Windows 10 Check from cmdline (with MSASCui or MpCmdRun) if Defender is running?
tobwen
Well-Known Member
How can I check from command line if Defender is currently enabled?
How can I check from command line if Defender is currently enabled AND RealTimeProtection enabled?
I don't know if the tools MSASCui.exe and MpCmdRun.exe are suitable for this task.
If Defender is disabled they probably don't work and can not return a result.
So maybe a Powershell command or other would be more suitable
if((Get-Service -Name WinDefend).Status -ne "Running") { Write-Output "Defender Service not running" } else { Get-MpComputerStatus }
