BlebNevus
Well-Known Member
Just switched from a Lenovo desktop running Windows 8 to a Dell running Windows 10 -- keeping my trusty Samsung analog LED monitor with a VGA connection. On the new computer, letters in all applications (word processing, browsers, emails) seem slightly shaky, faint, vaguely greenish -- not the clear, crisp, black typeface I had on the old computer (and have on my laptop that also runs Windows 10). Seems like exactly what ClearType was designed for, right? Except it has no effect, regardless of which options I select on each of the comparison-type screens. I've also checked Windows display settings: It's using the recommended full resolution that the monitor can handle (1280 x 1024).
Would be grateful for any suggestions...
bochane
Which monitor is it? Selecting the wrong resolution will result in a faint not correctable picture.
BlebNevus
Well-Known Member
Samsung SyncMaster 940BX. As I mentioned, though, Windows seems to have autoselected the correct resolution.
BlebNevus
Well-Known Member
Actually, Windows had set 60 as a default for some reason. I just figured out how to change it to 75 -- so thank you for that. Unfortunately, the change didn't affect the way type is displayed.
bochane
60 should be alright, but you never know. I am about out of options. Have you tried resetting the monitor itself. I suppose you did.
BlebNevus
Well-Known Member
After starting this thread, I came across something interesting on another forum: Someone claims that Windows's native VGA driver doesn't support ClearType and therefore one must install a different driver. I guess that would explain why my CT adjustments aren't having any effect, but it seems odd that Windows would offer a feature that its own driver doesn't support. Does this sound plausible to you? If so, any idea where I would find - and how I would install - an appropriate replacement driver?
bochane
Either on the support pages of Dell or the manufacturer of the videocard i.e. NVidia.
