Windows 7 cdrom code 5
...The disk will setup from within windows.
You can extract all files from the .iso image to the hard drive and run the setup.exe from there.
I did it when I got error messages trying a ordinary installation from cdrom drive, worked super.
Hi Jmagg,
Great!
Glad it worked for you!
Best,
Byron
Ref: Thanks byron, that did the trick.
I did need to put the WIMGAPI.dll into the main Vlite folder manually after I installed Windows AIK.
Cheers
When I try to boot from the DVD I get the message CDROM cannot boot Code 5.
That's because the boot sector of the Windows 7 installation DVD is not fully compatible with ISO9660 standard. But you can create a bootable disk. Take a correct boot sector from other bootable disk (e.g. Vista) and merge it into the Windows 7 installation disk. See Link Removed.
