poizondragon
Hello all, and thanks for your time....99% of my bluescreens occur while watching Youtube or any other video. I've tried disabling hardware acceleration in flash, but that doesn't seem to work. The other 1% seems to happen randomly while I'm away from the computer(All together, I get about 3-4 a week). I never put it to sleep; I have the display turn off after 15 minutes of idle. I used the diagnostic tool uploaded by Capt. Jack Sparrow(awesome program btw :D), and will provide all the info I can here. Any help would be appreciated! Thanks again!
P.S. On 8/27 of this year, I sent back a stick of memory to Cyberpower and had it replaced; (I ran Memtest and found that one of the sticks was bad). Everything seemed fine for about 2-3 weeks, and then it started again. With this said, any bsods on 8/27 or prior will probably point to memory; I'm only concerned about those that happened afterwards. Hope that makes sense :D
General Spec BrandCyberpowerPC ModelGamer Xtreme 1047 TypeGaming ProcessorIntel Core i7 860(2.8GHz) Processor Main Features64 bit Quad-Core Processor Memory4GB (2x2GB) DDR3 1333 Hard Drive1TB SATA-II 3.0Gb/s 7200RPM HDD Optical Drive 124X DVD±R/±RW Dual Layer Drive GraphicsATI Radeon HD 5850 1GB PCI Express Video Card AudioSound card - Integrated EthernetGigabit LAN Power Supply800W
Operating SystemWindows 7 Home Premium 64-bit Special FeaturesX-Cruiser 2 Gaming Case Motherboard ChipsetIntel P55M-UD2 CPU CPU TypeIntel Core i7 Installed Qty1 CPU Speed860(2.80GHz) L3 Cache Per CPU8MB CPU Socket TypeLGA 1156 CPU Main Features64 bit Quad-Core Processor Graphics GPU/VPU TypeATI Radeon HD 5850 Graphics InterfacePCI Express 2.0 x16 Memory Memory Capacity4GB DDR3 Memory SpeedDDR3 1333 Form FactorDIMM 240-pin Memory Spec2GB x 2 Memory Slot (Total)4 Memory Slot (Available)2 Maximum Memory Supported16GB Hard Drive HDD Capacity1TB HDD InterfaceSATA II HDD RPM7200rpm Optical Drive Optical Drive TypeDVD±RW Optical Drive Spec24X DVD±R/±RW Dual Layer Drive Audio Audio ChipsetIntegrated Communications LAN ChipsetIntegrated LAN Speed10/100/1000Mbps Front Panel Ports Front USB2 Front IEEE 13941 Front Audio Ports2 Back Panel Ports PS/21 Video Ports2 DVI, 1 HDMI, 1 Display Port Rear USB10 Rear IEEE 13941 eSATA1 RJ451 port Rear Audio Ports6 ports S/P DIF1 x Optical S/PDIF Out
1 x Coaxial S/PDIF Out Expansion PCI Slots (Available/Total)2 x PCI Express x16
2 x PCI
Hey there, welcome.
1) Uninstall AVG in safe mode using the tool found here:
AV Uninstallers - Windows 7 Forums
Reboot and install MSE to replace it.
2) Update the Realtek HD Audio driver:
RTKVHD64 RTKVHD64.sys Tue Aug 25 07:28:04 2009
3) Update Realtek lan driver:
Rt64win7 Rt64win7.sys Thu Jul 30 07:58:43 2009
4) Daemon Tools with its sptd.sys is notorious. Uninstall Daemon Tools normally then use the installer/uninstaller found here to remove sptd.sys (do not update instead while using):
Reboot and install PowerISO to replace it. Disc emulation part of the software is free forever:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO...
Everything is lookin' good so far. You rock :D
My event viewer is finally clearing up as well(thanks God) The only error I receive at all is, "Microsoft Security Essentials OOBE" stopped due to the following error: 0xC000000D", but this seems pretty common so it seems. Your assistance is much appreciated, and I hope all is well from here on out!
Thanks for the complement and you're welcome. Also, thanks for telling us about how it's going. In the other case, the last I heard was that it was all well and I suppose it still is or I would have been asked for further help.
Enjoy! If there's any further problems, give a shout. :)
Sorry to bug you again :frown: Just came back from work and had another right before I got home. Memory replacement time looks inevitable.
Unfortunately, yes. Test it overnight with Memtest86+.
Will do, and your time is again appreciated. If the ram is bad, I'll be going with this, as it came back compatible with my P55M-UD2 Gigabyte motherboard...Newegg.com - Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model BL2KIT25664BN1337. I had Crucial ram installed in my last pc, and never had a problem with it.
