightly later driver than the one above. Please first remove the original driver before installing the new version.
Product Support | Dell US Regarding your GPU driver, this is going to sound odd but please re-install the nvidia gpu driver off the support site:
nVIDIA GeForce GTX660, GTX670, GTX680, GTX690, GTX760, GTX760Ti, GTX770, GTX780, GTX960, GTX970, GTX980, GTX980Ti, GTX TitanX, GTX TitanZ Win10 64bit WHQL Desktop Graphics Driver Driver Details | Dell US The reason I want you to do this is so you can then use the Display Driver Uninstaller to then remove the driver. This has to be done in safe mode and the DDU will remove everything including anything left behind by previous GPU driver installs
Display Driver Uninstaller (DDU) V15.7.5.5 Released. - Wagnardmobile Forum Once you've removed the driver and rebooted, install the driver again and hopefully this time you won't have any issues.
Please run these scans to check for and repair corruption:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Ok see how you get on. If the bsod continues then you may want to consider applying a bios update which is available. Check the support page under bios but if your not familiar with the process then you may want to get another to do it?
Post any new dump files.
