MIRKOSOFT
Active Member
Hi!
I need to transfer data between my PC (Windows 10.1903 x64 Pro) and notebook with MS-DOS 7.10 (also Windows 3.11 for Workgroups - but without Win32s)
I want to use serial port 'cause DOS is not so familiar with USB.
I know that serial transfer was possible even on my hobby computers - Commodore 8-bits.
But what a software to use for Windows and for DOS?
Also - can anybody recommend me important things like timing etc?
Thank you for help.
Miro
You should be able to connect a USB to serial cable. On the sending computer look in device manager for the COM# of the device.
For example lets say it's COM2. Then run the following two commands from a command prompt.
MODE COM2: BAUD=b PARITY=p DATA=d this command you should only need to issue once with in the command prompt and you will need to replace b,p,and d with the appropriate values configured on the DOS machine
Then to copy you would simply type copy somefile.txt \\.\COM2
For binary file copying COPY somefile.zip /B COM2 /B
Neemobeer
Windows Forum Team
