Windows 7 Cabinet File Detection
Wilsoneiw
I need to install Direct9c for this game that i am playing. However i am unable to complete the installation as the installer says the cabinet file required for installation is not to be trusted. And that i am to verify that the Cryptographic Services are enabled and that the cabinet file certificate is valid.
I am unsure of how to remedy this and will be glad for any assistance.
To address the issue you are facing with the Direct9c installation and the error message about the cabinet file not being trusted, you can follow these steps to verify the Cryptographic Services and ensure the cabinet file certificate is valid:
Steps to Verify Cryptographic Services and Cabinet File Certificate:​
  1. Check Cryptographic Services:
    • Go to the Start menu and search for "services.msc" (without quotes) and press Enter.
    • Look for "Cryptographic Services" in the list of services.
    • Double-click on "Cryptographic Services" to open its properties.
    • Make sure the service is set to "Automatic" under Startup type.
    • Click on the "Start" button to ensure the service is running.
    • Click "OK" to save...
    • Click "OK" to save changes.
    []Check Certificate Revocation List:
    • Open Internet Explorer (even if you don't use it regularly) to check the certificate revocation list.
    • Go to "Tools" > "Internet Options" > "Advanced" tab.
    • Scroll down to the "Security" section and ensure the options "Check for publisher's certificate revocation" and "Check for server certificate revocation" are checked.
    • Click on "Apply" and then "OK" to save the changes.
    ]Download Direct9c from Official Source:
    • It's crucial to download Direct9c from a legitimate source to ensure the cabinet file is trustworthy.
  2. Install Direct9c:
    • Try to reinstall Direct9c after verifying the above settings.
      Further Troubleshooting:​
      If the issue persists after checking and adjusting the Cryptographic Services and certificate revocation settings, you can try the following additional steps:
      • Run Installer as Administrator: Right-click on the installer and select "Run as administrator" to ensure proper permissions during installation.
      • Disable Antivirus: Temporarily disable your antivirus software during the installation process, as it might be flagging the cabinet file incorrectly.
      • Download Updated Version: Ensure you are downloading the most recent version of Direct9c from a trusted source.
      By following these steps, you should be able to resolve the issue with the cabinet file and successfully install Direct9c for your game.
