Windows 7 BSOD, when using pc generally, or playing games.
Bortelli
Hello, My Pc Always crashes whenever I play games, or just randomly when I'm on the web. Operating System
Microsoft Windows 8 Pro 64-bit
CPU
AMD Phenom II X4 965 29 °C
Deneb 45nm Technology
RAM
8.00 GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
Motherboard
MICRO-STAR INTERNATIONAL CO.,LTD 760GM -E51 (MS-7596) (CPU1) 20 °C
Graphics
TF-TV3207E* (1920x1080@30Hz)
AMD Radeon HD 6900 Series (Gigabyte)
Hard Drives
932GB Seagate ST31000524AS ATA Device (SATA) 29 °C
Optical Drives
DTSOFT Virtual CdRom Device
Audio
High Definition Audio Device
  • dump file.rar
usasma
Fantastic Member
Sorry for the delay in responding. There just aren't that many people who do BSOD analysis, so at times we get a bit overwhelmed!
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions). I strongly suspect that this hold true for Win8 systems also.
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Rt630x64.sys Wed Oct 19 08:12:55 2011 (4E9EBEC7)
Realtek PCI/PCIe Adapters
http://www.carrona.org/drivers/driver.php?id=Rt630x64.sys
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Fri Jan 18 18:49:26.334 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011813-14000-01.dmp]
Windows 8 Kernel Version 9200 MP (4 procs) Free x64
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 3:52:06.043[/B]
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
Probably caused by :[B]atikmdag.sys ( atikmdag+22a6c )[/B]
BugCheck [B]A0000001, {5, 0, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]Unknown bugcheck code (a0000001)[/URL]
Arguments:
Arg1: 0000000000000005
Arg2: 0000000000000000
Arg3: 0000000000000000
Arg4: 0000000000000000
BUGCHECK_STR:  0xA0000001
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]0xA0000001_atikmdag+22a6c[/B]
  BIOS Version                  V1.10
  BIOS Release Date             02/28/2011
  Manufacturer                  MICRO-STAR INTERNATIONAL CO.,LTD
  Product Name                  MS-7596
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]Rt630x64.sys                Wed Oct 19 08:12:55 2011 (4E9EBEC7)[/B][/COLOR]
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
[COLOR=RED][B]AODDriver2.sys              Tue Mar  6 04:55:00 2012 (4F55DEF4)[/B][/COLOR]
atikmpag.sys                Sun Dec  2 02:13:21 2012 (50BAFF91)
atikmdag.sys                Sun Dec  2 03:21:53 2012 (50BB0FA1)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
Top Bottom
