Windows 7 Copy > Less / More info
CabbageTree
Hi,*
I would like to ask, whether someone has any idea, if is possible to see more info while copy by default, without that bloody click...
Thanx & have a great X-mas!
Hello! It sounds like you're looking for a way to get additional information when copying files without having to click every time. This can be achieved through certain settings in Windows. To enable more information to be shown by default during copying, you can adjust the settings in File Explorer. Here's how you can do it: 1. Open File Explorer Options: - Open File Explorer. - Go to the "View" tab. - Click on "Options" on the right side. This opens the Folder Options window. 2. Adjust Folder Options: - In the Folder Options window, go to the "View" tab. - Scroll down and find the checkbox for "Show more information while dragging." - Check this option to enable more information to be displayed during file operations like...
Hello! It sounds like you're looking for a way to get additional information when copying files without having to click every time. This can be achieved through certain settings in Windows. To enable more information to be shown by default during copying, you can adjust the settings in File Explorer. Here's how you can do it: 1. Open File Explorer Options: - Open File Explorer. - Go to the "View" tab. - Click on "Options" on the right side. This opens the Folder Options window. 2. Adjust Folder Options: - In the Folder Options window, go to the "View" tab. - Scroll down and find the checkbox for "Show more information while dragging." - Check this option to enable more information to be displayed during file operations like copying. By enabling this setting, you should see more details without the need to click during file operations like copying. This should make the copying process more informative and user-friendly. I hope this helps! Let me know if you need further assistance. Have a great day and Happy Holidays!
