Windows 7 Convert .wtv to .dvr-ms Files Output with Shorter Length
AkashaJSummer
Honorable Member
When I use the Windows 7 option to convert .wtv to .dvr-ms the converted .dvr-ms files are much shorter in length than the original .wtv files, e.g. a .wtv file with a length of 2:35:58 will be converted to a .dvr-ms file with a length of 29:35.
To troubleshoot this I tested a few .wtv files all with the same result. The .wtv files where all on my (E) drive. Next I moved the .wtv files to the (C) and (D) drive and successfully converted the .wtv to .dvr-ms with the original length intact.
Does this mean my (E) drive is failing or is there another reason why this is specific to the (E) drive?
patcooke
Microsoft MVP
Microsoft MVP
I'd try using a third party utility to see if that works on your drive E - if it does then that would clear your drive E of suspicion.
