A row of blue-lit server racks displays glowing digital patterns in a data center.
CISA (Cybersecurity and Infrastructure Security Agency) has released two Industrial Control Systems (ICS) advisories on August 5, 2025. These advisories provide essential updates regarding cybersecurity issues, vulnerabilities, and exploits related to ICS products.
Here are the two advisories:
CISA recommends that users and administrators read these advisories for technical specifics and recommended mitigations to protect against potential cyber threats.
Source: CISA Official Alert
If you need a summary or details from either advisory, let me know!
Source: CISA CISA Releases Two Industrial Control Systems Advisories | CISA
Good point — thanks, Casey. I agree: these advisories are important and worth treating as high priority for any org running Mitsubishi/ICONICS (and related ICS) software.
Quick summary + immediate actions you can take now
1) Why this matters
  • CISA and vendor advisories describe high‑impact issues in ICONICS/GENESIS64 and Mitsubishi products (DLL hijacking/uncontrolled search path, incorrect default permissions, keypad/config file handling that can launch arbitrary EXEs). These issues can lead to local or remote code execution on Windows engineering/operator hosts.
2) Immediate (high‑priority) checklist — do these first
  • Inventory: identify systems running ICONICS GENESIS64, AlarmWorX, MC Works64, GT Designer3/SoftGOT and any Mitsubishi FA/CNC stacks.
  • Patch/Upgrade: apply vendor patches/rollups (e.g., GENESIS64 10.97.3 critical fixes rollup or later where provided) or follow vendor migration guidance (MC Works64 → GENESIS64 where vendor recommends).
  • Isolate engineering/OT hosts: put engineering workstations and HMI/SCADA hosts on segmented networks or VLANs with strict ACLs and no direct Internet access.
  • Fix file permissions: check ProgramData, project folders, network shares and correct overly permissive ACLs (prevent unprivileged users or remote accounts from replacing config files).
  • Compensating controls: block unnecessary ports, restrict remote file share access, enable host‑based EDR/antivirus on workstations, and require MFA for remote access to maintenance networks.
  • Detect/monitor: look for suspicious EXE launches from HMI processes, unusual DLL loads, and file changes to keypad/config files; enable process auditing and collect logs for SIEM/EDR review.
3) Medium-term actions
  • Formal OT/IT risk assessment and update patching/migration plan.
  • Apply vendor hardening guidance and disable unused features/services.
  • Regularly review CISA/vendor advisories and CVE entries for updates or new mitigations.
Would you like any of the following next?
  • A short one‑page remediation checklist you can send to your OT/IT team (patch commands, exact file paths to check, recommended firewall rules).
  • A prioritized CVE/affected‑version list for your inventory.
  • Suggested detection rules for Windows EDR/SIEM (process creation, DLL loads, changes to HMI config files).
Tell me which one and I’ll produce it (or I can walk you through the steps).
