Windows Vista Control Panel View (Classic)
Noonmark
Vista Home Premium
I view the Control Panel in "classic view". On the left hand side of the screen is a large wasted area. At the top it lists "Control Panel Home" and "Classic View". Is there a way to get rid of that and merely see the icons?
In Windows Vista Home Premium, if you are using the Control Panel in "classic view" and want to remove the large wasted area on the left side of the screen where it lists "Control Panel Home" and "Classic View," you have a few options to customize the Control Panel display to better suit your preferences. Here's how you can customize the Control Panel display in Windows Vista Home Premium: 1. Switch to Category View: - If you prefer a cleaner layout without the large wasted area in Classic View, you can switch to Category View. In Category View, you will see the Control Panel items organized by category with icons. To switch to Category View: - Open the Control Panel. - Click on "Switch to Category View" located on the left side...
In Windows Vista Home Premium, if you are using the Control Panel in "classic view" and want to remove the large wasted area on the left side of the screen where it lists "Control Panel Home" and "Classic View," you have a few options to customize the Control Panel display to better suit your preferences. Here's how you can customize the Control Panel display in Windows Vista Home Premium: 1. Switch to Category View: - If you prefer a cleaner layout without the large wasted area in Classic View, you can switch to Category View. In Category View, you will see the Control Panel items organized by category with icons. To switch to Category View: - Open the Control Panel. - Click on "Switch to Category View" located on the left side of the Control Panel window. 2. Change Control Panel Display Settings: - Another way to customize the Control Panel display is by adjusting the display settings: - Open Control Panel. - Click on "Appearance and Personalization." - Click on "Personalization." - In the left pane, click on "Change desktop icons." - Uncheck the box next to "Control Panel." - Click "OK" to apply the changes. 3. Use Larger Icons: - You can also adjust the icon size in the Control Panel to make better use of the space. Here's how: - Open Control Panel. - Click on "Appearance and Personalization." - Click on "Personalization." - In the left pane, click on "Adjust font size (DPI)." - Select "Use large icons" or adjust the icon size according to your preference. By following these steps, you can customize the Control Panel display in Windows Vista Home Premium to optimize the layout and visibility of icons based on your preferences.
